Software Archive
Read-only legacy content
XDK not starting - RESOLVED
paolo_c_
He,
I have problem my XDK not starting more.
I have disinstalled and reinstalled but it is the same.
The XDK is stoppend in initializing...
In my task manager i see  seven nw.exe *32
can you help me?
thanks Paolo
Elroy_A_Intel
I recommend removing the seven processes and restarting your computer before trying to launch Intel XDK again. This time it should start successfully. If there is multiple processes already running in regards to nw.exe, Intel XDK will not launch successfully.
paolo_c_
I did more tests
same result 7 times nw.exe * 32 in task manager (1 application, 7 process)
And XDK It's stopped in initializing...
paolo_c_
my log??
xdk:client:[2015-12-09T17:33:25.647Z]: (1449682405649): memlim: 767557632
xdk:client:[2015-12-09T17:33:25.680Z]: (1449682405680): Setting NW crash dump to: C:\Users\utente\AppData\Local\XDK
xdk:client:[2015-12-09T17:33:25.948Z]: (1449682405948): Intel XDK: 2727
xdk:client:[2015-12-09T17:33:25.948Z]: (1449682405948): Platform: win32-ia32 (6.1.7601)
xdk:client:[2015-12-09T17:33:25.948Z]: (1449682405948): NW: 0.11.7-rc8
xdk:client:[2015-12-09T17:33:26.038Z]: (1449682406039): Created new theme: base
xdk:client:[2015-12-09T17:33:26.039Z]: (1449682406039): Registered new theme: base
xdk:client:[2015-12-09T17:33:26.041Z]: (1449682406041): Current theme is now: base
xdk:client:[2015-12-09T17:33:26.041Z]: (1449682406041): Loading theme from: ../../public/themes/xdk.json
xdk:client:[2015-12-09T17:33:26.042Z]: (1449682406042): Failed to load theme: xdk { [Error: Cannot find module '../../public/themes/xdk.json'] code: 'MODULE_NOT_FOUND' }
xdk:client:[2015-12-09T17:33:26.104Z]: (1449682406104): Error SyntaxError: Unexpected token
 loading components\client\emulator\locale\root\text-content.json
xdk:client:[2015-12-09T17:33:26.224Z]: (1449682406224): Starting client process initialization
xdk:client:[2015-12-09T17:33:26.259Z]: (1449682406259): NW Cache is up-to-date.
xdk:server:[2015-12-09T17:33:26.956Z]: (1449682406958): memlim: 767557632
xdk:server:[2015-12-09T17:33:26.963Z]: (1449682406963): Setting NW crash dump to: C:\Users\utente\AppData\Local\XDK
xdk:server:[2015-12-09T17:33:27.273Z]: (1449682407273): Starting server process initialization
xdk:server:[2015-12-09T17:33:27.461Z]: (1449682407461): Http server started on the standard port 58889
xdk:server:[2015-12-09T17:33:27.488Z]: (1449682407488): Component "core:assert" starting import
xdk:server:[2015-12-09T17:33:27.489Z]: (1449682407489): Component "core:assert" finished initialization
xdk:server:[2015-12-09T17:33:27.489Z]: (1449682407489): Component "core:component-error" starting import
xdk:server:[2015-12-09T17:33:27.489Z]: (1449682407489): Component "core:component-error" finished initialization
xdk:server:[2015-12-09T17:33:27.490Z]: (1449682407490): Component "core:command-line-options" starting import
xdk:server:[2015-12-09T17:33:27.490Z]: (1449682407490): Component "core:command-line-options" finished initialization
xdk:server:[2015-12-09T17:33:27.490Z]: (1449682407490): Component "core:service-error" starting import
xdk:server:[2015-12-09T17:33:27.490Z]: (1449682407490): Component "core:service-error" finished initialization
xdk:server:[2015-12-09T17:33:27.490Z]: (1449682407490): Component "core:buffer" starting import
xdk:server:[2015-12-09T17:33:27.490Z]: (1449682407490): Component "core:buffer" finished initialization
xdk:server:[2015-12-09T17:33:27.490Z]: (1449682407490): Component "core:signaler" starting import
xdk:server:[2015-12-09T17:33:27.494Z]: (1449682407494): Component "core:signaler" finished initialization
xdk:server:[2015-12-09T17:33:27.494Z]: (1449682407494): Component "core:signaler-group" starting import
xdk:server:[2015-12-09T17:33:27.497Z]: (1449682407497): Component "core:signaler-group" finished initialization
xdk:server:[2015-12-09T17:33:27.497Z]: (1449682407497): Component "core:logger" starting import
xdk:server:[2015-12-09T17:33:27.498Z]: (1449682407498): Component "core:logger" finished initialization
xdk:server:[2015-12-09T17:33:27.498Z]: (1449682407498): Component "core:http-request" starting import
xdk:server:[2015-12-09T17:33:27.499Z]: (1449682407499): Component "core:http-request" finished initialization
xdk:server:[2015-12-09T17:33:27.499Z]: (1449682407499): Component "core:database" starting import
xdk:server:[2015-12-09T17:33:27.500Z]: (1449682407500): Component "core:database" finished initialization
xdk:server:[2015-12-09T17:33:27.501Z]: (1449682407501): Component "core:version" starting import
xdk:server:[2015-12-09T17:33:27.501Z]: (1449682407501): Component "core:version" finished initialization
xdk:server:[2015-12-09T17:33:27.501Z]: (1449682407501): Component "core:userfs-name-converter" starting import
xdk:server:[2015-12-09T17:33:27.502Z]: (1449682407502): Component "core:userfs-name-converter" finished initialization
xdk:server:[2015-12-09T17:33:27.502Z]: (1449682407502): Component "core:crash-handler" starting import
xdk:server:[2015-12-09T17:33:27.503Z]: (1449682407503): Component "core:crash-handler" finished initialization
xdk:server:[2015-12-09T17:33:27.503Z]: (1449682407503): Component "core:i18n-support" starting import
xdk:server:[2015-12-09T17:33:27.503Z]: (1449682407503): Component "core:i18n-support" finished initialization
xdk:server:[2015-12-09T17:33:27.503Z]: (1449682407503): Component "core:theme" starting import
xdk:server:[2015-12-09T17:33:27.573Z]: (1449682407573): Component "core:theme" finished initialization
