Software Archive
Read-only legacy content
17060 Discussions
address range partially overlaps with existing allocation
wang_p_1
These are my program's simplification,because my source code is so tedious.
// head.h
class CTest {
public:
float * array1;
float * array2;
int    Len1,Len2;
CTest();
void do();
​// head.cpp
float * ptr1=0;
float *ptr2=0;
CTest:: CTest( ) {
..do something
Len1 = something;
array1=new float [Len1];
array1 assignment
ptr1=array;
#pragma offload_transfer target(mic:0) in(ptr1:length(Len1) alloc_if(1) free_if(0)) signal(ptr1)
...do something
Len2=something;
array2=new float[Len2];
array2 assignment
#pragma offload_transfer target(mic:0) wait(ptr1) in(ptr2:length(Len2) alloc_if(1) free_if(0))
void CTest::do( ){
#pragma offload target(mic:0) nocopy(ptr1:length(Len1) alloc_if(0) free_if(0))\
nocopy(ptr2:length(Len2) alloc_if(0) free_if(0))
while(1);// this is the key point !
do something
I have already found that the error message was thrown by  "do" function."
the program will throw an error message: "address range partially overlaps with existing allocation"
I changed the  function   like this :
void CTest::do( ){
do something
It works well !
I'm a Chinese student, sorry for the bad English taking to your inconvenience.
wang_p_1
How can I fix the error :"address range partially overlaps with existing allocation"?
wang_p_1
It reports the error "address range partially overlaps with existing allocation", like below changing:
void CTest::do( ){
  printf("this message print out successfully \n");//used to debug
 // the while(1) loop would not block this routine !?
replace symbols used in next block for debugging,because offload clause don't include these symbol.
do something
TimP
In my cases, this failure is suppressed by arbitrarily keeping length() below about 60MB, but I don't think anyone proposes this as a solution.  It's been suggested (but not verified) that it may be due to older KNC hardware (e.g. KNC B0) not being the primary support target.
Rajiv_D_Intel
The offload that goes into an infinite loop on MIC is a synchronous offload, so once the CPU starts it, the program will block at that point.
If you make that offload asynchronous then you will observe execution proceeding past that point on the CPU, as shown by the print "Async offload successfully issued.
The program does block at program termination, waiting for all offloads to complete.
Here is the code:
#include <iostream>
//These are my program's simplification,because my source code is so tedious.
// head.h
class CTest {
 public:
  float * array1;
  float * array2;
  int    Len1,Len2;
  CTest();
  void doit();
// head.cpp
__declspec(target(mic)) float *ptr1=0;
__declspec(target(mic)) float *ptr2=0;
CTest:: CTest( )
 int Len1 = 10;
 array1[0:10] = 1.0; //array1 assignment
 ptr1=array1;
 //...do something
 int Len2 = 10;
 array2[0:10] = 2.0; //array2 assignment
 ptr2=array2;
void CTest::doit( )
  nocopy(ptr2:length(Len2) alloc_if(0) free_if(0)) signal(66)
 // do something
int main()
 CTest *ct = new CTest;
 ct->doit();
 std::cout << "Async offload successfully issued\n";
 return 0;
wang_p_1
Hi, Tim. Thks for your proposes.
There is a case below, it works well. This array size is 1GB.
I just want to find out the error's source that"address range partially overlaps with existing allocation".
#define LEN 4294967296
void print(int *p){
#pragma offload target(mic:0) in(p:length(LEN) alloc_if(1) free_if(1))
        for(int i=0;i<LEN;i++)
                p=p[i+1]+p;
int main(){
        int *p  =new int[LEN];
        print(p);
        return 0;
wang_p_1
Hi Rajiv, thank u very much .
I confused that the synchronous offload won't be blocked by an infinite loop. I want to find out where is  my program's error coming from, so I added the infinite loop. But the infinite loop can not works well , the "do" function report "address range partially overlaps with existing allocation".
Many thanks for all things you have done.
wang_p_1
thank you all.
I have already fix the bug: "address range partially overlaps with existing allocation"
I put CTest class member variable into the offload scope and I forgot declaring it using offload-attribute(target(mic)).
I just assign  these member variables to global variables, and declare these global variables using  offload_attribute.
