- Отметить как новое
- Закладка
- Подписаться
- Отключить
- Подписка на RSS-канал
- Выделить
- Печать
- Сообщить о недопустимом содержимом
Whenever I try to Build or Test my game which is exported from Construct 2 the following error occurs, even when I tried the sample Cordova app I had the same problem.
ERROR (-9) from "client:upload-manager": Error in uploading project files: : Error in uploading project files: : Error in uploading project files: : unable to verify the first certificate Error at new ComponentError (C:\Users\Dante\AppData\Local\Intel\XDK\xdk\core-modules\public\component-error.js:17:1122) at makeError (file:///C:/Users/Dante/AppData/Local/Intel/XDK/xdk/components/client/upload-manager/upload-manager.js:17:170) at getComponentError (file:///C:/Users/Dante/AppData/Local/Intel/XDK/xdk/components/client/upload-manager/upload-manager.js:17:265) at file:///C:/Users/Dante/AppData/Local/Intel/XDK/xdk/components/client/upload-manager/upload-manager.js:17:11448 at _rejected (C:\Users\Dante\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:844:24) at C:\Users\Dante\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:870:30 at Promise.when (C:\Users\Dante\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:1122:31) at Promise.promise.promiseDispatch (C:\Users\Dante\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:788:41) at C:\Users\Dante\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:604:44 at runSingle (C:\Users\Dante\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:137:13)
I can really use some help from you guys on how to tackle this issue, thanks.
P.S. The app works fine in emulator.
- Теги:
- HTML5
- Intel® XDK
Ссылка скопирована
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Name your project so it contains only 7-bit ASCII letters, numbers and dashes. There may be a problem with a project name that has "odd" characters in it.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
My project is named "Sample" without quotes and "BaseballHenk". Both of these projects have same problem, and this is the first time am using Intel XDK, just downloaded it yesterday from the Intel site, I have no previous experience with the tool.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Did you use the Construct2 export to XDK option? And then "open" that project using the XDK.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Yes, That is what i did, even more as I mentioned the demo project which comes with the Intel XDK called Hello Cordova project is having the same problem, so its not a construct 2 issue.
- Отметить тему как новую
- Отметить тему как прочитанную
- Выполнить отслеживание данной Тема для текущего пользователя
- Закладка
- Подписаться
- Страница в формате печати