xdk:server:[2015-12-09T17:33:27.575Z]: (1449682407575): Component "server:userfs" starting import
xdk:server:[2015-12-09T17:33:27.584Z]: (1449682407584): Component "server:userfs" calling init()
xdk:server:[2015-12-09T17:33:27.640Z]: (1449682407640): Component "server:userfs" finished initialization
xdk:server:[2015-12-09T17:33:27.640Z]: (1449682407640): Component "server:user-profile" starting import
xdk:server:[2015-12-09T17:33:27.645Z]: (1449682407645): Component "server:user-profile" calling init()
xdk:server:[2015-12-09T17:33:27.645Z]: (1449682407645): Component "server:user-profile" finished initialization
xdk:server:[2015-12-09T17:33:27.645Z]: (1449682407645): Component "server:ui-builder" starting import
xdk:server:[2015-12-09T17:33:27.724Z]: (1449682407724): Component "server:ui-builder" calling init()
xdk:server:[2015-12-09T17:33:27.727Z]: (1449682407727): Component "server:ui-builder" finished initialization
xdk:server:[2015-12-09T17:33:27.727Z]: (1449682407727): Component "server:emulator-notification" starting import
xdk:server:[2015-12-09T17:33:27.733Z]: (1449682407733): Component "server:emulator-notification" calling init()
xdk:server:[2015-12-09T17:33:27.733Z]: (1449682407733): Component "server:emulator-notification" finished initialization
xdk:server:[2015-12-09T17:33:27.733Z]: (1449682407733): Component "server:emulator-webserver" starting import
xdk:server:[2015-12-09T17:33:27.735Z]: (1449682407735): Component "server:emulator-webserver" calling init()
xdk:server:[2015-12-09T17:33:27.737Z]: (1449682407737): Component "server:emulator-webserver" finished initialization
xdk:server:[2015-12-09T17:33:27.737Z]: (1449682407738): Component "server:new-project-creator" starting import
xdk:server:[2015-12-09T17:33:27.745Z]: (1449682407745): Component "server:new-project-creator" calling init()
xdk:server:[2015-12-09T17:33:27.746Z]: (1449682407746): Component "server:new-project-creator" finished initialization
xdk:server:[2015-12-09T17:33:27.746Z]: (1449682407746): Component "server:zip-util" starting import
xdk:server:[2015-12-09T17:33:27.751Z]: (1449682407751): Component "server:zip-util" calling init()
xdk:server:[2015-12-09T17:33:27.751Z]: (1449682407751): Component "server:zip-util" finished initialization
xdk:server:[2015-12-09T17:33:27.751Z]: (1449682407751): Component "server:uuid-server" starting import
xdk:server:[2015-12-09T17:33:27.755Z]: (1449682407755): Component "server:uuid-server" calling init()
xdk:server:[2015-12-09T17:33:27.755Z]: (1449682407755): Component "server:uuid-server" finished initialization
xdk:server:[2015-12-09T17:33:27.755Z]: (1449682407755): Component "server:app-starter" starting import
xdk:server:[2015-12-09T17:33:27.765Z]: (1449682407765): Component "server:app-starter" calling init()
xdk:server:[2015-12-09T17:33:27.769Z]: (1449682407769): Component "server:app-starter" finished initialization
xdk:server:[2015-12-09T17:33:27.769Z]: (1449682407769): Component "server:force-download" starting import
xdk:server:[2015-12-09T17:33:27.773Z]: (1449682407773): Component "server:force-download" calling init()
xdk:server:[2015-12-09T17:33:27.774Z]: (1449682407774): Component "server:force-download" finished initialization
xdk:server:[2015-12-09T17:33:27.774Z]: (1449682407774): Component "server:updater" starting import
xdk:server:[2015-12-09T17:33:27.782Z]: (1449682407782): Component "server:updater" calling init()
server:updater:[2015-12-09T17:33:27.782Z]: (1449682407782): config.base-auto
server:updater:[2015-12-09T17:33:27.782Z]: (1449682407782): url=auto
xdk:server:[2015-12-09T17:33:27.783Z]: (1449682407783): Component "server:updater" finished initialization
xdk:server:[2015-12-09T17:33:27.783Z]: (1449682407783): Component "server:editor-node" starting import
xdk:server:[2015-12-09T17:33:27.820Z]: (1449682407820): Component "server:editor-node" calling init()
xdk:server:[2015-12-09T17:33:27.820Z]: (1449682407820): Component "server:editor-node" waiting for delayed initialization
xdk:server:[2015-12-09T17:33:27.820Z]: (1449682407820): Component "server:cordova-lib" starting import
xdk:server:[2015-12-09T17:33:28.266Z]: (1449682408266): Component "server:cordova-lib" calling init()
xdk:server:[2015-12-09T17:33:28.489Z]: (1449682408489): Component "server:cordova-lib" finished initialization
xdk:server:[2015-12-09T17:33:28.489Z]: (1449682408489): Component "server:api-explorer" starting import
xdk:server:[2015-12-09T17:33:28.496Z]: (1449682408496): Component "server:api-explorer" calling init()
xdk:server:[2015-12-09T17:33:28.558Z]: (1449682408558): Component "server:api-explorer" finished initialization
xdk:server:[2015-12-09T17:33:28.558Z]: (1449682408558): Component "server:plugin-listener" starting import
xdk:server:[2015-12-09T17:33:28.562Z]: (1449682408562): Component "server:plugin-listener" calling init()
xdk:server:[2015-12-09T17:33:28.562Z]: (1449682408562): Component "server:plugin-listener" finished initialization
xdk:server:[2015-12-09T17:33:28.562Z]: (1449682408562): Component "server:git-runner" starting import
xdk:server:[2015-12-09T17:33:28.567Z]: (1449682408567): Component "server:git-runner" calling init()
xdk:server:[2015-12-09T17:33:28.567Z]: (1449682408567): Component "server:git-runner" finished initialization
server:editor-node:[2015-12-09T17:33:28.570Z]: (1449682408570): Starting Brackets node process "D:\Program Files\Intel\XDK\bin\node.exe" "D:\Program Files\Intel\XDK\bin\node-core"
xdk:server:[2015-12-09T17:33:28.593Z]: (1449682408593): NW Cache is up-to-date.
