Software Archive
Read-only legacy content
17060 Discussions
XDK not starting (Resolved?)
paolo_c_
He,
(This is an old problem I thought it was resolved but it is not so )
I have problem my XDK not starting more.
I have disinstalled and reinstalled but it is the same.
The XDK is stoppend in initializing...
In my task manager i see  seven nw.exe *32
can you help me?
thanks Paolo
debug.log
[884:0525/172401:INFO:CONSOLE(17)] ""xdk:client:[2016-05-25T15:24:01.394Z]: (1464189841394): Failed to load theme: xdk" {"code":"MODULE_NOT_FOUND"}", source: C:\Users\utente\AppData\Local\Intel\XDK\xdk\core-modules\private\logger.js (17)
[884:0525/172401:INFO:CONSOLE(17)] ""xdk:client:[2016-05-25T15:24:01.462Z]: (1464189841462): Error SyntaxError: Unexpected token \r loading components\\client\\emulator\\locale\\root\\text-content.json"", source: C:\Users\utente\AppData\Local\Intel\XDK\xdk\core-modules\private\logger.js (17)
[884:0525/172401:INFO:CONSOLE(989)] "" Unhandled rejection reasons (should be empty):" ["(no stack) [object Object]"]", source: file:///C:/Users/utente/AppData/Local/Intel/XDK/xdk/node_modules/q/q.js (989)
[884:0525/172406:INFO:CONSOLE(989)] "" Unhandled rejection reasons (should be empty):" ["Error: Could not locate the bindings file. Tried:\n \u2192 C:\\Users\\utente\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\ref\\build\\binding.node\n \u2192 C:\\Users\\utente\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\ref\\build\\Debug\\binding.node\n \u2192 C:\\Users\\utente\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\ref\\build\\Release\\binding.node\n \u2192 C:\\Users\\utente\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\ref\\out\\Debug\\binding.node\n \u2192 C:\\Users\\utente\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\ref\\Debug\\binding.node\n \u2192 C:\\Users\\utente\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\ref\\out\\Release\\binding.node\n \u2192 C:\\Users\\utente\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\ref\\Release\\binding.node\n \u2192 C:\\Users\\utente\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\ref\\build\\default\\binding.node\n \u2192 C:\\Users\\utente\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\ref\\compiled\\0.12.7\\win32\\ia32\\binding.node\n    at bindings (C:\\Users\\utente\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\bindings\\bindings.js:88:9)\n    at Object.\u003Canonymous\u003E (C:\\Users\\utente\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\ref\\lib\\ref.js:5:47)\n    at Module._compile (module.js:465:26)\n    at Object.Module._extensions..js (module.js:483:10)\n    at Module.load (module.js:360:32)\n    at Function.Module._load (module.js:315:12)\n    at Module.require (module.js:370:17)\n    at require (module.js:389:17)\n    at Object.\u003Canonymous\u003E (C:\\Users\\utente\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\ffi\\lib\\ffi.js:6:11)\n    at Module._compile (module.js:465:26)"]", source: C:\Users\utente\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js (989)
paolo_c_
I found this workaround
I start without a network then I connect
Jamal_A_
Try installing XDK in a different folder, for example: c:\intelXDK
If that does not work, it is possible the Windows user profile is corrupt; create another Windows user, then switch to the new user and install XDK.
HTH,
Jamal
Pamela_H_Intel
Paolo,
Try killing the node webkit instances (nw.exe). Then try installation again. You also might try downloading the installation executable again in case it got corrupted.
Installing XDK in a different directory may not work well.
Pamela
paolo_c_
thank you,
but still no network should be open?
paolo_c_
Pamela_H_Intel
Paolo - that is interesting . . . and strange. So, you are able to use XDK now?
paolo_c_
Very strange.
Now I can open XDK. I made a new project, but I have another problem. "No developer certificate found".
https://software.intel.com/en-us/forums/intel-xdk/topic/635123
Pamela_H_Intel
Paolo,
You have 3 accounts. The one you used today has multiple certs. You upgraded your Android cert on the 26th of May. Please screen shot your error message so I can see which window/process you are in when you see that.
Meanwhile - have you looked in the Account Manager to see your certs?
Pamela
