Software Archive
Read-only legacy content
17060 Discussions
Upcoming Intel Parallel Building Blocks and Intel Cilk Plus Technical Presentations
Elizabeth_S_Intel
You are invited to two upcoming Intel Parallel Studio Techincal Presentations:
Thursday, September 23, 2010
9:00-10:00 AM Pacific (GMT-8)
5:00-6:00 PM Pacific (GMT-8)
Introducing Intel Parallel Building Blocks
This technical presentation will introduce three methods for adding parallelization to your serial application: Intel Threading Building Blocks, Intel Cilk Plus, and Intel Array Building Blocks. The methods will be compared showing where each will be most beneficial and to what types of applications. In addition to the presentation there will be time for Q&A on these threading methods or any other questions you might have about using Intel Parallel Studio.
Tuesday, September 28, 2010
Introduction to Intel Cilk Plus
Intel Cilk Plus, one of the Intel Parallel Building Blocks which includes Intel Threading Building Blocks and Intel Array Building Blocks, provides C/C++ language extensions to implement parallelism in your application simply and efficiently. This technical talk will cover this new syntax, supported by the C++ compiler in Intel Parallel Composer, and how it provides an easy way to use task and vector parallelism to take full advantage of multiple cores and the SIMD-compute engine on CPUs. In addition to the presentation there will be time for Q&A on Intel Cilk Plus or any other questions you might have about using Intel Parallel Studio.
Register hereand see other upcoming presenations.