server:editor-node:[2015-12-09T17:33:28.704Z]: (1449682408704): Brackets node is running on port 4524
xdk:server:[2015-12-09T17:33:28.704Z]: (1449682408704): Component "server:editor-node" finished delayed initialization
xdk:server:[2015-12-09T17:33:28.704Z]: (1449682408704): Component "server:ui-builder" calling start()
xdk:server:[2015-12-09T17:33:28.704Z]: (1449682408704): Component "server:ui-builder" finished start()
xdk:server:[2015-12-09T17:33:28.704Z]: (1449682408704): Component "server:emulator-webserver" calling start()
xdk:server:[2015-12-09T17:33:28.704Z]: (1449682408704): Component "server:emulator-webserver" finished start()
xdk:server:[2015-12-09T17:33:28.704Z]: (1449682408704): Component "server:editor-node" calling start()
xdk:server:[2015-12-09T17:33:28.704Z]: (1449682408704): Component "server:editor-node" finished start()
xdk:server:[2015-12-09T17:33:28.720Z]: (1449682408720): Intel XDK is initialized now
xdk:server:[2015-12-09T17:33:28.720Z]: (1449682408720): Writing to the server data file
xdk:server:[2015-12-09T17:33:28.720Z]: (1449682408720): Wrote server data to "C:\Users\utente\AppData\Local\XDK\server-data.txt"
xdk:client:[2015-12-09T17:33:28.799Z]: (1449682408799): Successfully read server data file
xdk:client:[2015-12-09T17:33:29.257Z]: (1449682409258): Component "core:assert" starting import
xdk:client:[2015-12-09T17:33:29.258Z]: (1449682409258): Component "core:assert" finished initialization
xdk:client:[2015-12-09T17:33:29.258Z]: (1449682409258): Component "core:component-error" starting import
xdk:client:[2015-12-09T17:33:29.259Z]: (1449682409259): Component "core:component-error" finished initialization
xdk:client:[2015-12-09T17:33:29.259Z]: (1449682409259): Component "core:command-line-options" starting import
xdk:client:[2015-12-09T17:33:29.259Z]: (1449682409259): Component "core:command-line-options" finished initialization
xdk:client:[2015-12-09T17:33:29.259Z]: (1449682409259): Component "core:service-error" starting import
xdk:client:[2015-12-09T17:33:29.259Z]: (1449682409259): Component "core:service-error" finished initialization
xdk:client:[2015-12-09T17:33:29.259Z]: (1449682409259): Component "core:buffer" starting import
xdk:client:[2015-12-09T17:33:29.259Z]: (1449682409259): Component "core:buffer" finished initialization
xdk:client:[2015-12-09T17:33:29.259Z]: (1449682409259): Component "core:signaler" starting import
xdk:client:[2015-12-09T17:33:29.260Z]: (1449682409260): Component "core:signaler" finished initialization
xdk:client:[2015-12-09T17:33:29.261Z]: (1449682409261): Component "core:signaler-group" starting import
xdk:client:[2015-12-09T17:33:29.263Z]: (1449682409263): Component "core:signaler-group" finished initialization
xdk:client:[2015-12-09T17:33:29.263Z]: (1449682409263): Component "core:logger" starting import
xdk:client:[2015-12-09T17:33:29.264Z]: (1449682409264): Component "core:logger" finished initialization
xdk:client:[2015-12-09T17:33:29.264Z]: (1449682409264): Component "core:http-request" starting import
xdk:client:[2015-12-09T17:33:29.265Z]: (1449682409265): Component "core:http-request" finished initialization
xdk:client:[2015-12-09T17:33:29.265Z]: (1449682409266): Component "core:version" starting import
xdk:client:[2015-12-09T17:33:29.266Z]: (1449682409266): Component "core:version" finished initialization
xdk:client:[2015-12-09T17:33:29.266Z]: (1449682409266): Component "core:exit-notifier" starting import
xdk:client:[2015-12-09T17:33:29.266Z]: (1449682409266): Component "core:exit-notifier" finished initialization
xdk:client:[2015-12-09T17:33:29.266Z]: (1449682409266): Component "core:userfs-name-converter" starting import
xdk:client:[2015-12-09T17:33:29.267Z]: (1449682409267): Component "core:userfs-name-converter" finished initialization
xdk:client:[2015-12-09T17:33:29.267Z]: (1449682409267): Component "core:crash-handler" starting import
xdk:client:[2015-12-09T17:33:29.268Z]: (1449682409268): Component "core:crash-handler" finished initialization
xdk:client:[2015-12-09T17:33:29.268Z]: (1449682409268): Component "core:analytics" starting import
xdk:client:[2015-12-09T17:33:29.268Z]: (1449682409268): Component "core:analytics" finished initialization
xdk:client:[2015-12-09T17:33:29.268Z]: (1449682409268): Component "core:i18n-support" starting import
xdk:client:[2015-12-09T17:33:29.268Z]: (1449682409268): Component "core:i18n-support" finished initialization
xdk:client:[2015-12-09T17:33:29.268Z]: (1449682409268): Component "core:theme" starting import
xdk:client:[2015-12-09T17:33:29.268Z]: (1449682409268): Component "core:theme" finished initialization
xdk:client:[2015-12-09T17:33:29.280Z]: (1449682409280): Analytics ID: 8c37fe3f-48b9-4be0-b086-23b081cdf253
