Software Archive
Read-only legacy content
17060 Discussions
VisBasic call to Fortran DLL
Intel_C_Intel
I used the VisualBAsic-Visual Fortran DLL sample code (Compaq vb-example FCALL.F90) to check calling a DLL from VisBasic. Works fine on my computer but when trying to run on some other computers, I get the message: "Run time error '7'. File not found fcall.dll"
I used DEPENDS.EXE and verified the dependent dlls were in windowssystem directory.
I moved the fcall.dll and the vb executable to floppy. Runs fine on my computer. Move floppy to my lap top - get the error message. I copied DFORRT.DLL to the floppy - still get error message.
Any trouble shooting suggestions would be much appreciated.
Roger
Steven_L_Intel1
Is DFORRT.DLL in the Windows System folder of your laptop? It could also be in the PATH or in the directory where the VB executable is (if it's a .EXE).
On your CVF 6.5 CD in folder X86USUPPORTMISC is a program called LOADTEST.EXE. Copy this to your laptop, start a command prompt, and type: LOADTEST your-EXE It will report any problems found.
Steve
Intel_C_Intel
Steve,
Confiming that DFORRT.DLL is in the windows system folder. I just copied it there - does it need to be registerred??
Based on other forum messages, compiled dll using static libs istead of dll libs - ran ok.
I don't have LOADTEST.EXE on my cd (version upgrade 6.x to 6.5). Is it available to download??
Thanks for help.
Roger
Steven_L_Intel1
Here
Steve
Intel_C_Intel
Ran loadtest in A: drive of lap top.
Loadtest FCALL.DLL - "The specified module could not be found"
Loadtest Project.exe - "One of the library files needed to run this application could not be found"
Steven_L_Intel1
Very strange. LOADTEST doesn't link against any non-standard DLLs. Please e-mail your fcall.dll to me at fortran@compaq.com so that I can take a look at it. What Windows version is your laptop?
Steve
Intel_C_Intel
Steve,
Tried moving MSVCRT.DLL to floppy. Still ng. But along the way, I
believe I found the problem. Using DEPENDENCY WALKER (came up when I
used explorer and double cliked on the dll), showed DFORRT.DLL "doesn't
appear to be WIN32 module..." Recopied DFORRT.DLL to floppy and voila,
runs ok. So I guess DFORRT.DLL got contaminated along the way.
Steve, thank you again for your patient support. VERY MUCH APPRECIATED.
Roger
