Hey All!
i have upgraded my XDK to 3088 version. But now, it cant starts
LOG Says:
xdk:client:[2016-03-31T10:59:49.206Z]: (1459421989207): memlim: 1535115264
xdk:client:[2016-03-31T10:59:49.210Z]: (1459421989210): Setting NW crash dump to: /root/.config/XDK
xdk:client:[2016-03-31T10:59:49.374Z]: (1459421989374): Intel XDK: 3088
xdk:client:[2016-03-31T10:59:49.374Z]: (1459421989374): Platform: linux-x64 (4.4.6-300.fc23.x86_64)
xdk:client:[2016-03-31T10:59:49.374Z]: (1459421989374): System Info: CPU: 4 X Intel(R) Core(TM) i7-4510U CPU @ 2.00GHz Physical Memory: 8272400384
xdk:client:[2016-03-31T10:59:49.374Z]: (1459421989374): NW: 0.11.7-rc10-dev
xdk:client:[2016-03-31T10:59:49.432Z]: (1459421989432): Created new theme: base
xdk:client:[2016-03-31T10:59:49.432Z]: (1459421989432): Registered new theme: base
xdk:client:[2016-03-31T10:59:49.434Z]: (1459421989434): Current theme is now: base
xdk:client:[2016-03-31T10:59:49.434Z]: (1459421989434): Loading theme from: ../../public/themes/xdk.json
xdk:client:[2016-03-31T10:59:49.434Z]: (1459421989434): Created new theme: base
xdk:client:[2016-03-31T10:59:49.434Z]: (1459421989434): Registered new theme: xdk
xdk:client:[2016-03-31T10:59:49.435Z]: (1459421989435): Current theme is now: xdk
xdk:client:[2016-03-31T10:59:49.579Z]: (1459421989579): Starting client process initialization
xdk:client:[2016-03-31T10:59:49.597Z]: (1459421989597): OS version: "Fedora release 23 (Twenty Three)"
xdk:client:[2016-03-31T10:59:49.610Z]: (1459421989610): NW Cache is up-to-date.
xdk:server:[2016-03-31T10:59:50.046Z]: (1459421990047): memlim: 1535115264
xdk:server:[2016-03-31T10:59:50.049Z]: (1459421990049): Setting NW crash dump to: /root/.config/XDK
xdk:server:[2016-03-31T10:59:50.197Z]: (1459421990197): Starting server process initialization
xdk:server:[2016-03-31T10:59:50.260Z]: (1459421990260): Http server started on the standard port 58889
xdk:server:[2016-03-31T10:59:50.277Z]: (1459421990277): NW Cache is up-to-date.
xdk:server:[2016-03-31T10:59:50.634Z]: (1459421990634): Component "core:assert" starting import
xdk:server:[2016-03-31T10:59:50.634Z]: (1459421990634): Component "core:assert" finished initialization
xdk:server:[2016-03-31T10:59:50.634Z]: (1459421990634): Component "core:component-error" starting import
xdk:server:[2016-03-31T10:59:50.635Z]: (1459421990635): Component "core:component-error" finished initialization
xdk:server:[2016-03-31T10:59:50.635Z]: (1459421990635): Component "core:command-line-options" starting import
xdk:server:[2016-03-31T10:59:50.635Z]: (1459421990635): Component "core:command-line-options" finished initialization
xdk:server:[2016-03-31T10:59:50.635Z]: (1459421990635): Component "core:service-error" starting import
xdk:server:[2016-03-31T10:59:50.635Z]: (1459421990635): Component "core:service-error" finished initialization
xdk:server:[2016-03-31T10:59:50.635Z]: (1459421990635): Component "core:buffer" starting import
xdk:server:[2016-03-31T10:59:50.635Z]: (1459421990635): Component "core:buffer" finished initialization
xdk:server:[2016-03-31T10:59:50.635Z]: (1459421990635): Component "core:signaler" starting import
xdk:server:[2016-03-31T10:59:50.636Z]: (1459421990636): Component "core:signaler" finished initialization
xdk:server:[2016-03-31T10:59:50.636Z]: (1459421990636): Component "core:signaler-group" starting import
xdk:server:[2016-03-31T10:59:50.638Z]: (1459421990638): Component "core:signaler-group" finished initialization
xdk:server:[2016-03-31T10:59:50.638Z]: (1459421990638): Component "core:logger" starting import
xdk:server:[2016-03-31T10:59:50.638Z]: (1459421990638): Component "core:logger" finished initialization
xdk:server:[2016-03-31T10:59:50.638Z]: (1459421990638): Component "core:http-request" starting import
xdk:server:[2016-03-31T10:59:50.639Z]: (1459421990639): Component "core:http-request" finished initialization
xdk:server:[2016-03-31T10:59:50.639Z]: (1459421990639): Component "core:database" starting import
xdk:server:[2016-03-31T10:59:50.640Z]: (1459421990640): Component "core:database" finished initialization
xdk:server:[2016-03-31T10:59:50.640Z]: (1459421990640): Component "core:version" starting import
xdk:server:[2016-03-31T10:59:50.640Z]: (1459421990640): Component "core:version" finished initialization
xdk:server:[2016-03-31T10:59:50.640Z]: (1459421990640): Component "core:userfs-name-converter" starting import
xdk:server:[2016-03-31T10:59:50.640Z]: (1459421990640): Component "core:userfs-name-converter" finished initialization
xdk:server:[2016-03-31T10:59:50.640Z]: (1459421990640): Component "core:crash-handler" starting import
xdk:server:[2016-03-31T10:59:50.641Z]: (1459421990641): Component "core:crash-handler" finished initialization
xdk:server:[2016-03-31T10:59:50.641Z]: (1459421990641): Component "core:i18n-support" starting import
xdk:server:[2016-03-31T10:59:50.641Z]: (1459421990641): Component "core:i18n-support" finished initialization
xdk:server:[2016-03-31T10:59:50.641Z]: (1459421990641): Component "core:theme" starting import
xdk:server:[2016-03-31T10:59:50.685Z]: (1459421990685): Component "core:theme" finished initialization
xdk:server:[2016-03-31T10:59:50.686Z]: (1459421990686): Component "server:userfs" starting import
xdk:server:[2016-03-31T10:59:50.689Z]: (1459421990689): Component "server:userfs" calling init()
xdk:server:[2016-03-31T10:59:50.711Z]: (1459421990711): Component "server:userfs" finished initialization
xdk:server:[2016-03-31T10:59:50.711Z]: (1459421990711): Component "server:user-profile" starting import
xdk:server:[2016-03-31T10:59:50.713Z]: (1459421990713): Component "server:user-profile" calling init()
xdk:server:[2016-03-31T10:59:50.713Z]: (1459421990713): Component "server:user-profile" finished initialization
xdk:server:[2016-03-31T10:59:50.714Z]: (1459421990714): Component "server:ui-builder" starting import
xdk:server:[2016-03-31T10:59:50.754Z]: (1459421990754): Component "server:ui-builder" calling init()
xdk:server:[2016-03-31T10:59:50.756Z]: (1459421990756): Component "server:ui-builder" finished initialization
xdk:server:[2016-03-31T10:59:50.756Z]: (1459421990756): Component "server:emulator-notification" starting import
xdk:server:[2016-03-31T10:59:50.759Z]: (1459421990759): Component "server:emulator-notification" calling init()
xdk:server:[2016-03-31T10:59:50.759Z]: (1459421990759): Component "server:emulator-notification" finished initialization
xdk:server:[2016-03-31T10:59:50.759Z]: (1459421990759): Component "server:emulator-webserver" starting import
xdk:server:[2016-03-31T10:59:50.760Z]: (1459421990760): Component "server:emulator-webserver" calling init()
xdk:server:[2016-03-31T10:59:50.761Z]: (1459421990761): Component "server:emulator-webserver" finished initialization
xdk:server:[2016-03-31T10:59:50.761Z]: (1459421990761): Component "server:zip-util" starting import
xdk:server:[2016-03-31T10:59:50.763Z]: (1459421990763): Component "server:zip-util" calling init()
xdk:server:[2016-03-31T10:59:50.763Z]: (1459421990763): Component "server:zip-util" finished initialization
xdk:server:[2016-03-31T10:59:50.764Z]: (1459421990764): Component "server:uuid-server" starting import
xdk:server:[2016-03-31T10:59:50.765Z]: (1459421990765): Component "server:uuid-server" calling init()
xdk:server:[2016-03-31T10:59:50.766Z]: (1459421990766): Component "server:uuid-server" finished initialization
xdk:server:[2016-03-31T10:59:50.766Z]: (1459421990766): Component "server:force-download" starting import
xdk:server:[2016-03-31T10:59:50.768Z]: (1459421990768): Component "server:force-download" calling init()
xdk:server:[2016-03-31T10:59:50.769Z]: (1459421990769): Component "server:force-download" finished initialization
xdk:server:[2016-03-31T10:59:50.769Z]: (1459421990769): Component "server:updater" starting import
xdk:server:[2016-03-31T10:59:50.781Z]: (1459421990781): Component "server:updater" calling init()
server:updater:[2016-03-31T10:59:50.782Z]: (1459421990782): config.base-auto
server:updater:[2016-03-31T10:59:50.782Z]: (1459421990782): url=auto
xdk:server:[2016-03-31T10:59:50.782Z]: (1459421990782): Component "server:updater" finished initialization
xdk:server:[2016-03-31T10:59:50.782Z]: (1459421990782): Component "server:editor-node" starting import
xdk:server:[2016-03-31T10:59:50.800Z]: (1459421990800): Component "server:editor-node" calling init()
xdk:server:[2016-03-31T10:59:50.800Z]: (1459421990800): Component "server:editor-node" waiting for delayed initialization
xdk:server:[2016-03-31T10:59:50.800Z]: (1459421990800): Component "server:cordova-lib" starting import
xdk:server:[2016-03-31T10:59:51.019Z]: (1459421991019): Component "server:cordova-lib" calling init()
xdk:server:[2016-03-31T10:59:51.115Z]: (1459421991115): Component "server:cordova-lib" finished initialization
xdk:server:[2016-03-31T10:59:51.115Z]: (1459421991115): Component "server:api-explorer" starting import
xdk:server:[2016-03-31T10:59:51.117Z]: (1459421991117): Component "server:api-explorer" calling init()
xdk:server:[2016-03-31T10:59:51.145Z]: (1459421991145): Component "server:api-explorer" finished initialization
xdk:server:[2016-03-31T10:59:51.145Z]: (1459421991145): Component "server:plugin-listener" starting import
xdk:server:[2016-03-31T10:59:51.146Z]: (1459421991146): Component "server:plugin-listener" calling init()
xdk:server:[2016-03-31T10:59:51.146Z]: (1459421991146): Component "server:plugin-listener" finished initialization
xdk:server:[2016-03-31T10:59:51.146Z]: (1459421991146): Component "server:git-runner" starting import
xdk:server:[2016-03-31T10:59:51.147Z]: (1459421991147): Component "server:git-runner" calling init()
xdk:server:[2016-03-31T10:59:51.148Z]: (1459421991148): Component "server:git-runner" finished initialization
server:editor-node:[2016-03-31T10:59:51.149Z]: (1459421991149): Starting Brackets node process /home/hpandelo/Softwares/intel/XDK/bin/xdk-node /home/hpandelo/Softwares/intel/XDK/bin/node-core
server:editor-node:[2016-03-31T10:59:51.222Z]: (1459421991222): Brackets node is running on port 42071
xdk:server:[2016-03-31T10:59:51.223Z]: (1459421991223): Component "server:editor-node" finished delayed initialization
xdk:server:[2016-03-31T10:59:51.224Z]: (1459421991224): Component "server:ui-builder" calling start()
xdk:server:[2016-03-31T10:59:51.227Z]: (1459421991227): Component "server:ui-builder" finished start()
xdk:server:[2016-03-31T10:59:51.227Z]: (1459421991227): Component "server:emulator-webserver" calling start()
xdk:server:[2016-03-31T10:59:51.227Z]: (1459421991227): Component "server:emulator-webserver" finished start()
xdk:server:[2016-03-31T10:59:51.227Z]: (1459421991227): Component "server:editor-node" calling start()
xdk:server:[2016-03-31T10:59:51.227Z]: (1459421991227): Component "server:editor-node" finished start()
xdk:server:[2016-03-31T10:59:51.229Z]: (1459421991229): Intel XDK is initialized now
xdk:server:[2016-03-31T10:59:51.230Z]: (1459421991230): Writing to the server data file
xdk:server:[2016-03-31T10:59:51.232Z]: (1459421991232): Wrote server data to "/root/.config/XDK/server-data.txt"
xdk:client:[2016-03-31T10:59:51.362Z]: (1459421991362): Successfully read server data file
xdk:client:[2016-03-31T10:59:51.541Z]: (1459421991541): Component "core:assert" starting import
xdk:client:[2016-03-31T10:59:51.541Z]: (1459421991541): Component "core:assert" finished initialization
xdk:client:[2016-03-31T10:59:51.541Z]: (1459421991541): Component "core:component-error" starting import
xdk:client:[2016-03-31T10:59:51.541Z]: (1459421991541): Component "core:component-error" finished initialization
xdk:client:[2016-03-31T10:59:51.541Z]: (1459421991541): Component "core:command-line-options" starting import
xdk:client:[2016-03-31T10:59:51.541Z]: (1459421991541): Component "core:command-line-options" finished initialization
xdk:client:[2016-03-31T10:59:51.541Z]: (1459421991541): Component "core:service-error" starting import
xdk:client:[2016-03-31T10:59:51.541Z]: (1459421991541): Component "core:service-error" finished initialization
xdk:client:[2016-03-31T10:59:51.541Z]: (1459421991541): Component "core:buffer" starting import
xdk:client:[2016-03-31T10:59:51.542Z]: (1459421991542): Component "core:buffer" finished initialization
xdk:client:[2016-03-31T10:59:51.542Z]: (1459421991542): Component "core:signaler" starting import
xdk:client:[2016-03-31T10:59:51.542Z]: (1459421991542): Component "core:signaler" finished initialization
xdk:client:[2016-03-31T10:59:51.542Z]: (1459421991542): Component "core:signaler-group" starting import
xdk:client:[2016-03-31T10:59:51.543Z]: (1459421991543): Component "core:signaler-group" finished initialization
xdk:client:[2016-03-31T10:59:51.543Z]: (1459421991543): Component "core:logger" starting import
xdk:client:[2016-03-31T10:59:51.544Z]: (1459421991544): Component "core:logger" finished initialization
xdk:client:[2016-03-31T10:59:51.544Z]: (1459421991544): Component "core:http-request" starting import
xdk:client:[2016-03-31T10:59:51.545Z]: (1459421991545): Component "core:http-request" finished initialization
xdk:client:[2016-03-31T10:59:51.545Z]: (1459421991545): Component "core:version" starting import
xdk:client:[2016-03-31T10:59:51.545Z]: (1459421991545): Component "core:version" finished initialization
xdk:client:[2016-03-31T10:59:51.545Z]: (1459421991545): Component "core:exit-notifier" starting import
xdk:client:[2016-03-31T10:59:51.545Z]: (1459421991545): Component "core:exit-notifier" finished initialization
xdk:client:[2016-03-31T10:59:51.545Z]: (1459421991545): Component "core:userfs-name-converter" starting import
xdk:client:[2016-03-31T10:59:51.545Z]: (1459421991545): Component "core:userfs-name-converter" finished initialization
xdk:client:[2016-03-31T10:59:51.545Z]: (1459421991545): Component "core:crash-handler" starting import
xdk:client:[2016-03-31T10:59:51.546Z]: (1459421991546): Component "core:crash-handler" finished initialization
xdk:client:[2016-03-31T10:59:51.546Z]: (1459421991546): Component "core:analytics" starting import
xdk:client:[2016-03-31T10:59:51.546Z]: (1459421991546): Component "core:analytics" finished initialization
xdk:client:[2016-03-31T10:59:51.546Z]: (1459421991546): Component "core:i18n-support" starting import
xdk:client:[2016-03-31T10:59:51.546Z]: (1459421991546): Component "core:i18n-support" finished initialization
xdk:client:[2016-03-31T10:59:51.546Z]: (1459421991546): Component "core:theme" starting import
xdk:client:[2016-03-31T10:59:51.546Z]: (1459421991546): Component "core:theme" finished initialization
xdk:client:[2016-03-31T10:59:51.553Z]: (1459421991554): Analytics ID: 347a3685-e4bd-469b-a957-c41639b84a61
xdk:client:[2016-03-31T10:59:51.555Z]: (1459421991555): onExit listener 0:
at Object.exports.onExit (/home/hpandelo/Softwares/intel/XDK/xdk/core-modules/public/exit-notifier.js:17:2339)
at setupDefaultAnalytics (/home/hpandelo/Softwares/intel/XDK/xdk/core-modules/public/analytics.js:17:1438)
at /home/hpandelo/Softwares/intel/XDK/xdk/core-modules/public/analytics.js:17:6219
at /home/hpandelo/Softwares/intel/XDK/xdk/node_modules/q/q.js:1229:26
at _fulfilled (/home/hpandelo/Softwares/intel/XDK/xdk/node_modules/q/q.js:834:54)
at self.promiseDispatch.done (/home/hpandelo/Softwares/intel/XDK/xdk/node_modules/q/q.js:863:30)
at Promise.promise.promiseDispatch (/home/hpandelo/Softwares/intel/XDK/xdk/node_modules/q/q.js:796:13)
at /home/hpandelo/Softwares/intel/XDK/xdk/node_modules/q/q.js:604:44
at runSingle (/home/hpandelo/Softwares/intel/XDK/xdk/node_modules/q/q.js:137:13)
xdk:client:[2016-03-31T10:59:51.588Z]: (1459421991588): Component "client:app" starting import
xdk:client:[2016-03-31T10:59:51.589Z]: (1459421991589): Component "client:help-helper" starting import
xdk:client:[2016-03-31T10:59:51.589Z]: (1459421991589): Component "client:nativefs" starting import
