Software Archive
Read-only legacy content
android app extremely slow and iOS app heating and drains iPhone 6 battery
Renato_B_
I don't know what changed in the last Intel XDK updates, but something expressive really changed. Before these updates my apks run very well, smoothly and in the same velocity of the web browser. Now, a unique sprite that uses only a "bullet behaviour" move very slowly making the game unplayable. In the case of the ios apps, the device is heating and battery drain a few minutes later. Not to mention the fact the problems with cordova plugins. Sorry to ask but: why the Intel XDK became worse? Are you doing something to revert this situation? Do you have any idea how long to fix these issues? Thanks.
Renato_B_
I would like to know why I don't get answers for my questions? Could anyone from Intel team give me an answer, please? Thanks in advance.
John_H_Intel2
Without an apk or source code to attempt to reproduce the issue there is not a whole lot we can do except ask questions.
Did you rebuild your apk? Do you still have the old apk that works fine?
What device/OS are you testing on?
Do you see this on all devices? Which have you tested on?
Did your device recently get an update?
Did the plugins you are using get updated?
Did you alter the code or add other plugins?
Renato_B_
Thanks for the answer, John
Unfortunately I don't keep any old apk/ipa.
I'm testing the app in several devices, all of them updated.
APK - moto g, samsung tab 4, samsung tab pro
IPA - iPhone 6
In any of these android devices, the animations runs slowly, even more the samsung tab4/pro (unbelievably slow - the game was unplayable). The tests that I did with iPhone, the only problem I found was the device's heat (IMO is a big problem, but less than slowness).
In most applications I am using only the admob or revmob plugin and I only remove the code of intelxdkconfigadditions.xml because I'm using CLI 5.1. But I did some tests with CLI 4.2 and the problem the problem continued to happen.
PS: Could you visit us in the Scirra's forum to get a feedback from the Construct2 users?
John_H_Intel2
Are you building with Crosswalk for Android?
Do you have a link to a specific question you would like us to look at on the Scirra forums?
Renato_B_
Yes. I always use Crosswalk for Android.
I don't have a specific link. If search for something like "intel xdk" + "slow" or "lag" you'll get several post about this issue, like these links bellow:
https://www.scirra.com/forum/viewtopic.php?f=147&t=163388&p=990037&hilit=intel+xdk+android+slow#p990037
https://www.scirra.com/forum/viewtopic.php?f=147&t=163452&p=989763&hilit=intel+xdk+android+slow#p989763
https://www.scirra.com/forum/viewtopic.php?f=147&t=166272&p=1003117&hilit=intel+xdk+android+lag#p1003117
Some users are changing for Cocoon, despite them like to work with the XDK, because these problems. A long time ago, some guys from Intel usually go to the Scirra's forum to give us some support and get informations to improve the XDK, but they are gone.
Renato_B_
I still need some help with this issue. I'm waiting to publish my game for android with Intel XDK.
John_H_Intel2
Can you send a private message with a zip file that contains the entire project?
Renato_B_
For test only? Could be any capx?
John_H_Intel2
It needs to be a set of project files that exhibits the behavior you are experiencing.
PaulF_IntelCorp
Renato, see this FAQ and let us know if it helps > https://software.intel.com/en-us/xdk/faqs/crosswalk#crosswalk-animatable
Renato_B_
Thanks, Paul
I tried it, but the movement still very slow. The IPA is okay. The movement is perfect. The problem is the android version. If the problem was the game, the problem would be repeated in the IPA.
PaulF_IntelCorp
Not necessarily, the runtime environment on an iOS device is not the same as that on an Android device. It's like running your app inside two different browsers, where iOS is similar to Safari and Crosswalk is similar to Chrome. So there could be something you're doing in the game that is supported differently in Safari than it is in Chrome, for example.
There may be a Chromium command-line option that might help, see this blog for some pointers > http://blogs.intel.com/evangelists/2015/06/25/chromium-command-line-options-for-crosswalk-builds-with-the-intel-xdk/ -- especially those related to GPU operations.
Renato_B_
Paul,
I included the lines and I got:
9.8 FPS (8-15) with 15.2 mb GPU memory used
not including
9.6 (8-12) with 15.7 GPU memory
no change on game speed
PaulF_IntelCorp
Did you try the --ignore-gpu-blacklist option? See this list of options > http://peter.sh/experiments/chromium-command-line-switches/
Renato_B_
Yes, but I didn't succeed.
Any other possibility to fix it?
In Scirra's forum you'll find a several discussions about the perfomance of the applications built in the Intel XDX and comparisons with Ludei Cocoon. In all of them, who tried both, said the Cocoon is much better than XDK. How it's possible? What's the big difference between these two solutions and why XDK got worse suddenly?
PaulF_IntelCorp
Renato, can you provide some specific links to the Construct2 issues? Can you provide a sample app that we can work with to understand the issue better? Our test apps do not see this issue.
Renato_B_
Ok Paul. I'll send you a APK by PM with the game that I'm working now.
Renato_B_
Paul
Did you received the file?
PaulF_IntelCorp
Yes, sorry Renato, I have lots of non-forum work to do, as well, so it takes me a while to get to more complicated issues.
PaulF_IntelCorp
Renato -- try adding the --ignore-gpu-blacklist option to your additions file. See this FAQ > https://software.intel.com/en-us/xdk/faqs/crosswalk#crosswalk-animatable
Beginning with the CLI 5.1.1 build system you must add the --ignore-gpu-blacklist option to your intelxdk.config.additions.xml file if you want the additional performance this option provides to blacklisted devices.
