Software Archive
Read-only legacy content
17061 Discussions
Windows uninstallation of Parallel Studio XE 2017 u2
lespo
I am unable to uninstall Parallel Studio XE 2017. I get the following screen:uninst.PNG
The same screen appears if I try to repair the installation first. The same screen appears regardless if I run installer from add/remove programs or setup.exe from disk. I tried the tool from microsoft : https://support.microsoft.com/en-us/help/17588/fix-problems-that-block-programs-from-being-installed-or-removed which was suggested in one of the posts but without luck. The setup ends right at the first component (I think it writes something about sortcuts).
Help is really welcome as I really need to remove it.
Devorah_H_Intel
Could you please attach installer logs specified in the above screen? Do you have any previous versions of the Intel Software install on the system?
lespo
The log is attached (it is 7zipped as the original is over 22 MB)550214
There was no previsous installation of the Parallel studio on the system.
Devorah_H_Intel
Thank you for the log. We will investigate the issue and update you on the status.
