Software Archive
Read-only legacy content
17060 Discussions
Xeon Phi offload openmp segmentation fault
an__taewoo
I'm executing some simple Xeon Phi OpenMP codes.
(From https://software.intel.com/en-us/xeon-phi/mic/training)
#include <stdio.h>
int main(int argc, char* argv[])
  const int count=10;
  int a[count], b[count];
  int c=5;
  int d=7;
  for (int i = 0; i<count; i++)
    a=0;
    b = (i+1)*100;
  #pragma offload target(mic)
  #pragma omp parallel for
  for ( int i = 0; i < count; i++ )
    a[ i ] = b[ i ] * c + d;
    printf ("%d\n", a);
I tried to execute it, but my system just printed "segmentation fault". I wanted to debug it, so I tried to use gdb with core dump. But, I couldn't get any information.
Who could help me?
My system is
Host: i7-5820K, CentOS 7.6 (kernel: 3.10.0-957.el7.x86_64), MPSS 3.8.4, using icc in Parallel Studio XE 2016 Update4
Device: Xeon Phi 71S1P(miccinfo: B1PRQ-7110 P/X)
JJK
New Contributor III
what happens if you try
icc -g -o offload-code -std=c99 -qopenmp offload-code.c
gdb-ia offload-code
and then type 'r' to run the code?
(the sample code works on my boxen)
CSpot
Thanks to sharing these codes, but can you elaborate that what these codes are used for? Also, if you are willing to make your career in the IT department, earning CISCO certification, could help you out to gain better results.
an__taewoo
My computer printed
[root@localhost slide12]# /opt/intel/bin/gdb-ia offload-code
GNU gdb (GDB) 7.8-16.0.881
Copyright (C) 2014 Free Software Foundation, Inc; (C) 2013-2016 Intel Corp.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
and "show warranty" for details.
This GDB was configured as "x86_64-unknown-linux-gnu".
Type "show configuration" for configuration details.
For information about how to find Technical Support, Product Updates,
User Forums, FAQs, tips and tricks, and other support information, please visit:
<http://www.intel.com/software/products/support/>.For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from offload-code...done.
(gdb) r
Starting program: /root/Download/beginningslides-extractedcode/02_Offload_Compilation/slide12/offload-code
Catchpoint -2 (signal SIGSEGV), 0x00007ffff6ac9e9e in ?? ()
(gdb)
At that time, 'miccheck' printed "Status: OK". And more simple code(non-openmp offload printf) worked.
If I re-install MPSS with CentOS 7.3, could I get a good result?
JJK
New Contributor III
the same test program runs fine on my CentOS 7.6 (3.10.0-957.5.1.el7.x86_64) MPSS 3.8.4 box. You can find my binary at https://www.nikef.nl/~janjust/mpss/offload5
Can you try this binary and see whether it runs on your machine?
an__taewoo
I tried to run it, but it also printed what I had seen. I'll try to reinstall this system.
Thank you so much :D