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:app" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:help-helper" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:nativefs" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:document-manager" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:project-manager" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:aa-controller" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:projects-renderers" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:projects-renderers-jsapp" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:projects-renderers-webapp" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:projects-renderers-iotapp" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:active-sync" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:apk-installer" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:appcenter-options" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:resource-manager" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:resource-cocos2d" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:resource-cocos2djs" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:resource-phaser" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:resource-pixi" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:resource-easeljs" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:resource-plain" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:resource-render-frame" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:resource-util" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:services-tab" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:editor" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:live-preview" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:backend-services" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:backend-feeds" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:merged-feed" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:backend-services-ext" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:backend-service-utils" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:app-starter" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:ui-builder-client" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:project-meta" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:contenttype-registry" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:editor-registry" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:platform-registry" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:projecttype-registry" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:library-registry" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:cordova-registry" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:service-method" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:settings-db" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:adb" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:iosdb" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:device" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:device-discovery" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:dialog-box" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:test-local-server" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:quick-tour" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:hot-keys" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:persistance" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:tabs" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:hash-utils" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:file-watcher" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:tool-tip" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:cordova" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:settings-ui" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:external-links" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:external-editors-runner" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:project-list-load" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:upload-manager" starting import
xdk:client:[2015-12-09T17:33:29.306Z]: (1449682409306): Component "client:git-manager" starting import
xdk:client:[2015-12-09T17:33:29.356Z]: (1449682409356): Component "client:help-helper" finished initialization
xdk:client:[2015-12-09T17:33:29.356Z]: (1449682409356): Component "client:nativefs" finished initialization
xdk:client:[2015-12-09T17:33:29.388Z]: (1449682409388): Component "client:active-sync" calling init()
xdk:client:[2015-12-09T17:33:29.388Z]: (1449682409388): Component "client:active-sync" finished initialization
xdk:client:[2015-12-09T17:33:29.391Z]: (1449682409391): Component "client:apk-installer" calling init()
xdk:client:[2015-12-09T17:33:29.391Z]: (1449682409391): Component "client:apk-installer" finished initialization
xdk:client:[2015-12-09T17:33:29.413Z]: (1449682409413): Component "client:resource-render-frame" calling init()
xdk:client:[2015-12-09T17:33:29.414Z]: (1449682409414): Component "client:resource-render-frame" waiting for delayed initialization
xdk:client:[2015-12-09T17:33:29.415Z]: (1449682409415): Component "client:resource-util" calling init()
xdk:client:[2015-12-09T17:33:29.415Z]: (1449682409415): Component "client:resource-util" finished initialization
xdk:client:[2015-12-09T17:33:29.423Z]: (1449682409423): Component "client:backend-services" calling init()
xdk:client:[2015-12-09T17:33:29.425Z]: (1449682409425): Component "client:backend-services" finished initialization
xdk:client:[2015-12-09T17:33:29.427Z]: (1449682409427): Component "client:backend-feeds" calling init()
xdk:client:[2015-12-09T17:33:29.427Z]: (1449682409427): Component "client:backend-feeds" finished initialization
xdk:client:[2015-12-09T17:33:29.429Z]: (1449682409429): Component "client:merged-feed" finished initialization
xdk:client:[2015-12-09T17:33:29.431Z]: (1449682409431): Component "client:backend-services-ext" calling init()
xdk:client:[2015-12-09T17:33:29.431Z]: (1449682409431): Component "client:backend-services-ext" finished initialization
xdk:client:[2015-12-09T17:33:29.432Z]: (1449682409432): Component "client:backend-service-utils" finished initialization