xdk:client:[2016-03-31T10:59:51.589Z]: (1459421991589): Component "client:document-manager" starting import
xdk:client:[2016-03-31T10:59:51.589Z]: (1459421991589): Component "client:project-manager" starting import
xdk:client:[2016-03-31T10:59:51.589Z]: (1459421991589): Component "client:aa-controller" starting import
xdk:client:[2016-03-31T10:59:51.589Z]: (1459421991589): Component "client:build-validator" starting import
xdk:client:[2016-03-31T10:59:51.589Z]: (1459421991589): Component "client:projects-renderers" starting import
xdk:client:[2016-03-31T10:59:51.589Z]: (1459421991589): Component "client:projects-renderers-jsapp" starting import
xdk:client:[2016-03-31T10:59:51.589Z]: (1459421991589): Component "client:projects-renderers-webapp" starting import
xdk:client:[2016-03-31T10:59:51.589Z]: (1459421991589): Component "client:projects-renderers-iotapp" starting import
xdk:client:[2016-03-31T10:59:51.589Z]: (1459421991589): Component "client:active-sync" starting import
xdk:client:[2016-03-31T10:59:51.589Z]: (1459421991589): Component "client:apk-installer" starting import
xdk:client:[2016-03-31T10:59:51.589Z]: (1459421991589): Component "client:appcenter-options" starting import
xdk:client:[2016-03-31T10:59:51.589Z]: (1459421991589): Component "client:resource-manager" starting import
xdk:client:[2016-03-31T10:59:51.589Z]: (1459421991589): Component "client:resource-cocos2d" starting import
xdk:client:[2016-03-31T10:59:51.590Z]: (1459421991590): Component "client:resource-cocos2djs" starting import
xdk:client:[2016-03-31T10:59:51.590Z]: (1459421991590): Component "client:resource-phaser" starting import
xdk:client:[2016-03-31T10:59:51.590Z]: (1459421991590): Component "client:resource-pixi" starting import
xdk:client:[2016-03-31T10:59:51.590Z]: (1459421991590): Component "client:resource-easeljs" starting import
xdk:client:[2016-03-31T10:59:51.590Z]: (1459421991590): Component "client:resource-plain" starting import
xdk:client:[2016-03-31T10:59:51.590Z]: (1459421991590): Component "client:resource-render-frame" starting import
xdk:client:[2016-03-31T10:59:51.590Z]: (1459421991590): Component "client:resource-util" starting import
xdk:client:[2016-03-31T10:59:51.590Z]: (1459421991590): Component "client:bower-package-manager" starting import
xdk:client:[2016-03-31T10:59:51.590Z]: (1459421991590): Component "client:services-tab" starting import
xdk:client:[2016-03-31T10:59:51.590Z]: (1459421991590): Component "client:editor" starting import
xdk:client:[2016-03-31T10:59:51.590Z]: (1459421991590): Component "client:live-preview" starting import
xdk:client:[2016-03-31T10:59:51.590Z]: (1459421991590): Component "client:backend-services" starting import
xdk:client:[2016-03-31T10:59:51.590Z]: (1459421991590): Component "client:backend-feeds" starting import
xdk:client:[2016-03-31T10:59:51.590Z]: (1459421991590): Component "client:merged-feed" starting import
xdk:client:[2016-03-31T10:59:51.590Z]: (1459421991590): Component "client:backend-services-ext" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:backend-service-utils" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:cert-manager" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:account-settings" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:ui-builder-client" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:project-meta" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:contenttype-registry" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:editor-registry" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:platform-registry" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:projecttype-registry" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:library-registry" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:cordova-registry" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:service-method" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:settings-db" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:adb" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:iosdb" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:device" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:device-discovery" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:dialog-box" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:test-local-server" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:quick-tour" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:hot-keys" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:persistance" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:tabs" starting import
xdk:client:[2016-03-31T10:59:51.592Z]: (1459421991592): Component "client:hash-utils" starting import
xdk:client:[2016-03-31T10:59:51.592Z]: (1459421991592): Component "client:file-watcher" starting import
xdk:client:[2016-03-31T10:59:51.592Z]: (1459421991592): Component "client:tool-tip" starting import
xdk:client:[2016-03-31T10:59:51.592Z]: (1459421991592): Component "client:cordova" starting import
xdk:client:[2016-03-31T10:59:51.592Z]: (1459421991592): Component "client:settings-ui" starting import
xdk:client:[2016-03-31T10:59:51.592Z]: (1459421991592): Component "client:external-links" starting import
xdk:client:[2016-03-31T10:59:51.592Z]: (1459421991592): Component "client:external-editors-runner" starting import
xdk:client:[2016-03-31T10:59:51.592Z]: (1459421991592): Component "client:project-list-load" starting import
xdk:client:[2016-03-31T10:59:51.592Z]: (1459421991592): Component "client:upload-manager" starting import
xdk:client:[2016-03-31T10:59:51.592Z]: (1459421991592): Component "client:git-manager" starting import
xdk:client:[2016-03-31T10:59:51.592Z]: (1459421991592): Component "client:new-project-creator" starting import
xdk:client:[2016-03-31T10:59:51.621Z]: (1459421991621): Component "client:help-helper" finished initialization
xdk:client:[2016-03-31T10:59:51.622Z]: (1459421991622): Component "client:nativefs" finished initialization
xdk:client:[2016-03-31T10:59:51.636Z]: (1459421991636): Component "client:active-sync" calling init()
xdk:client:[2016-03-31T10:59:51.636Z]: (1459421991636): Component "client:active-sync" finished initialization
xdk:client:[2016-03-31T10:59:51.637Z]: (1459421991637): Component "client:apk-installer" calling init()
xdk:client:[2016-03-31T10:59:51.637Z]: (1459421991637): Component "client:apk-installer" finished initialization
xdk:client:[2016-03-31T10:59:51.648Z]: (1459421991648): Component "client:resource-render-frame" calling init()
xdk:client:[2016-03-31T10:59:51.649Z]: (1459421991649): Component "client:resource-render-frame" waiting for delayed initialization
xdk:client:[2016-03-31T10:59:51.649Z]: (1459421991649): Component "client:resource-util" calling init()
xdk:client:[2016-03-31T10:59:51.649Z]: (1459421991649): Component "client:resource-util" finished initialization
xdk:client:[2016-03-31T10:59:51.652Z]: (1459421991652): Component "client:resource-render-frame" finished delayed initialization
xdk:client:[2016-03-31T10:59:51.658Z]: (1459421991658): Component "client:build-validator" finished initialization
xdk:client:[2016-03-31T10:59:51.665Z]: (1459421991665): Component "client:backend-services" calling init()
xdk:client:[2016-03-31T10:59:51.666Z]: (1459421991666): Component "client:backend-services" finished initialization
xdk:client:[2016-03-31T10:59:51.667Z]: (1459421991667): Component "client:backend-feeds" calling init()
xdk:client:[2016-03-31T10:59:51.667Z]: (1459421991667): Component "client:backend-feeds" finished initialization
xdk:client:[2016-03-31T10:59:51.669Z]: (1459421991669): Component "client:merged-feed" finished initialization
xdk:client:[2016-03-31T10:59:51.670Z]: (1459421991670): Component "client:backend-services-ext" calling init()
xdk:client:[2016-03-31T10:59:51.670Z]: (1459421991670): Component "client:backend-services-ext" finished initialization
xdk:client:[2016-03-31T10:59:51.670Z]: (1459421991670): Component "client:backend-service-utils" finished initialization
