Hi, I'm trying to develop some shader code on a Sandy bridge + HD graphics 3000 hardware using Visual studio 2008 (latest version, SP, patches, drivers, SDK ...)
Running the EXE as a stand alone gives this timings
Compiling Pixel Shader ../WorldViewer/DX10\\SimuFluid_RenderSmooth_ComputeVisibilityLOD4x4.ps.hlsl
Took 1317.041662 ms
Create Took 1832.699483 ms
Compiling Pixel Shader ../WorldViewer/DX10\\SimuFluid_RenderSmooth_ComputeVisibilityLOD2x2.ps.hlsl
Took 377.944188 ms
Create Took 156.574857 ms
Compiling Pixel Shader ../WorldViewer/DX10\\SimuFluid_RenderSmooth_ComputeVisibilityLOD2x2x2.ps.hlsl
Took 672.108109 ms
Create Took 399.883245 ms
Compiling Pixel Shader ../WorldViewer/DX10\\SimuFluid_RenderSmooth_ComputeVisibilityLOD2x2x4.ps.hlsl
Took 1352.036399 ms
Create Took 1632.707879 ms
Running from VS (Release, full optimizations, anyway it's the driver's code which takes all the time)
Took 1390.279165 ms
Create Took 7952.150473 ms
Took 383.181736 ms
Create Took 3648.525213 ms
Took 706.142689 ms
Create Took 4018.351381 ms
Took 1386.748164 ms
Create Took 7980.124220 ms
the D3DCompile (Microsoft) takes about the same time running as a stand-alone EXE or launched from Visual Studio.
the Device->CreateShader (Intel) is up to 20 times longer while running from Visual Studio
which is very annoying when you spend all your day trying your shaders code.
is there a workaround to prevent it please ?
Took 1317.041662 ms
Took 377.944188 ms
Took 672.108109 ms
Took 1352.036399 ms
Took 1390.279165 ms
Took 383.181736 ms
Took 706.142689 ms
Took 1386.748164 ms
Hi.
Here is a workaround :
set _NO_DEBUG_HEAP=1 in VisualStudio environment settings for the project you are working on.
http://blogs.msdn.com/b/ms_joc/archive/2009/02/19/why-is-my-app-so-much-slower-under-the-debugger.aspx
>>...set _NO_DEBUG_HEAP=1...
He is running from Release configuration. Take a look, please:
From the 1st post:
>>...Running from VS (Release, full optimizations...
All memory management CRT-functions, like 'malloc_dbg', 'free_dbg', etc, shouldn't be called and it looks like something else affects the performance.
From the 1st post:
