Software Archive
Read-only legacy content
17061 Discussions
XDK app designer not working correctly
Youssef_A_
I have created a new project based on the ionic framework. I used the app designer to drag and drop controls. I have added a second page and dropped controls there also. But I want to go back to page 1 (main page) in the designer, I can't return to page 2 (bookingslistpage). I tried to restart the xdk but now I can't even drag and drop controls. What am I doing wrong here? I have no code writen I just drag and drop controls. See my screenshot for more information.
PaulF_IntelCorp
Please try using the Twitter Bootstrap framework, instead. The Ionic and Framework7 options are more difficult to work with.
Chris_P_Intel
Did you edit the HTML directly at all?
I tried what you described several times, and it works great. Multiple pages, different controls, no problems.
If I had to hazard a guess I would guess that you made some edit to the HTML directly and perhaps broke it. Try copy/pasting your code into https://validator.w3.org/  to see if there are any problems.
Chris
Youssef_A_
Hi Chris, thank you for your answer. I did edit the html. I have drag and dropped an image and set another image to that control. Now I can see my second page. There's a problem I always encounter here. When I add a page via the designer. In the beginning I can switch between them design time. But after a while it isn't possible. I deleted the other page and added a new one. Now I can see the controls. But in design time I can't switch between the 2 controls. Any suggestions?
Himansu_H_
Hello
Intel App Design option not coming , actually when i start a project framework option is not there ? what is the sollution,. please help me
PaulF_IntelCorp
App Designer has been retired. Please see the release notes > https://software.intel.com/en-us/xdk/docs/release-notes-information-intel-xdk < and we suggest you update to the latest version > http://xdk.intel.com <