xdk:client:[2015-12-09T17:33:29.436Z]: (1449682409436): Component "client:project-meta" calling init()
xdk:client:[2015-12-09T17:33:29.437Z]: (1449682409437): Component "client:project-meta" finished initialization
xdk:client:[2015-12-09T17:33:29.444Z]: (1449682409444): Component "client:service-method" finished initialization
xdk:client:[2015-12-09T17:33:29.447Z]: (1449682409447): Component "client:settings-db" calling init()
xdk:client:[2015-12-09T17:33:29.447Z]: (1449682409447): Component "client:settings-db" waiting for delayed initialization
xdk:client:[2015-12-09T17:33:29.448Z]: (1449682409449): Component "client:adb" calling init()
xdk:client:[2015-12-09T17:33:29.475Z]: (1449682409475): Component "client:adb" waiting for delayed initialization
xdk:client:[2015-12-09T17:33:29.477Z]: (1449682409477): Component "client:iosdb" calling init()
xdk:client:[2015-12-09T17:33:29.477Z]: (1449682409477): Component "client:iosdb" finished initialization
xdk:client:[2015-12-09T17:33:29.484Z]: (1449682409484): Component "client:device" finished initialization
xdk:client:[2015-12-09T17:33:29.498Z]: (1449682409498): Component "client:persistance" calling init()
xdk:client:[2015-12-09T17:33:29.498Z]: (1449682409498): Component "client:persistance" waiting for delayed initialization
xdk:client:[2015-12-09T17:33:29.502Z]: (1449682409502): Component "client:file-watcher" calling init()
xdk:client:[2015-12-09T17:33:29.502Z]: (1449682409502): Component "client:file-watcher" finished initialization
xdk:client:[2015-12-09T17:33:29.510Z]: (1449682409510): Component "client:external-links" finished initialization
xdk:client:[2015-12-09T17:33:29.511Z]: (1449682409511): Component "client:external-editors-runner" calling init()
xdk:client:[2015-12-09T17:33:29.512Z]: (1449682409512): Component "client:external-editors-runner" finished initialization
xdk:client:[2015-12-09T17:33:29.512Z]: (1449682409513): Component "client:project-list-load" calling init()
xdk:client:[2015-12-09T17:33:29.513Z]: (1449682409513): Component "client:project-list-load" waiting for delayed initialization
xdk:client:[2015-12-09T17:33:29.522Z]: (1449682409522): Component "client:resource-render-frame" finished delayed initialization
xdk:client:[2015-12-09T17:33:29.540Z]: (1449682409540): Component "client:tool-tip" finished initialization
xdk:client:[2015-12-09T17:33:29.545Z]: (1449682409546): Component "client:upload-manager" calling init()
xdk:client:[2015-12-09T17:33:29.546Z]: (1449682409546): Component "client:upload-manager" finished initialization
xdk:client:[2015-12-09T17:33:29.547Z]: (1449682409547): Component "client:git-manager" calling init()
client:git-manager:[2015-12-09T17:33:29.547Z]: (1449682409547): git path =  D:\Program Files\Intel\XDK\bin\git\bin\git.exe
xdk:client:[2015-12-09T17:33:29.547Z]: (1449682409547): Component "client:git-manager" waiting for delayed initialization
xdk:client:[2015-12-09T17:33:29.552Z]: (1449682409552): Component "client:app-starter" finished initialization
xdk:client:[2015-12-09T17:33:29.556Z]: (1449682409556): Component "client:ui-builder-client" calling init()
xdk:client:[2015-12-09T17:33:29.556Z]: (1449682409556): Component "client:ui-builder-client" finished initialization
xdk:client:[2015-12-09T17:33:29.558Z]: (1449682409558): Component "client:dialog-box" finished initialization
xdk:client:[2015-12-09T17:33:29.560Z]: (1449682409560): Component "client:hot-keys" calling init()
xdk:client:[2015-12-09T17:33:29.560Z]: (1449682409560): Component "client:hot-keys" finished initialization
xdk:client:[2015-12-09T17:33:29.562Z]: (1449682409562): Component "client:settings-ui" finished initialization
xdk:client:[2015-12-09T17:33:29.565Z]: (1449682409565): Component "client:document-manager" calling init()
xdk:client:[2015-12-09T17:33:29.565Z]: (1449682409565): Component "client:document-manager" finished initialization
xdk:client:[2015-12-09T17:33:29.585Z]: (1449682409585): Component "client:aa-controller" calling init()
xdk:client:[2015-12-09T17:33:29.585Z]: (1449682409585): Component "client:aa-controller" finished initialization
xdk:client:[2015-12-09T17:33:29.656Z]: (1449682409656): Component "client:contenttype-registry" calling init()
xdk:client:[2015-12-09T17:33:29.657Z]: (1449682409657): Component "client:contenttype-registry" finished initialization
xdk:client:[2015-12-09T17:33:29.658Z]: (1449682409658): Component "client:editor-registry" finished initialization
xdk:client:[2015-12-09T17:33:29.667Z]: (1449682409667): Component "client:library-registry" calling init()
xdk:client:[2015-12-09T17:33:29.667Z]: (1449682409667): Component "client:library-registry" finished initialization
xdk:client:[2015-12-09T17:33:29.675Z]: (1449682409675): Component "client:device-discovery" calling init()
xdk:client:[2015-12-09T17:33:29.676Z]: (1449682409676): Component "client:device-discovery" waiting for delayed initialization
xdk:client:[2015-12-09T17:33:29.678Z]: (1449682409678): Component "client:hash-utils" finished initialization
xdk:client:[2015-12-09T17:33:29.723Z]: (1449682409723): Component "client:cordova" calling init()
xdk:client:[2015-12-09T17:33:29.723Z]: (1449682409723): Component "client:cordova" waiting for delayed initialization
xdk:client:[2015-12-09T17:33:29.731Z]: (1449682409731): Component "client:device-discovery" finished delayed initialization
client:adb:[2015-12-09T17:33:29.737Z]: (1449682409737): Can't find adb process.
client:adb:[2015-12-09T17:33:29.737Z]: (1449682409737): Using default adb executable at "D:\Program Files\Intel\XDK\bin\adb\adb"
xdk:client:[2015-12-09T17:33:29.772Z]: (1449682409772): Component "client:resource-manager" calling init()
xdk:client:[2015-12-09T17:33:29.772Z]: (1449682409772): Component "client:resource-manager" waiting for delayed initialization
xdk:client:[2015-12-09T17:33:29.788Z]: (1449682409788): Component "client:resource-cocos2djs" calling init()
xdk:client:[2015-12-09T17:33:29.788Z]: (1449682409788): Component "client:resource-cocos2djs" finished initialization
xdk:client:[2015-12-09T17:33:29.788Z]: (1449682409788): Component "client:resource-phaser" calling init()
xdk:client:[2015-12-09T17:33:29.788Z]: (1449682409788): Component "client:resource-phaser" finished initialization
xdk:client:[2015-12-09T17:33:29.788Z]: (1449682409788): Component "client:resource-pixi" calling init()
xdk:client:[2015-12-09T17:33:29.788Z]: (1449682409788): Component "client:resource-pixi" finished initialization
xdk:client:[2015-12-09T17:33:29.788Z]: (1449682409788): Component "client:resource-easeljs" calling init()
xdk:client:[2015-12-09T17:33:29.788Z]: (1449682409788): Component "client:resource-easeljs" finished initialization
xdk:client:[2015-12-09T17:33:29.788Z]: (1449682409788): Component "client:resource-plain" calling init()
xdk:client:[2015-12-09T17:33:29.788Z]: (1449682409788): Component "client:resource-plain" finished initialization
xdk:client:[2015-12-09T17:33:29.788Z]: (1449682409788): Component "client:cordova-registry" calling init()
xdk:client:[2015-12-09T17:33:29.788Z]: (1449682409788): Component "client:cordova-registry" waiting for delayed initialization
xdk:client:[2015-12-09T17:33:29.803Z]: (1449682409803): Component "client:appcenter-options" calling init()
xdk:client:[2015-12-09T17:33:29.803Z]: (1449682409803): Component "client:appcenter-options" waiting for delayed initialization
xdk:client:[2015-12-09T17:33:29.803Z]: (1449682409803): Component "client:services-tab" calling init()
xdk:client:[2015-12-09T17:33:29.803Z]: (1449682409803): Component "client:services-tab" finished initialization
xdk:client:[2015-12-09T17:33:29.803Z]: (1449682409803): Component "client:test-local-server" calling init()
xdk:client:[2015-12-09T17:33:29.851Z]: (1449682409851): Component "client:test-local-server" finished initialization
xdk:client:[2015-12-09T17:33:29.852Z]: (1449682409852): Component "client:tabs" finished initialization
xdk:client:[2015-12-09T17:33:29.857Z]: (1449682409857): Component "client:app" calling init()
xdk:client:[2015-12-09T17:33:29.884Z]: (1449682409884): Component "client:app" finished initialization
xdk:client:[2015-12-09T17:33:29.895Z]: (1449682409895): Component "client:quick-tour" calling init()
xdk:client:[2015-12-09T17:33:29.895Z]: (1449682409895): Component "client:quick-tour" finished initialization
xdk:client:[2015-12-09T17:33:29.908Z]: (1449682409908): Component "client:project-manager" calling init()
xdk:client:[2015-12-09T17:33:29.909Z]: (1449682409909): Component "client:project-manager" waiting for delayed initialization
xdk:client:[2015-12-09T17:33:29.913Z]: (1449682409913): Component "client:projects-renderers" calling init()
xdk:client:[2015-12-09T17:33:29.913Z]: (1449682409913): Component "client:projects-renderers" waiting for delayed initialization
xdk:client:[2015-12-09T17:33:29.913Z]: (1449682409913): Component "client:projects-renderers-iotapp" calling init()
xdk:client:[2015-12-09T17:33:29.914Z]: (1449682409914): Component "client:projects-renderers-iotapp" finished initialization
xdk:client:[2015-12-09T17:33:29.933Z]: (1449682409933): Component "client:resource-cocos2d" calling init()
xdk:client:[2015-12-09T17:33:29.933Z]: (1449682409933): Component "client:resource-cocos2d" waiting for delayed initialization
xdk:client:[2015-12-09T17:33:29.943Z]: (1449682409943): Component "client:platform-registry" calling init()
xdk:client:[2015-12-09T17:33:29.944Z]: (1449682409944): Component "client:platform-registry" finished initialization
xdk:client:[2015-12-09T17:33:29.946Z]: (1449682409946): Component "client:projecttype-registry" calling init()
xdk:client:[2015-12-09T17:33:29.947Z]: (1449682409947): Component "client:projecttype-registry" finished initialization
xdk:client:[2015-12-09T17:33:29.948Z]: (1449682409948): Component "client:navbar" starting import
xdk:client:[2015-12-09T17:33:29.948Z]: (1449682409948): Component "client:tweets" starting import
xdk:client:[2015-12-09T17:33:29.948Z]: (1449682409948): Component "client:projects-tab" starting import
xdk:client:[2015-12-09T17:33:29.948Z]: (1449682409948): Component "client:test-tab" starting import
xdk:client:[2015-12-09T17:33:29.948Z]: (1449682409948): Component "client:profilingTab" starting import
xdk:client:[2015-12-09T17:33:29.948Z]: (1449682409948): Component "client:emulator" starting import
xdk:client:[2015-12-09T17:33:29.948Z]: (1449682409948): Component "client:remote-tab" starting import
xdk:client:[2015-12-09T17:33:29.949Z]: (1449682409949): Component "client:build-tab" starting import
