Software Archive
Read-only legacy content
17060 Discussions
Xdk audio record and upload do not work
Claude_M_
Good morning everyone
I m working on a iphone mobile application where i need to record audio and send the audio file to my server
I work with the "phonegap audio" intel xdk demo provided with the xdk software and when i try to upload the audio file after record
> i have always the same error message > "ERROR uploading file Cannot find the file for upload"
I've tried many differents solutions :
> i use intel.xdk.file.uploadToServer function and it work for the pictures files but not for the audio
> i use the media type > audio/x-wav to upload
> i v tried to add "intel.xdk.webRoot" to my source path audio file but its dont help
> i have tried other types of audio demos based on cordova but no one worked > i have other errors of audio recording
Here is my javascript upload code:
        var url= intel.xdk.webRoot+audioFileUrl
        intel.xdk.file.uploadToServer(url,serverRoot+"mobileTools/upload.php", "", "audio/x-wav", "updateUploadProgress");
The PHP
<?php
ob_start();
echo "<pre>";
print_r($_FILES);
print_r($_GET);
print_r($_POST);
echo "</pre>";
print_r("file type: " . $_FILES["Filedata"]["type"]);
$allowedExts = array("gif", "jpeg", "jpg", "png");
$temp = explode(".", $_FILES["Filedata"]["name"]);
$extension = end($temp);
if ((($_FILES["Filedata"]["type"] == "image/gif")
|| ($_FILES["Filedata"]["type"] == "image/jpeg")
|| ($_FILES["Filedata"]["type"] == "image/jpg")
|| ($_FILES["Filedata"]["type"] == "image/pjpeg")
|| ($_FILES["Filedata"]["type"] == "image/x-png")
|| ($_FILES["Filedata"]["type"] == "image/png"))
&& ($_FILES["Filedata"]["size"] < 9999999999)
&& in_array($extension, $allowedExts))
  if ($_FILES["Filedata"]["error"] > 0)
    echo "Return Code: " . $_FILES["Filedata"]["error"] . "<br>";
  else
    echo "uploads: " . $_FILES["Filedata"]["name"] . "<br>";
    echo "Type: " . $_FILES["Filedata"]["type"] . "<br>";
    echo "Size: " . ($_FILES["Filedata"]["size"] / 1024) . " kB<br>";
    echo "Temp file: " . $_FILES["Filedata"]["tmp_name"] . "<br>";
    if (file_exists("uploads/" . $_FILES["Filedata"]["name"]))
      echo $_FILES["Filedata"]["name"] . " already exists. ";
    else
      move_uploaded_file($_FILES["Filedata"]["tmp_name"],
      "uploads/" . $_FILES["Filedata"]["name"]);
      echo "Stored in: " . "uploads/" . $_FILES["Filedata"]["name"];
else
  echo "Invalid file";
  $data=ob_get_clean();
$fp=fopen("debug.txt","w+");
fputs($fp,$data);
fclose($fp);
I work on the last version of iphone app preview 2.3.3 and the last PC xdk software version
I you have some help this can save my life :)
Thanks you
Anusha_M_Intel1
If it cannot find the file for uploading, you might be having trouble accessing the root directory on your device.
Please refer to this stackoverflow posting: http://stackoverflow.com/questions/21321335/intel-xdk-directory-browsing
The second answer by xmnboy should give you a clue on how to go about this.
PaulF_IntelCorp
Here's a direct link to the answer Anusha is refering to: http://stackoverflow.com/a/21392617