xdk:client:[2016-03-31T10:59:51.675Z]: (1459421991675): Component "client:project-meta" calling init()
xdk:client:[2016-03-31T10:59:51.675Z]: (1459421991675): Component "client:project-meta" finished initialization
xdk:client:[2016-03-31T10:59:51.681Z]: (1459421991681): Component "client:service-method" finished initialization
xdk:client:[2016-03-31T10:59:51.683Z]: (1459421991683): Component "client:settings-db" calling init()
xdk:client:[2016-03-31T10:59:51.683Z]: (1459421991683): Component "client:settings-db" waiting for delayed initialization
xdk:client:[2016-03-31T10:59:51.684Z]: (1459421991684): Component "client:adb" calling init()
xdk:client:[2016-03-31T10:59:51.689Z]: (1459421991689): Component "client:adb" waiting for delayed initialization
xdk:client:[2016-03-31T10:59:51.690Z]: (1459421991691): Component "client:iosdb" calling init()
xdk:client:[2016-03-31T10:59:51.691Z]: (1459421991691): Component "client:iosdb" finished initialization
xdk:client:[2016-03-31T10:59:51.701Z]: (1459421991701): Component "client:persistance" calling init()
xdk:client:[2016-03-31T10:59:51.702Z]: (1459421991702): Component "client:persistance" waiting for delayed initialization
xdk:client:[2016-03-31T10:59:51.705Z]: (1459421991705): Component "client:file-watcher" calling init()
xdk:client:[2016-03-31T10:59:51.705Z]: (1459421991705): Component "client:file-watcher" finished initialization
xdk:client:[2016-03-31T10:59:51.708Z]: (1459421991708): Component "client:external-links" finished initialization
xdk:client:[2016-03-31T10:59:51.709Z]: (1459421991709): Component "client:external-editors-runner" calling init()
xdk:client:[2016-03-31T10:59:51.710Z]: (1459421991710): Component "client:external-editors-runner" finished initialization
xdk:client:[2016-03-31T10:59:51.710Z]: (1459421991710): Component "client:project-list-load" calling init()
xdk:client:[2016-03-31T10:59:51.710Z]: (1459421991710): Component "client:project-list-load" waiting for delayed initialization
xdk:client:[2016-03-31T10:59:51.714Z]: (1459421991714): Component "client:upload-manager" calling init()
xdk:client:[2016-03-31T10:59:51.714Z]: (1459421991714): Component "client:upload-manager" finished initialization
xdk:client:[2016-03-31T10:59:51.715Z]: (1459421991715): Component "client:git-manager" calling init()
client:git-manager:[2016-03-31T10:59:51.715Z]: (1459421991715): git path = /usr/bin/git
xdk:client:[2016-03-31T10:59:51.715Z]: (1459421991715): Component "client:git-manager" waiting for delayed initialization
xdk:client:[2016-03-31T10:59:51.717Z]: (1459421991717): Component "client:new-project-creator" calling init()
xdk:client:[2016-03-31T10:59:51.717Z]: (1459421991717): Component "client:new-project-creator" finished initialization
xdk:client:[2016-03-31T10:59:51.728Z]: (1459421991728): Component "client:hot-keys" calling init()
xdk:client:[2016-03-31T10:59:51.728Z]: (1459421991728): Component "client:hot-keys" finished initialization
xdk:client:[2016-03-31T10:59:51.731Z]: (1459421991731): Component "client:document-manager" calling init()
xdk:client:[2016-03-31T10:59:51.732Z]: (1459421991732): Component "client:document-manager" finished initialization
xdk:client:[2016-03-31T10:59:51.752Z]: (1459421991752): Component "client:aa-controller" calling init()
xdk:client:[2016-03-31T10:59:51.752Z]: (1459421991752): Component "client:aa-controller" finished initialization
xdk:client:[2016-03-31T10:59:51.800Z]: (1459421991800): Component "client:ui-builder-client" calling init()
xdk:client:[2016-03-31T10:59:51.800Z]: (1459421991800): Component "client:ui-builder-client" finished initialization
xdk:client:[2016-03-31T10:59:51.803Z]: (1459421991803): Component "client:dialog-box" finished initialization
xdk:client:[2016-03-31T10:59:51.808Z]: (1459421991808): Component "client:tool-tip" finished initialization
xdk:client:[2016-03-31T10:59:51.810Z]: (1459421991810): Component "client:settings-ui" finished initialization
xdk:client:[2016-03-31T10:59:51.828Z]: (1459421991828): Component "client:resource-manager" calling init()
xdk:client:[2016-03-31T10:59:51.829Z]: (1459421991829): Component "client:resource-manager" waiting for delayed initialization
xdk:client:[2016-03-31T10:59:51.839Z]: (1459421991839): Component "client:resource-cocos2djs" calling init()
xdk:client:[2016-03-31T10:59:51.839Z]: (1459421991839): Component "client:resource-cocos2djs" finished initialization
xdk:client:[2016-03-31T10:59:51.866Z]: (1459421991866): Component "client:appcenter-options" calling init()
xdk:client:[2016-03-31T10:59:51.866Z]: (1459421991866): Component "client:appcenter-options" waiting for delayed initialization
xdk:client:[2016-03-31T10:59:51.868Z]: (1459421991868): Component "client:test-local-server" calling init()
xdk:client:[2016-03-31T10:59:51.893Z]: (1459421991893): Component "client:test-local-server" finished initialization
xdk:client:[2016-03-31T10:59:51.894Z]: (1459421991894): Component "client:tabs" finished initialization
xdk:client:[2016-03-31T10:59:51.972Z]: (1459421991972): Component "client:cert-manager" finished initialization
xdk:client:[2016-03-31T10:59:51.978Z]: (1459421991978): Component "client:app" calling init()
xdk:client:[2016-03-31T10:59:51.993Z]: (1459421991993): Component "client:app" finished initialization
xdk:client:[2016-03-31T10:59:51.998Z]: (1459421991998): Component "client:services-tab" calling init()
xdk:client:[2016-03-31T10:59:51.998Z]: (1459421991998): Component "client:services-tab" finished initialization
xdk:client:[2016-03-31T10:59:52.005Z]: (1459421992005): Component "client:contenttype-registry" calling init()
xdk:client:[2016-03-31T10:59:52.006Z]: (1459421992006): Component "client:contenttype-registry" finished initialization
xdk:client:[2016-03-31T10:59:52.007Z]: (1459421992007): Component "client:editor-registry" finished initialization
xdk:client:[2016-03-31T10:59:52.013Z]: (1459421992013): Component "client:library-registry" calling init()
xdk:client:[2016-03-31T10:59:52.013Z]: (1459421992013): Component "client:library-registry" finished initialization
xdk:client:[2016-03-31T10:59:52.023Z]: (1459421992023): Component "client:device-discovery" calling init()
xdk:client:[2016-03-31T10:59:52.023Z]: (1459421992023): Component "client:device-discovery" waiting for delayed initialization
xdk:client:[2016-03-31T10:59:52.025Z]: (1459421992025): Component "client:hash-utils" finished initialization
xdk:client:[2016-03-31T10:59:52.074Z]: (1459421992074): Component "client:cordova" calling init()
xdk:client:[2016-03-31T10:59:52.075Z]: (1459421992075): Component "client:cordova" waiting for delayed initialization
xdk:client:[2016-03-31T10:59:52.088Z]: (1459421992088): Component "client:project-manager" calling init()
xdk:client:[2016-03-31T10:59:52.088Z]: (1459421992089): Component "client:project-manager" waiting for delayed initialization
xdk:client:[2016-03-31T10:59:52.094Z]: (1459421992095): Component "client:projects-renderers" calling init()
xdk:client:[2016-03-31T10:59:52.095Z]: (1459421992095): Component "client:projects-renderers" waiting for delayed initialization
xdk:client:[2016-03-31T10:59:52.096Z]: (1459421992096): Component "client:projects-renderers-iotapp" calling init()
xdk:client:[2016-03-31T10:59:52.096Z]: (1459421992096): Component "client:projects-renderers-iotapp" finished initialization
xdk:client:[2016-03-31T10:59:52.108Z]: (1459421992108): Component "client:resource-cocos2d" calling init()
xdk:client:[2016-03-31T10:59:52.108Z]: (1459421992108): Component "client:resource-cocos2d" waiting for delayed initialization
xdk:client:[2016-03-31T10:59:52.110Z]: (1459421992110): Component "client:navbar" starting import
xdk:client:[2016-03-31T10:59:52.110Z]: (1459421992110): Component "client:tweets" starting import
xdk:client:[2016-03-31T10:59:52.111Z]: (1459421992111): Component "client:projects-tab" starting import
xdk:client:[2016-03-31T10:59:52.111Z]: (1459421992111): Component "client:test-tab" starting import
