Software Archive
Read-only legacy content
Comunicados
17060 Discussões
V3088 iOS built OK but lots of Error in Android build
Nick_F_2
Novo colaborador III
437 Visualizações
Just converted at app to V3088
Finally got the certificates updated.iOS build fine but the Android build fails. This is the error towards the end of the log.
  symbol: class CordovaChromeClient
.../WFSL/platforms/android/src/com/intel/xdk/device/Device.java:1184: error: cannot find symbol
            CordovaChromeClient ccc = new CordovaChromeClient((CordovaInterface) activity, remoteView);;
.../WFSL/platforms/android/src/com/intel/xdk/device/Device.java:1191: error: incompatible types: CordovaWebView cannot be converted to View
        remoteLayout.addView(remoteView);
.../WFSL/platforms/android/src/com/intel/xdk/device/Device.java:1202: error: cannot find symbol
      remoteView.requestFocus(View.FOCUS_DOWN);
  symbol:   method requestFocus(int)
.../WFSL/platforms/android/src/com/intel/xdk/device/Device.java:1203: error: cannot find symbol
      remoteView.setOnTouchListener(new View.OnTouchListener() {
  symbol:   method setOnTouchListener(<anonymous OnTouchListener>)
Note: .../WFSL/platforms/android/src/com/intel/xdk/device/Device.java uses or overrides a deprecated API.
Note: Recompile with -Xlint:deprecation for details.
Note: .../WFSL/platforms/android/src/com/intel/xdk/device/Device.java uses unchecked or unsafe operations.
Note: Recompile with -Xlint:unchecked for details.
Note: Some messages have been simplified; recompile with -Xdiags:verbose to get full output
16 errors
 FAILED
FAILURE: Build failed with an exception.
* What went wrong:
Execution failed for task ':compileArmv7ReleaseJava'.
> Compilation failed; see the compiler error output for details.
* Try:
Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
BUILD FAILED
Total time: 22.303 secs
.../WFSL/platforms/android/cordova/node_modules/q/q.js:126
                    throw e;
Error code 1 for command: .../WFSL/platforms/android/gradlew with args: cdvBuildRelease,-b,.../WFSL/platforms/android/build.gradle,--no-daemon
Command finished with error code 1: .../WFSL/platforms/android/cordova/build --release
ERROR building one of the platforms: Error: .../WFSL/platforms/android/cordova/build: Command failed with exit code 1
You may not have the required environment or OS to build this project
    at ChildProcess.whenDone (.../cordova/cordova-cli/5.1.1/node_modules/cordova/node_modules/cordova-lib/src/cordova/superspawn.js:134:23)
    at emitTwo (events.js:87:13)
    at ChildProcess.emit (events.js:172:7)
    at maybeClose (internal/child_process.js:821:16)
    at Process.ChildProcess._handle.onexit (internal/child_process.js:211:5)
1 Responder
Nick_F_2
437 Visualizações
After updating to CLI 5.4.1 the build was successful.
Responder
