- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
I use GotoBlas and mpich to run hpl in the cluster(the cpu is Intel(R) Xeon(R) CPU E5-2670 0 @ 2.60GHz). I use two ways to compile GotoBlas:(1)make (2)make USE_THREAD=0 TARGET=NEHALEM. The library used in the makefile of hpl is libgoto.a. However, the two different ways of compiling GotoBlas all leads to a low efficiency of HPL results: only 150GFlops(the theorical peak is 330 GFlops). Do I have some mistakes in compiling GotoBlas? Thanks for your answer.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
As you don't use Intel xeon phi, the subject isn't topical here.
Did you see the advice to set core2 rather than Nehalem if you can't upgrade to openblas? The latter project would seem a better source for advice.
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Thanks for your answer. I know I asked the question in a wrong place, but I don't know where to find experts...I will try you method, thank you
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
A more appropriate forum might be:
https://software.intel.com/en-us/forums/software-tuning-performance-optimization-platform-monitoring
In this case the answer is easy -- the Nehalem target generates SSE2/3/4 code (128-bit SIMD vectors), while your Xeon E5-2670 (Sandy Bridge EP) processor requires AVX code (256-bit SIMD vectors) to achieve full speed. So you are getting 150 GFLOPS out of a peak of 165 GFLOPS (using SSE code), which is about 91% of peak.
The author of GotoBLAS worked at TACC (http://www.tacc.utexas.edu/) when I started working at TACC in 1999. He left for industry well before we received our first Xeon E5 (Sandy Bridge EP) processors, so it was never optimized for that target. The OpenBLAS project (http://www.openblas.net/) added Sandy Bridge support, and is continuing to add support for Haswell and other newer processors.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
https://software.intel.com/en-us/forums/software-tuning-performance-opti...
Thank you for your explanation. Finally I know the reason of low effiency.(My teacher will forgive me for such a low efficiency :) ) Thank you very much!
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