xdk:client:[2015-12-09T17:33:29.949Z]: (1449682409949): Component "client:editor-tab" starting import
xdk:client:[2015-12-09T17:33:29.949Z]: (1449682409949): Component "client:account" starting import
xdk:client:[2015-12-09T17:33:29.949Z]: (1449682409949): Component "client:project-selector" starting import
xdk:client:[2015-12-09T17:33:29.954Z]: (1449682409954): Component "client:resource-cocos2d" finished delayed initialization
xdk:client:[2015-12-09T17:33:29.956Z]: (1449682409956): Component "client:settings-db" finished delayed initialization
xdk:client:[2015-12-09T17:33:29.993Z]: (1449682409993): Component "client:git-manager" finished delayed initialization
xdk:client:[2015-12-09T17:33:30.023Z]: (1449682410023): Component "client:editor" calling init()
xdk:client:[2015-12-09T17:33:30.023Z]: (1449682410023): Component "client:editor" finished initialization
xdk:client:[2015-12-09T17:33:30.024Z]: (1449682410024): Component "client:live-preview" calling init()
xdk:client:[2015-12-09T17:33:30.024Z]: (1449682410024): Component "client:live-preview" finished initialization
xdk:client:[2015-12-09T17:33:30.024Z]: (1449682410024): Component "client:editor-tab" getting UI region for "develop"
xdk:client:[2015-12-09T17:33:30.025Z]: (1449682410025): Component "client:editor-tab" calling init()
xdk:client:[2015-12-09T17:33:30.044Z]: (1449682410044): Component "client:editor-tab" waiting for delayed initialization
xdk:client:[2015-12-09T17:33:30.060Z]: (1449682410060): Component "client:projects-renderers-webapp" calling init()
xdk:client:[2015-12-09T17:33:30.061Z]: (1449682410061): Component "client:projects-renderers-webapp" finished initialization
xdk:client:[2015-12-09T17:33:30.068Z]: (1449682410068): Component "client:projects-renderers-jsapp" calling init()
xdk:client:[2015-12-09T17:33:30.068Z]: (1449682410068): Component "client:projects-renderers-jsapp" finished initialization
xdk:client:[2015-12-09T17:33:30.094Z]: (1449682410094): Component "client:projects-renderers" finished delayed initialization
xdk:client:[2015-12-09T17:33:30.097Z]: (1449682410097): Component "client:cordova" finished delayed initialization
xdk:client:[2015-12-09T17:33:30.144Z]: (1449682410144): Component "client:account" getting UI region for "account"
xdk:client:[2015-12-09T17:33:30.145Z]: (1449682410145): Component "client:account" calling init()
xdk:client:[2015-12-09T17:33:30.151Z]: (1449682410151): Component "client:account" finished initialization
xdk:client:[2015-12-09T17:33:30.154Z]: (1449682410154): Component "client:tweets" finished initialization
xdk:client:[2015-12-09T17:33:30.155Z]: (1449682410155): Component "client:projects-tab" getting UI region for "project"
xdk:client:[2015-12-09T17:33:30.155Z]: (1449682410155): Component "client:projects-tab" calling init()
xdk:client:[2015-12-09T17:33:30.157Z]: (1449682410157): Component "client:projects-tab" waiting for delayed initialization
xdk:client:[2015-12-09T17:33:30.159Z]: (1449682410159): Component "client:test-tab" getting UI region for "test"
xdk:client:[2015-12-09T17:33:30.159Z]: (1449682410159): Component "client:test-tab" calling init()
xdk:client:[2015-12-09T17:33:30.159Z]: (1449682410159): Component "client:test-tab" waiting for delayed initialization
xdk:client:[2015-12-09T17:33:30.175Z]: (1449682410175): Component "client:emulator" getting UI region for "emulate"
xdk:client:[2015-12-09T17:33:30.175Z]: (1449682410175): Component "client:emulator" calling init()
xdk:client:[2015-12-09T17:33:30.178Z]: (1449682410178): Component "client:emulator" finished initialization
xdk:client:[2015-12-09T17:33:30.180Z]: (1449682410180): Component "client:build-tab" getting UI region for "build"
xdk:client:[2015-12-09T17:33:30.180Z]: (1449682410180): Component "client:build-tab" calling init()
xdk:client:[2015-12-09T17:33:30.187Z]: (1449682410187): Component "client:build-tab" finished initialization
xdk:client:[2015-12-09T17:33:30.194Z]: (1449682410194): Component "client:project-selector" getting UI region for "project-selector"
xdk:client:[2015-12-09T17:33:30.194Z]: (1449682410194): Component "client:project-selector" calling init()
xdk:client:[2015-12-09T17:33:30.194Z]: (1449682410194): Component "client:project-selector" finished initialization
xdk:client:[2015-12-09T17:33:30.198Z]: (1449682410198): Component "client:navbar" getting UI region for "navbar-common"
xdk:client:[2015-12-09T17:33:30.199Z]: (1449682410199): Component "client:navbar" calling init()
client:navbar:[2015-12-09T17:33:30.200Z]: (1449682410200): navbar options: {"common":{"servicesVersion":"release-2015-ww45","xdkVariant":"xdk"},"updatePollingInterval":1800,"forceUpdate":false}
xdk:client:[2015-12-09T17:33:30.200Z]: (1449682410200): Component "client:navbar" finished initialization
xdk:client:[2015-12-09T17:33:30.241Z]: (1449682410241): Component "client:remote-tab" getting UI region for "debug"
xdk:client:[2015-12-09T17:33:30.241Z]: (1449682410241): Component "client:remote-tab" calling init()
xdk:client:[2015-12-09T17:33:30.459Z]: (1449682410459): Component "client:remote-tab" waiting for delayed initialization
