Software Archive
Read-only legacy content
Unity3d not detecting Realsense camera at all the time
yoga_a_
hello,
i'm using real sense for unity3d.
when ever I hit the play button in unity3d the  real sense camera is not working all the times sometimes it working
most of the times not working ( light never turned on) .
and also it stop functioning after few minutes of working ( light goes off).
can any one suggest me to fix this issue.
samontab
Valued Contributor II
It seems that it is a power issue. Try another USB 3.0 port, another computer, or try a powered USB 3.0 hub.
yoga_a_
thanks, but its working perfectly  with real sense sample browser
Tao_P_Intel
maybe you should set right resolution and fps of color and depth.
Felipe_P_Intel
Hi Yoga,
Could you provide more details about what you are you trying to do in Unity? I'm sure sure but are you using the latest version of the SDK? Are you using the latest version of the DCM? Did you check if the cable of you camera is damaged?
Here is the link of the latest version of SDK and DCM: https://software.intel.com/en-us/intel-realsense-sdk/download
Also, I suggest you to take a look in this article with tips and tricks for Unity development: https://software.intel.com/en-us/blogs/2014/12/06/tips-and-tricks-to-use-unity-with-the-intel-realsense-sdk-2014
Felipe
yoga_a_
Hi Felipe,
Thanks for reply, after your comment, I tried latest versions of DCM and SDK but the result is same.
and there is no damage in the cable and device
when I try to play the lights in the F200 device comes and goes off,
sometimes it's working most of the times not working
