Software Archive
Read-only legacy content
Version 2496 Background Gradient slide unresponsive and causes XDK to crash
Nick_F_2
New Contributor III
Using background gradient slider XDK becomes unresponsive and crashes every time I use it. Can make small adjustments but then it freezes and crashes.
Also styles do not always appear when clicked on whether new styles or those already defined. I have to refresh the design screen for them to appear, even then they do not appear every time. I have to restart XDK to get them to appear so that I can make changes.
Running on OS X 10.10.5 i7 Macbook Air with 8GB RAM.
Pamela_H_Intel
Which background gradient slider are you using?
Nick_F_2
New Contributor III
The one in XDK designer for setting a page background gradient.
Create a page, add Background Style, move a slider to adjust the gradient and XDK freezes. Have to Force Quit to close and start again.
Pamela_H_Intel
Nick,
I have informed the engineer in charge of App Designer. He is working on it.
Meanwhile, if you know the RGB values or just want to click on the color in the color wheel, you can click the Background Color check box, then click in the color box next to it which will open a popup where you can type the RGB values or select a color.