xdk:client:[2016-03-31T10:59:52.111Z]: (1459421992111): Component "client:profilingTab" starting import
xdk:client:[2016-03-31T10:59:52.111Z]: (1459421992111): Component "client:emulator" starting import
xdk:client:[2016-03-31T10:59:52.111Z]: (1459421992111): Component "client:remote-tab" starting import
xdk:client:[2016-03-31T10:59:52.111Z]: (1459421992111): Component "client:build-tab" starting import
xdk:client:[2016-03-31T10:59:52.111Z]: (1459421992111): Component "client:build-service" starting import
xdk:client:[2016-03-31T10:59:52.111Z]: (1459421992111): Component "client:bower-client" starting import
xdk:client:[2016-03-31T10:59:52.111Z]: (1459421992111): Component "client:editor-tab" starting import
xdk:client:[2016-03-31T10:59:52.111Z]: (1459421992111): Component "client:account" starting import
xdk:client:[2016-03-31T10:59:52.111Z]: (1459421992111): Component "client:project-selector" starting import
xdk:client:[2016-03-31T10:59:52.111Z]: (1459421992111): Component "client:publish-tab" starting import
xdk:client:[2016-03-31T10:59:52.116Z]: (1459421992116): Component "client:resource-cocos2d" finished delayed initialization
xdk:client:[2016-03-31T10:59:52.124Z]: (1459421992124): Component "client:resource-phaser" calling init()
xdk:client:[2016-03-31T10:59:52.124Z]: (1459421992124): Component "client:resource-phaser" finished initialization
xdk:client:[2016-03-31T10:59:52.127Z]: (1459421992127): Component "client:resource-pixi" calling init()
xdk:client:[2016-03-31T10:59:52.127Z]: (1459421992127): Component "client:resource-pixi" finished initialization
xdk:client:[2016-03-31T10:59:52.128Z]: (1459421992128): Component "client:resource-easeljs" calling init()
xdk:client:[2016-03-31T10:59:52.128Z]: (1459421992128): Component "client:resource-easeljs" finished initialization
xdk:client:[2016-03-31T10:59:52.129Z]: (1459421992129): Component "client:resource-plain" calling init()
xdk:client:[2016-03-31T10:59:52.129Z]: (1459421992129): Component "client:resource-plain" finished initialization
xdk:client:[2016-03-31T10:59:52.134Z]: (1459421992134): Component "client:cordova-registry" calling init()
xdk:client:[2016-03-31T10:59:52.134Z]: (1459421992134): Component "client:cordova-registry" waiting for delayed initialization
xdk:client:[2016-03-31T10:59:52.149Z]: (1459421992149): Component "client:quick-tour" calling init()
xdk:client:[2016-03-31T10:59:52.149Z]: (1459421992149): Component "client:quick-tour" finished initialization
xdk:client:[2016-03-31T10:59:52.159Z]: (1459421992159): Component "client:account-settings" calling init()
xdk:client:[2016-03-31T10:59:52.159Z]: (1459421992159): Component "client:account-settings" finished initialization
xdk:client:[2016-03-31T10:59:52.163Z]: (1459421992163): Component "client:platform-registry" calling init()
xdk:client:[2016-03-31T10:59:52.164Z]: (1459421992164): Component "client:platform-registry" finished initialization
xdk:client:[2016-03-31T10:59:52.166Z]: (1459421992166): Component "client:projecttype-registry" calling init()
xdk:client:[2016-03-31T10:59:52.167Z]: (1459421992167): Component "client:projecttype-registry" finished initialization
xdk:client:[2016-03-31T10:59:52.172Z]: (1459421992172): Component "client:device" calling init()
ios-device:[2016-03-31T10:59:52.218Z]: (1459421992218): Failed to initialize libwi due to Dynamic Linking Error: libssl.so.1.0.0: cannot open shared object file: Arquivo ou diretório não encontrado
xdk:client:[2016-03-31T10:59:52.218Z]: (1459421992218): Component "client:device" finished initialization
xdk:client:[2016-03-31T10:59:52.224Z]: (1459421992224): Component "client:device-discovery" finished delayed initialization
xdk:client:[2016-03-31T10:59:52.225Z]: (1459421992225): Component "client:settings-db" finished delayed initialization
client:git-manager:[2016-03-31T10:59:52.253Z]: (1459421992253): Custom Git Client Path is /usr/bin/git
client:git-manager:[2016-03-31T10:59:52.253Z]: (1459421992253): Auto-Proxy setting is true
xdk:client:[2016-03-31T10:59:52.284Z]: (1459421992284): Component "client:bower-package-manager" calling init()
xdk:client:[2016-03-31T10:59:52.285Z]: (1459421992285): Component "client:bower-package-manager" waiting for delayed initialization
xdk:client:[2016-03-31T10:59:52.286Z]: (1459421992286): Component "client:bower-package-manager" finished delayed initialization
xdk:client:[2016-03-31T10:59:52.316Z]: (1459421992316): Component "client:projects-renderers-webapp" calling init()
xdk:client:[2016-03-31T10:59:52.317Z]: (1459421992317): Component "client:projects-renderers-webapp" finished initialization
xdk:client:[2016-03-31T10:59:52.325Z]: (1459421992325): Component "client:projects-renderers-jsapp" calling init()
xdk:client:[2016-03-31T10:59:52.326Z]: (1459421992326): Component "client:projects-renderers-jsapp" finished initialization
xdk:client:[2016-03-31T10:59:52.345Z]: (1459421992345): Component "client:build-service" getting UI region for "build"
xdk:client:[2016-03-31T10:59:52.346Z]: (1459421992346): Component "client:build-service" calling init()
xdk:client:[2016-03-31T10:59:52.346Z]: (1459421992346): Component "client:build-service" finished initialization
xdk:client:[2016-03-31T10:59:52.368Z]: (1459421992368): Component "client:projects-renderers" finished delayed initialization
xdk:client:[2016-03-31T10:59:52.373Z]: (1459421992373): Component "client:git-manager" finished delayed initialization
xdk:client:[2016-03-31T10:59:52.395Z]: (1459421992395): Component "client:account" getting UI region for "account"
xdk:client:[2016-03-31T10:59:52.396Z]: (1459421992396): Component "client:account" calling init()
xdk:client:[2016-03-31T10:59:52.402Z]: (1459421992402): Component "client:account" finished initialization
xdk:client:[2016-03-31T10:59:52.404Z]: (1459421992404): Component "client:project-selector" getting UI region for "project-selector"
xdk:client:[2016-03-31T10:59:52.405Z]: (1459421992405): Component "client:project-selector" calling init()
xdk:client:[2016-03-31T10:59:52.405Z]: (1459421992405): Component "client:project-selector" finished initialization
xdk:client:[2016-03-31T10:59:52.422Z]: (1459421992422): Component "client:editor" calling init()
xdk:client:[2016-03-31T10:59:52.422Z]: (1459421992422): Component "client:editor" finished initialization
xdk:client:[2016-03-31T10:59:52.423Z]: (1459421992423): Component "client:live-preview" calling init()
xdk:client:[2016-03-31T10:59:52.423Z]: (1459421992423): Component "client:live-preview" finished initialization
xdk:client:[2016-03-31T10:59:52.423Z]: (1459421992423): Component "client:editor-tab" getting UI region for "develop"
xdk:client:[2016-03-31T10:59:52.423Z]: (1459421992423): Component "client:editor-tab" calling init()
xdk:client:[2016-03-31T10:59:52.436Z]: (1459421992436): Component "client:editor-tab" waiting for delayed initialization
xdk:client:[2016-03-31T10:59:52.442Z]: (1459421992442): Component "client:tweets" finished initialization
xdk:client:[2016-03-31T10:59:52.443Z]: (1459421992443): Component "client:projects-tab" getting UI region for "project"
xdk:client:[2016-03-31T10:59:52.443Z]: (1459421992443): Component "client:projects-tab" calling init()
xdk:client:[2016-03-31T10:59:52.445Z]: (1459421992445): Component "client:projects-tab" waiting for delayed initialization
xdk:client:[2016-03-31T10:59:52.447Z]: (1459421992447): Component "client:test-tab" getting UI region for "test"
xdk:client:[2016-03-31T10:59:52.447Z]: (1459421992447): Component "client:test-tab" calling init()
xdk:client:[2016-03-31T10:59:52.448Z]: (1459421992448): Component "client:test-tab" waiting for delayed initialization
xdk:client:[2016-03-31T10:59:52.465Z]: (1459421992465): Component "client:emulator" getting UI region for "emulate"
xdk:client:[2016-03-31T10:59:52.465Z]: (1459421992465): Component "client:emulator" calling init()
