Software Archive
Read-only legacy content
17060 Discussions
V3491, new project and config xml files
James_H_4
Just noticed that when I use the nice graphical interface to update the build data it isn't updated in the underlying files like intelxdk.config.android.xml.  This file contains the <access> tag. I had created a new V3491 project and found that none of these config xml files were created, which I am assuming is the reason why my new project will not display anything on the canvas but I can rendir the index.html using firefox.I haven't had the chance to test this theory. I am planning to manually create the config.xml files and see if the new project starts working. The old project had the xml files but the xml wasn't updated when I would change the build data from the interface. Is the user interface buggy?
PaulF_IntelCorp
Those config files (other than the intelxdk.config.additions.xml file) are only created when you attempt a build or push the "sync" button on the Test tab.