xdk:client:[2015-12-09T17:33:30.473Z]: (1449682410473): Component "client:remote-tab" finished delayed initialization
xdk:client:[2015-12-09T17:33:30.539Z]: (1449682410539): Component "client:profilingTab" getting UI region for "profile"
xdk:client:[2015-12-09T17:33:30.539Z]: (1449682410539): Component "client:profilingTab" calling init()
xdk:client:[2015-12-09T17:33:30.539Z]: (1449682410539): Component "client:profilingTab" finished initialization
xdk:client:[2015-12-09T17:33:30.651Z]: (1449682410651): memmrk:    28339200    42403456
xdk:client:[2015-12-09T17:33:30.791Z]: (1449682410791): Component "client:adb" finished delayed initialization
xdk:server:[2015-12-09T17:33:31.960Z]: (1449682411960): memmrk:    23755164    43419136
xdk:client:[2015-12-09T17:33:35.657Z]: (1449682415657): memmrk:    28386656    42403456
xdk:server:[2015-12-09T17:33:36.971Z]: (1449682416971): memmrk:    19386992    43419136
xdk:client:[2015-12-09T17:33:40.669Z]: (1449682420669): memmrk:    28390256    42403456
xdk:server:[2015-12-09T17:33:41.978Z]: (1449682421978): memmrk:    19410244    43419136
xdk:client:[2015-12-09T17:33:45.676Z]: (1449682425676): memmrk:    28392608    42403456
xdk:server:[2015-12-09T17:33:46.986Z]: (1449682426986): memmrk:    18091152    25671296
xdk:client:[2015-12-09T17:33:50.684Z]: (1449682430684): memmrk:    28394944    42403456
xdk:server:[2015-12-09T17:33:51.993Z]: (1449682431993): memmrk:    17440560    24667776
xdk:client:[2015-12-09T17:33:55.711Z]: (1449682435711): memmrk:    28397296    42403456
xdk:server:[2015-12-09T17:33:57.004Z]: (1449682437004): memmrk:    17451484    24667776
xdk:client:[2015-12-09T17:34:00.717Z]: (1449682440717): memmrk:    28627780    42403456
xdk:server:[2015-12-09T17:34:02.011Z]: (1449682442011): memmrk:    15874244    23664256
xdk:client:[2015-12-09T17:34:05.725Z]: (1449682445725): memmrk:    21185524    44434816
xdk:server:[2015-12-09T17:34:07.019Z]: (1449682447019): memmrk:    15823764    22660736
cordova-registry:[2015-12-09T17:34:07.831Z]: (1449682447831): Dynamic plugin feed unavailable; using local feed    error: Http request aborted
xdk:client:[2015-12-09T17:34:07.831Z]: (1449682447831): Component "client:cordova-registry" finished delayed initialization
client:appcenter-options:[2015-12-09T17:34:07.854Z]: (1449682447854): [TypeError: Cannot read property 'setTimeout' of null]
Node Webkit Error log:
[2120:1209/183326:INFO:CONSOLE(17)] ""xdk:client:[2015-12-09T17:33:26.042Z]: (1449682406042): Failed to load theme: xdk" {"code":"MODULE_NOT_FOUND"}", source: D:\Program Files\Intel\XDK\xdk\core-modules\private\logger.js (17)
[2120:1209/183326:INFO:CONSOLE(17)] ""xdk:client:[2015-12-09T17:33:26.104Z]: (1449682406104): Error SyntaxError: Unexpected token \r loading components\\client\\emulator\\locale\\root\\text-content.json"", source: D:\Program Files\Intel\XDK\xdk\core-modules\private\logger.js (17)
[2120:1209/183326:INFO:CONSOLE(989)] "" Unhandled rejection reasons (should be empty):" ["(no stack) [object Object]"]", source: file:///D:/Program%20Files/Intel/XDK/xdk/node_modules/q/q.js (989)
[2120:1209/183407:INFO:dispatcher_host.cc(154)] [NW.JS]RenderProcessWasKilled
XDK exit code & signal: 1, null
Crash minidump not found in XDK data folder. Falling back to TEMP...
Crash Minidump File: C:\Users\utente\AppData\Local\Temp\55f195c4-6093-4067-a473-e017bcd54615.dmp Wed Dec 09 2015 18:32:37 GMT+0100 (ora solare Europa occidentale)
Size in bytes: 475209
NW Crash Detected.
PaulF_IntelCorp
Is the XDK crashing or simply stopping? Looking at the log you posted, it appears to be crashing. Do you get a crash screen? If so, please do submit the crash, engineering looks at these very closely in order to understand the issue and fix the problem.
paolo_c_
The video is stopped on first blue module initializing...
the report that i have posted is relative after i terminate XDK on task manager.
I'm sorry this had confused, really I don't have any report
The start don't progress and in task manager I see 7 nv.exe *32 istance
Rodrigo_M_1
New Contributor II
I had the same problem here, I have uninstalled, reboot the computer and reinstalled back and it works again!
Some times, I have this issue and I just need to reboot the computer to get it working again...
Just give it a try by right click on the Intel Shortcut and select the option "Run as Administrator" to see if you can get it working....
By the way, working or not, I can note that there are 7 nv.exe *32 istance running on task manager... I don't know if it's normal or not...
paolo_c_
I have uninstalled, reboot the computer and reinstalled , not work
I Run as Administrator,not work
I'm desperate
help
paolo_c_
 i saw a different situation
at home the loading finish, ask me if i want connect
i continue but system reply no internet connection
my internet connection function
paolo_c_
ok Malwarebytes Anti-Malware remove problems
sorry and thanks
Rodolfo_N_
My Intel XDK installation didn't start after I moved from Lubuntu 15.10 (32 bits) to Lubuntu 16.10 (64 bits).
(Of course I installed also a new copy of Intel XDK)
Everything is now OK after installing Lubuntu 16.04 (64 bits)
My computer: 2xIntel Core CPU 2.4 GHZ, 4GB Ram