xdk:client:[2016-03-31T10:59:52.469Z]: (1459421992469): Component "client:emulator" finished initialization
xdk:client:[2016-03-31T10:59:52.478Z]: (1459421992478): Component "client:remote-tab" getting UI region for "debug"
xdk:client:[2016-03-31T10:59:52.478Z]: (1459421992478): Component "client:remote-tab" calling init()
xdk:client:[2016-03-31T10:59:52.591Z]: (1459421992591): Component "client:remote-tab" waiting for delayed initialization
xdk:client:[2016-03-31T10:59:52.616Z]: (1459421992616): Component "client:remote-tab" finished delayed initialization
xdk:client:[2016-03-31T10:59:52.619Z]: (1459421992619): Component "client:cordova" finished delayed initialization
xdk:client:[2016-03-31T10:59:52.623Z]: (1459421992623): Component "client:navbar" getting UI region for "navbar-common"
xdk:client:[2016-03-31T10:59:52.623Z]: (1459421992623): Component "client:navbar" calling init()
client:navbar:[2016-03-31T10:59:52.623Z]: (1459421992623): navbar options: {"common":{"servicesVersion":"release-2016-ww11"},"updatePollingInterval":1800,"forceUpdate":false}
xdk:client:[2016-03-31T10:59:52.623Z]: (1459421992623): Component "client:navbar" finished initialization
xdk:client:[2016-03-31T10:59:52.641Z]: (1459421992641): Component "client:build-tab" getting UI region for "build"
xdk:client:[2016-03-31T10:59:52.641Z]: (1459421992641): Component "client:build-tab" calling init()
xdk:client:[2016-03-31T10:59:52.647Z]: (1459421992647): Component "client:build-tab" waiting for delayed initialization
xdk:client:[2016-03-31T10:59:52.654Z]: (1459421992654): Component "client:publish-tab" getting UI region for "publish"
xdk:client:[2016-03-31T10:59:52.654Z]: (1459421992654): Component "client:publish-tab" calling init()
xdk:client:[2016-03-31T10:59:52.662Z]: (1459421992662): Component "client:build-tab" finished delayed initialization
xdk:client:[2016-03-31T10:59:52.663Z]: (1459421992663): Component "client:publish-tab" finished initialization
xdk:client:[2016-03-31T10:59:52.684Z]: (1459421992684): Component "client:bower-client" getting UI region for "deps-manager"
xdk:client:[2016-03-31T10:59:52.684Z]: (1459421992684): Component "client:bower-client" calling init()
xdk:client:[2016-03-31T10:59:52.686Z]: (1459421992686): Component "client:bower-client" finished initialization
xdk:client:[2016-03-31T10:59:52.762Z]: (1459421992762): Component "client:profilingTab" getting UI region for "profile"
xdk:client:[2016-03-31T10:59:52.762Z]: (1459421992762): Component "client:profilingTab" calling init()
xdk:client:[2016-03-31T10:59:52.766Z]: (1459421992766): Component "client:profilingTab" finished initialization
client:appcenter-options:[2016-03-31T10:59:53.618Z]: (1459421993618): Fetch Status: 1, Message: Feched latest appcenter-options info because network is available.
xdk:client:[2016-03-31T10:59:53.619Z]: (1459421993619): Component "client:appcenter-options" finished delayed initialization
xdk:client:[2016-03-31T10:59:53.621Z]: (1459421993621): Component "client:test-tab" finished delayed initialization
xdk:client:[2016-03-31T10:59:53.769Z]: (1459421993769): Component "client:cordova-registry" finished delayed initialization
xdk:client:[2016-03-31T10:59:54.209Z]: (1459421994209): memmrk: 48795056 76273264
client:adb:[2016-03-31T10:59:54.391Z]: (1459421994391): Using existing adb at "/home/hpandelo/Softwares/intel/XDK/bin/adb/adb"
xdk:client:[2016-03-31T10:59:54.399Z]: (1459421994399): Component "client:adb" finished delayed initialization
xdk:client:[2016-03-31T10:59:55.024Z]: (1459421995024): Component "client:persistance" finished delayed initialization
xdk:server:[2016-03-31T10:59:55.049Z]: (1459421995049): memmrk: 39326640 69612936
xdk:client:[2016-03-31T10:59:55.229Z]: (1459421995229): Component "client:project-manager" finished delayed initialization
xdk:client:[2016-03-31T10:59:55.230Z]: (1459421995230): Component "client:project-list-load" finished delayed initialization
xdk:client:[2016-03-31T10:59:55.235Z]: (1459421995235): Component "client:resource-manager" finished delayed initialization
xdk:client:[2016-03-31T10:59:55.235Z]: (1459421995235): Component "client:projects-tab" finished delayed initialization
xdk:client:[2016-03-31T10:59:55.235Z]: (1459421995235): Component "client:projects-list" starting import
xdk:client:[2016-03-31T10:59:55.235Z]: (1459421995235): Component "client:projects-info" starting import
xdk:client:[2016-03-31T10:59:55.236Z]: (1459421995236): Component "client:projects-create-list" starting import
xdk:client:[2016-03-31T10:59:55.236Z]: (1459421995236): Component "client:projects-create-info" starting import
xdk:client:[2016-03-31T10:59:56.055Z]: (1459421996055): Component "client:projects-list" getting UI region for "existing-list"
xdk:client:[2016-03-31T10:59:56.055Z]: (1459421996055): Component "client:projects-list" calling init()
xdk:client:[2016-03-31T10:59:56.057Z]: (1459421996057): Component "client:projects-list" finished initialization
xdk:client:[2016-03-31T10:59:56.059Z]: (1459421996059): Component "client:projects-info" getting UI region for "existing-info"
xdk:client:[2016-03-31T10:59:56.059Z]: (1459421996059): Component "client:projects-info" calling init()
xdk:client:[2016-03-31T10:59:56.059Z]: (1459421996059): Component "client:projects-info" finished initialization
xdk:client:[2016-03-31T10:59:56.066Z]: (1459421996066): Component "client:projects-create-info" getting UI region for "create-info"
xdk:client:[2016-03-31T10:59:56.066Z]: (1459421996066): Component "client:projects-create-info" calling init()
xdk:client:[2016-03-31T10:59:56.066Z]: (1459421996066): Component "client:projects-create-info" finished initialization
xdk:client:[2016-03-31T10:59:56.071Z]: (1459421996071): Component "client:projects-create-list" getting UI region for "create-list"
xdk:client:[2016-03-31T10:59:56.071Z]: (1459421996071): Component "client:projects-create-list" calling init()
xdk:client:[2016-03-31T10:59:56.071Z]: (1459421996071): Component "client:projects-create-list" finished initialization
xdk:client:[2016-03-31T11:00:00.041Z]: (1459422000041): memmrk: 55434648 92493936
xdk:server:[2016-03-31T11:00:00.049Z]: (1459422000049): memmrk: 39505424 69620776
xdk:client:[2016-03-31T11:00:02.169Z]: (1459422002169): onExitRequest listener 1:
at Object.exports.onExitRequest (/home/hpandelo/Softwares/intel/XDK/xdk/core-modules/public/exit-notifier.js:17:2170)
at Object.<anonymous> (file:///home/hpandelo/Softwares/intel/XDK/xdk/brackets/b/extensions/default/XDK/main.js:459:21)
at Object.context.execCb (file:///home/hpandelo/Softwares/intel/XDK/xdk/brackets/b/thirdparty/requirejs/require.js:1658:33)
at Object.Module.check (file:///home/hpandelo/Softwares/intel/XDK/xdk/brackets/b/thirdparty/requirejs/require.js:869:55)
at Object.<anonymous> (file:///home/hpandelo/Softwares/intel/XDK/xdk/brackets/b/thirdparty/requirejs/require.js:1121:34)
at file:///home/hpandelo/Softwares/intel/XDK/xdk/brackets/b/thirdparty/requirejs/require.js:132:23
at file:///home/hpandelo/Softwares/intel/XDK/xdk/brackets/b/thirdparty/requirejs/require.js:1164:21
at each (file:///home/hpandelo/Softwares/intel/XDK/xdk/brackets/b/thirdparty/requirejs/require.js:57:31)
at Object.Module.emit (file:///home/hpandelo/Softwares/intel/XDK/xdk/brackets/b/thirdparty/requirejs/require.js:1163:17)
xdk:client:[2016-03-31T11:00:05.041Z]: (1459422005041): memmrk: 81982296 113429520
xdk:server:[2016-03-31T11:00:05.049Z]: (1459422005049): memmrk: 30233512 70231800
client:services-tab:[2016-03-31T11:00:05.212Z]: (1459422005212): component:services-tab : Container provided by brackets :
client:services-tab:[2016-03-31T11:00:05.212Z]: (1459422005212): component:services-tab : mainContainer_ = XDKMiniServices-main
client:services-tab:[2016-03-31T11:00:05.212Z]: (1459422005212): component:services-tab : sidebarContainer = XDKMiniServices-list
client:services-tab:[2016-03-31T11:00:05.212Z]: (1459422005212): component:services-tab : Iframes inserted by services-tab : .
