Software Archive
Read-only legacy content
17061 Discussions
Upgrading Floating Licenses from Intel Cluster Studio to 2016 Parallel Studio XE
ed_rosenbloom
I have 2 Floating Licenses  for Intel Cluster Studio for Linux. I am running icc 11,12, and 14 versions under these existing licenses.
I am about to install icc 16, licenses obtained (via upgrade) for  Intel® Parallel Studio XE Cluster Edition for Linux.
Will the new licenses for icc 16 support running the older versions (above)  of the Intel compiler which I need for existing customer support, as well as the 16 version?
Devorah_H_Intel
Your license includes older version, however support is limited to a number of compiler versions supported. The following article explains which versions of compiler are currently supported (14.0 and newer).
https://software.intel.com/en-us/articles/intel-compilers-supported-compiler-versions
ed_rosenbloom
Will the older versions still run if i upgrade the license files to the new licenses?
Devorah_H_Intel
Yes, the older versions of the compiler will work with new licenses.
