Software Archive
Read-only legacy content
17060 Discussions
VS2015 integration error: The specified account already exists
K_L_1
I am having difficulties with the PSXE 2016 setup when I select the VS2015 integration option. I can successfully install PSXE without VS2015 integration.
The setup process aborts immediately after the installation starts. The error in the log files looks like this:
MSI (s) (E0:C4) [15:12:17:810]: Executing op: FolderCreate(Folder=C:\Program Files (x86)\Intel\Composer XE 2013\,Foreign=0,,)
MSI (s) (E0:C4) [15:12:17:813]: Executing op: FolderCreate(Folder=C:\Program Files (x86)\Intel\Composer XE 2013\,Foreign=0,,)
MSI (s) (E0:C4) [15:12:17:814]: Executing op: ActionStart(Name=InstallFiles,Description=Copying new files,Template=File: [1],  Directory: [9],  Size: [6])
MSI (s) (E0:C4) [15:12:17:814]: Executing op: ProgressTotal(Total=301134,Type=0,ByteEquivalent=1)
MSI (s) (E0:C4) [15:12:17:814]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Microsoft Visual Studio 10.0\Common7\IDE\Extensions\Intel\C++\)
MSI (s) (E0:C4) [15:12:17:814]: Executing op: SetSourceFolder(Folder=1\7prcblcg\Common7\IDE\yxarz17c\Intel\dyfafbdx\|VS2010DIR\Common7\IDE\Extensions\Intel\C++\)
MSI (s) (E0:C4) [15:12:17:814]: Executing op: ChangeMedia(MediaVolumeLabel=DISK1,MediaPrompt=Please insert the disk: Disk 1,MediaCabinet=1\Data1.cab,BytesPerTick=65536,CopierType=1,,,SignatureRequired=0,,,IsFirstPhysicalMedia=1)
MSI (s) (E0:C4) [15:12:17:814]: Executing op: RegisterSharedComponentProvider(,,File=File_ICMnuPkg.CompPro.dll0,Component={21B050C4-D4D2-11E2-9E75-00237DA952BE},ComponentVersion=13.0.1211.2010,ProductCode={742DCCA9-267E-4AAD-A5B5-CAAC5608EB6E},ProductVersion=13.1.3,PatchSize=0,PatchAttributes=0,PatchSequence=0,SharedComponent=0,IsFullFile=0)
MSI (s) (E0:C4) [15:12:17:816]: Executing op: FileCopy(SourceName=k51ulwxq.dll|ICMnuPkg.CompPro.dll,SourceCabKey=File_ICMnuPkg.CompPro.dll0,DestName=ICMnuPkg.CompPro.dll,Attributes=512,FileSize=130488,PerTick=65536,,VerifyMedia=1,,,,,CheckCRC=0,Version=13.0.1211.2010,Language=0,InstallMode=58982400,,,,,,,)
MSI (s) (E0:C4) [15:12:17:817]: File: C:\Program Files (x86)\Microsoft Visual Studio 10.0\Common7\IDE\Extensions\Intel\C++\ICMnuPkg.CompPro.dll;    To be installed;    Won't patch;    No existing file
MSI (s) (E0:C4) [15:12:17:817]: Resolving source.
MSI (s) (E0:C4) [15:12:17:817]: Resolving source to launched-from source.
MSI (s) (E0:C4) [15:12:17:817]: Setting launched-from source as last-used.
MSI (s) (E0:C4) [15:12:17:817]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'C:\WINDOWS\Installer\'.
MSI (s) (E0:C4) [15:12:17:817]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\WINDOWS\Installer\'.
MSI (s) (E0:C4) [15:12:17:817]: PROPERTY CHANGE: Adding SourcedirProduct property. Its value is '{742DCCA9-267E-4AAD-A5B5-CAAC5608EB6E}'.
MSI (s) (E0:C4) [15:12:17:817]: SOURCEDIR ==> C:\WINDOWS\Installer\
MSI (s) (E0:C4) [15:12:17:817]: SOURCEDIR product ==> {742DCCA9-267E-4AAD-A5B5-CAAC5608EB6E}
MSI (s) (E0:C4) [15:12:17:821]: SECREPAIR: CryptAcquireContext succeeded
MSI (s) (E0:C4) [15:12:17:821]: Determining source type
MSI (s) (E0:C4) [15:12:17:821]: Note: 1: 2203 2: C:\WINDOWS\Installer\w_cproide_c_unique_p_13.1.198.msi 3: -2147287038
MSI (s) (E0:C4) [15:12:17:821]: Note: 1: 1316 2: C:\WINDOWS\Installer\w_cproide_c_unique_p_13.1.198.msi
MSI (s) (E0:C4) [15:12:17:822]: SECREPAIR: Error determining package source type
MSI (s) (E0:C4) [15:12:17:822]: SECUREREPAIR: SecureRepair Failed. Error code: 524F6E844B8
MSI (s) (E0:C4) [15:12:17:822]: Note: 1: 2205 2:  3: Error
MSI (s) (E0:C4) [15:12:17:822]: Note: 1: 2228 2:  3: Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 1709
MSI (s) (E0:C4) [15:12:17:822]: Product: C++ Integration(s) in Microsoft Visual Studio* -- Error 1316. The specified account already exists.
The log contains references to VS2010 and Composer XE 2013 which I no longer have installed. The installer application, however, shows a few warning messages that Composer 2011' and 2013' integration in VS will be replaced with PSXE 2016. The older versions of the Intel compiler have been uninstalled and these messages shouldn't appear.
Actions performed to debug the problem:
  • Multiple uninstall/install cycles of VS2015 and PSXE 2016
  • Purge all Intel references from the registry
  • Purge the user AppData directory from all VS2015 and Intel references
The error still persists. Could you please advise how it could be resolved.
Thank you,
James_S
Hi K L.,
Could you please try to look for any occurrence of VS2010 and Composer XE 2013 in registry and remove it manually?
If the issue still exists, after installing VS 2015, could you please try to find original package of installed Composer XE 2013 and uninstall it by launching setup.exe from package. And then try to install PSXE 2016 again.
I have sent a private message asking for the installation log file. Thanks.
K_L_1
The problem was resolved thanks to Zhuowei's valuable help.
These are the steps advised by Zhuowei:
  1. Installed VS2010
  2. Installed Intel Composer 2013
  3. Installed Intel PSXE 2016 [success]
  4. Uninstalled Intel Composer 2013
  5. Uninstalled VS2010
My VS2015 installation however was corrupted as a result of the above. Using the "Repair" option of the installer didn't help. I had to uninstall and reinstall it. Afterwards everything worked as expected (including the Intel compiler integration in VS2015).
The cause of the problem is unknown at this time.