client:services-tab:[2016-03-31T11:00:05.212Z]: (1459422005212): component:services-tab : $mainContainer_ = mini-api-explorer
client:services-tab:[2016-03-31T11:00:05.212Z]: (1459422005212): component:services-tab : $sidebarContainer_ = api-sidebar
xdk:client:[2016-03-31T11:00:05.291Z]: (1459422005291): Component "client:editor-tab" finished delayed initialization
xdk:client:[2016-03-31T11:00:05.292Z]: (1459422005292): Component "client:app" calling start()
xdk:client:[2016-03-31T11:00:05.306Z]: (1459422005306): Component "client:app" finished start()
xdk:client:[2016-03-31T11:00:05.306Z]: (1459422005306): Component "client:navbar" calling start()
xdk:client:[2016-03-31T11:00:05.321Z]: (1459422005321): Component "client:navbar" finished start()
xdk:client:[2016-03-31T11:00:05.321Z]: (1459422005321): Component "client:project-manager" calling start()
xdk:client:[2016-03-31T11:00:05.321Z]: (1459422005321): Component "client:project-manager" finished start()
xdk:client:[2016-03-31T11:00:05.321Z]: (1459422005321): Component "client:aa-controller" calling start()
xdk:client:[2016-03-31T11:00:05.322Z]: (1459422005322): Component "client:aa-controller" finished start()
xdk:client:[2016-03-31T11:00:05.322Z]: (1459422005322): Component "client:projects-tab" calling start()
xdk:client:[2016-03-31T11:00:05.329Z]: (1459422005329): Component "client:projects-tab" finished start()
xdk:client:[2016-03-31T11:00:05.329Z]: (1459422005329): Component "client:projects-list" calling start()
xdk:client:[2016-03-31T11:00:05.331Z]: (1459422005331): Component "client:projects-list" finished start()
xdk:client:[2016-03-31T11:00:05.331Z]: (1459422005331): Component "client:projects-info" calling start()
xdk:client:[2016-03-31T11:00:05.333Z]: (1459422005333): Component "client:projects-info" finished start()
xdk:client:[2016-03-31T11:00:05.333Z]: (1459422005333): Component "client:projects-create-list" calling start()
xdk:client:[2016-03-31T11:00:05.363Z]: (1459422005363): Component "client:projects-create-list" finished start()
xdk:client:[2016-03-31T11:00:05.363Z]: (1459422005363): Component "client:projects-create-info" calling start()
xdk:client:[2016-03-31T11:00:05.370Z]: (1459422005371): Component "client:projects-create-info" finished start()
xdk:client:[2016-03-31T11:00:05.371Z]: (1459422005371): Component "client:test-tab" calling start()
xdk:client:[2016-03-31T11:00:05.374Z]: (1459422005374): Component "client:test-tab" finished start()
xdk:client:[2016-03-31T11:00:05.374Z]: (1459422005374): Component "client:profilingTab" calling start()
xdk:client:[2016-03-31T11:00:05.416Z]: (1459422005416): Component "client:profilingTab" finished start()
xdk:client:[2016-03-31T11:00:05.416Z]: (1459422005416): Component "client:emulator" calling start()
xdk:client:[2016-03-31T11:00:05.417Z]: (1459422005417): Component "client:emulator" finished start()
xdk:client:[2016-03-31T11:00:05.417Z]: (1459422005417): Component "client:remote-tab" calling start()
xdk:client:[2016-03-31T11:00:05.421Z]: (1459422005421): onExitRequest listener 2:
at Object.myExports.start (file:///home/hpandelo/Softwares/intel/XDK/xdk/components/client/remote-tab/remote-tab.js:20:3484)
at resumeClientInit (/home/hpandelo/Softwares/intel/XDK/xdk/core-modules/private/main.js:17:12040)
at /home/hpandelo/Softwares/intel/XDK/xdk/core-modules/private/main.js:17:1734
xdk:client:[2016-03-31T11:00:05.422Z]: (1459422005422): Component "client:remote-tab" finished start()
xdk:client:[2016-03-31T11:00:05.422Z]: (1459422005422): Component "client:build-tab" calling start()
xdk:client:[2016-03-31T11:00:05.424Z]: (1459422005424): Component "client:build-tab" finished start()
xdk:client:[2016-03-31T11:00:05.424Z]: (1459422005424): Component "client:active-sync" calling start()
xdk:client:[2016-03-31T11:00:05.425Z]: (1459422005425): Component "client:active-sync" finished start()
xdk:client:[2016-03-31T11:00:05.425Z]: (1459422005425): Component "client:apk-installer" calling start()
xdk:client:[2016-03-31T11:00:05.425Z]: (1459422005425): Component "client:apk-installer" finished start()
xdk:client:[2016-03-31T11:00:05.425Z]: (1459422005425): Component "client:resource-manager" calling start()
xdk:client:[2016-03-31T11:00:05.425Z]: (1459422005425): Component "client:resource-manager" finished start()
xdk:client:[2016-03-31T11:00:05.425Z]: (1459422005425): Component "client:resource-cocos2d" calling start()
xdk:client:[2016-03-31T11:00:05.425Z]: (1459422005425): Component "client:resource-cocos2d" finished start()
xdk:client:[2016-03-31T11:00:05.425Z]: (1459422005425): Component "client:resource-cocos2djs" calling start()
xdk:client:[2016-03-31T11:00:05.425Z]: (1459422005425): Component "client:resource-cocos2djs" finished start()
xdk:client:[2016-03-31T11:00:05.425Z]: (1459422005425): Component "client:resource-phaser" calling start()
xdk:client:[2016-03-31T11:00:05.425Z]: (1459422005425): Component "client:resource-phaser" finished start()
xdk:client:[2016-03-31T11:00:05.425Z]: (1459422005425): Component "client:resource-pixi" calling start()
xdk:client:[2016-03-31T11:00:05.425Z]: (1459422005425): Component "client:resource-pixi" finished start()
xdk:client:[2016-03-31T11:00:05.425Z]: (1459422005425): Component "client:resource-easeljs" calling start()
xdk:client:[2016-03-31T11:00:05.425Z]: (1459422005425): Component "client:resource-easeljs" finished start()
xdk:client:[2016-03-31T11:00:05.425Z]: (1459422005425): Component "client:resource-plain" calling start()
xdk:client:[2016-03-31T11:00:05.426Z]: (1459422005426): Component "client:resource-plain" finished start()
xdk:client:[2016-03-31T11:00:05.426Z]: (1459422005426): Component "client:resource-render-frame" calling start()
xdk:client:[2016-03-31T11:00:05.426Z]: (1459422005426): Component "client:resource-render-frame" finished start()
xdk:client:[2016-03-31T11:00:05.426Z]: (1459422005426): Component "client:resource-util" calling start()
xdk:client:[2016-03-31T11:00:05.426Z]: (1459422005426): Component "client:resource-util" finished start()
xdk:client:[2016-03-31T11:00:05.426Z]: (1459422005426): Component "client:bower-client" calling start()
xdk:client:[2016-03-31T11:00:05.426Z]: (1459422005426): Component "client:bower-client" finished start()
xdk:client:[2016-03-31T11:00:05.426Z]: (1459422005426): Component "client:editor" calling start()
xdk:client:[2016-03-31T11:00:05.427Z]: (1459422005427): Component "client:editor" finished start()
xdk:client:[2016-03-31T11:00:05.427Z]: (1459422005427): Component "client:editor-tab" calling start()
xdk:client:[2016-03-31T11:00:05.447Z]: (1459422005447): Component "client:editor-tab" finished start()
xdk:client:[2016-03-31T11:00:05.447Z]: (1459422005447): Component "client:live-preview" calling start()
xdk:client:[2016-03-31T11:00:05.447Z]: (1459422005447): Component "client:live-preview" finished start()
xdk:client:[2016-03-31T11:00:05.447Z]: (1459422005447): Component "client:account" calling start()
xdk:client:[2016-03-31T11:00:05.449Z]: (1459422005449): Component "client:account" finished start()
xdk:client:[2016-03-31T11:00:05.449Z]: (1459422005449): Component "client:project-selector" calling start()
xdk:client:[2016-03-31T11:00:05.451Z]: (1459422005451): Component "client:project-selector" finished start()
xdk:client:[2016-03-31T11:00:05.451Z]: (1459422005451): Component "client:ui-builder-client" calling start()
xdk:client:[2016-03-31T11:00:05.452Z]: (1459422005452): Component "client:ui-builder-client" finished start()
xdk:client:[2016-03-31T11:00:05.452Z]: (1459422005452): Component "client:project-meta" calling start()
xdk:client:[2016-03-31T11:00:05.453Z]: (1459422005453): Component "client:project-meta" finished start()
xdk:client:[2016-03-31T11:00:05.453Z]: (1459422005453): Component "client:cordova-registry" calling start()
xdk:client:[2016-03-31T11:00:05.453Z]: (1459422005453): Component "client:cordova-registry" finished start()
xdk:client:[2016-03-31T11:00:05.453Z]: (1459422005453): Component "client:adb" calling start()
xdk:client:[2016-03-31T11:00:05.453Z]: (1459422005453): Component "client:adb" finished start()
xdk:client:[2016-03-31T11:00:05.453Z]: (1459422005453): Component "client:iosdb" calling start()
xdk:client:[2016-03-31T11:00:05.454Z]: (1459422005454): Component "client:iosdb" finished start()
xdk:client:[2016-03-31T11:00:05.454Z]: (1459422005454): Component "client:device-discovery" calling start()
xdk:client:[2016-03-31T11:00:05.455Z]: (1459422005455): Component "client:device-discovery" threw exception during start()
xdk:client:[2016-03-31T11:00:05.455Z]: (1459422005455): Unexpected exception while initializing "device-discovery" (maybe crash): Error: Dynamic Linking Error: libssl.so.1.0.0: cannot open shared object file: Arquivo ou diretório não encontrado
at new DynamicLibrary (/home/hpandelo/Softwares/intel/XDK/xdk/node_modules/ffi/lib/dynamic_library.js:74:11)
at Object.Library (/home/hpandelo/Softwares/intel/XDK/xdk/node_modules/ffi/lib/library.js:45:12)
at start (file:///home/hpandelo/Softwares/intel/XDK/xdk/components/client/device-discovery/impl/discovery-iosdb.js:17:217)
at file:///home/hpandelo/Softwares/intel/XDK/xdk/components/client/device-discovery/device-discovery.js:17:9939
at Array.map (native)
at Array.impls_.call (file:///home/hpandelo/Softwares/intel/XDK/xdk/components/client/device-discovery/device-discovery.js:17:9879)
at Object.start (file:///home/hpandelo/Softwares/intel/XDK/xdk/components/client/device-discovery/device-discovery.js:17:8460)
xdk:client:[2016-03-31T11:00:05.455Z]: (1459422005455): Component "client:test-local-server" calling start()
xdk:client:[2016-03-31T11:00:05.456Z]: (1459422005456): Component "client:test-local-server" finished start()
xdk:client:[2016-03-31T11:00:05.456Z]: (1459422005456): Component "client:quick-tour" calling start()
xdk:client:[2016-03-31T11:00:05.456Z]: (1459422005456): Component "client:quick-tour" finished start()
xdk:client:[2016-03-31T11:00:05.456Z]: (1459422005456): Component "client:hot-keys" calling start()
xdk:client:[2016-03-31T11:00:05.457Z]: (1459422005457): Component "client:hot-keys" finished start()
xdk:client:[2016-03-31T11:00:05.457Z]: (1459422005457): Component "client:persistance" calling start()
xdk:client:[2016-03-31T11:00:05.458Z]: (1459422005458): onExit listener 3:
at Object.start (file:///home/hpandelo/Softwares/intel/XDK/xdk/components/client/persistance/persistance.js:17:4613)
xdk:client:[2016-03-31T11:00:05.458Z]: (1459422005458): Component "client:persistance" finished start()
xdk:client:[2016-03-31T11:00:05.458Z]: (1459422005458): Component "client:file-watcher" calling start()
xdk:client:[2016-03-31T11:00:05.458Z]: (1459422005458): Component "client:file-watcher" finished start()
xdk:client:[2016-03-31T11:00:05.458Z]: (1459422005458): Component "client:cordova" calling start()
xdk:client:[2016-03-31T11:00:05.458Z]: (1459422005458): Component "client:cordova" finished start()
xdk:client:[2016-03-31T11:00:05.458Z]: (1459422005458): Component "client:external-editors-runner" calling start()
xdk:client:[2016-03-31T11:00:05.459Z]: (1459422005459): Component "client:external-editors-runner" finished start()
xdk:client:[2016-03-31T11:00:05.459Z]: (1459422005459): Component "client:upload-manager" calling start()
xdk:client:[2016-03-31T11:00:05.459Z]: (1459422005459): Component "client:upload-manager" finished start()
xdk:client:[2016-03-31T11:00:05.459Z]: (1459422005459): Component "client:publish-tab" calling start()
xdk:client:[2016-03-31T11:00:05.461Z]: (1459422005461): onExitRequest listener 4:
at AutofillController.registerForEvents_ (file:///home/hpandelo/Softwares/intel/XDK/xdk/components/client/publish-tab/autofill-form-controller.js:17:1607)
at new AutofillController (file:///home/hpandelo/Softwares/intel/XDK/xdk/components/client/publish-tab/autofill-form-controller.js:17:470)
at Object.myExports.start (file:///home/hpandelo/Softwares/intel/XDK/xdk/components/client/publish-tab/publish-tab.js:17:4918)
xdk:client:[2016-03-31T11:00:05.486Z]: (1459422005486): Component "client:publish-tab" finished start()
xdk:client:[2016-03-31T11:00:05.487Z]: (1459422005487): Error in common initialization
client:build-tab:[2016-03-31T11:00:05.504Z]: (1459422005504): [refreshPage] Unable to generate project hash. { message_: 'no project selected',
code_: null,
componentName_: null,
stack_: 'Error\n at new ComponentError (/home/hpandelo/Softwares/intel/XDK/xdk/core-modules/public/component-error.js:17:1122)\n at makeError (file:///home/hpandelo/Softwares/intel/XDK/xdk/components/client/backend-service-utils/backend-service-utils.js:17:187)\n at Object.exports.generateProjectHash (file:///home/hpandelo/Softwares/intel/XDK/xdk/components/client/backend-service-utils/backend-service-utils.js:17:1440)\n at _refreshPage (file:///home/hpandelo/Softwares/intel/XDK/xdk/components/client/build-tab/build-tab.js:17:6994)\n at Object.start (file:///home/hpandelo/Softwares/intel/XDK/xdk/components/client/build-tab/build-tab.js:17:3869)\n at resumeClientInit (/home/hpandelo/Softwares/intel/XDK/xdk/core-modules/private/main.js:17:12040)\n at /home/hpandelo/Softwares/intel/XDK/xdk/core-modules/private/main.js:17:1734\n at _fulfilled (/home/hpandelo/Softwares/intel/XDK/xdk/node_modules/q/q.js:834:54)\n at self.promiseDispatch.done (/home/hpandelo/Softwares/intel/XDK/xdk/node_modules/q/q.js:863:30)\n at Promise.promise.promiseDispatch (/home/hpandelo/Softwares/intel/XDK/xdk/node_modules/q/q.js:796:13)' }
client:build-tab:[2016-03-31T11:00:05.505Z]: (1459422005505): [updatePageStatus] Set Status: PAGE_STATUS_ERROR
[Log closed from xdk:client]
and i have created some links:
sudo ln -s /lib64 ./x86_64-linux-gnu && sudo ln -s /lib64/libssl.so.1.0.2g /lib64/libssl.so.1.0.0 && sudo ln -s /lib64/libcrypto.so.1.0.2g /lib64/libcrypto.so.1.0.0
now it warns:
ios-device:[2016-03-31T11:22:09.168Z]: (1459423329168): Failed to initialize libwi due to Dynamic Linking Error: /lib64/libssl.so.1.0.0: version `OPENSSL_1.0.0' not found (required by /home/hpandelo/Softwares/intel/XDK/bin/libwi/libimobiledevice.so.5)
and:
xdk:client:[2016-03-31T11:22:22.611Z]: (1459423342611): Unexpected exception while initializing "device-discovery" (maybe crash): Error: Dynamic Linking Error: /lib64/libssl.so.1.0.0: version `OPENSSL_1.0.0' not found (required by /home/hpandelo/Softwares/intel/XDK/bin/libwi/libimobiledevice.so.5)
Anyone know the solution??
- Tags:
- HTML5
- Intel® XDK
Intel XDK is expected to be installed on Window 7 or higher, Mac OSX and Linux Ubuntu based on its requirements. Any other operating system is not supported outside of its developed use.
Version before 3088 was working on Fedora 23
It just needed to replace libudev.so.0 on XDK folder for a symlink to the real one in libraries
ln -s /usr/lib64/libudev.so.1 libudev.so.0
But this not works anymore since 3088
