Software Archive
Read-only legacy content
17061 ディスカッション
cilkscreen showing races on reducers
Aamir_Shafi
ビギナー
422件の閲覧回数
This seems weird, but cilkscreen reports data race on reducer variable. The code, and corresponding output of cilkscreen is shown below.
user@velour:~/tmp/cilk_tests$ cat reducer_test.c
#include
#include
#include
#include
#include
using namespace std;
cilk::reducer_opadd total(0);
int main() {
const int STAT_SIZE = 2;
const int N=10;
cilk_for(int i=0 ; i
total += 1;
cout << "total =" << total.get_value() << endl;
return 0;
user@velour:~/tmp/cilk_tests$ icpc -g reducer_test.c
user@velour:~/tmp/cilk_tests$ icpc -V
Intel C++ Intel 64 Compiler XE for applications running on Intel 64, Version 12.0.1.107 Build 20101116
Copyright (C) 1985-2010 Intel Corporation. All rights reserved.
user@velour:~/tmp/cilk_tests$ cilkscreen ./a.out
Cilkscreen Race Detector V2.0.0, Build 1113
Race condition on location 0x6024c0
write access at 0x4014a8: (~/aamirshafi/intel/composerxe-2011.1.107/compiler/include/cilk/reducer_opadd.h:320, cilk::reducer_opadd::operator+=+0x30)
read access at 0x4014a2: (~/aamirshafi/intel/composerxe-2011.1.107/compiler/include/cilk/reducer_opadd.h:320, cilk::reducer_opadd::operator+=+0x2a)
called by 0x7f7d6110860d: (__$U2+0x9d)
called by 0x7f7d611083a0: (cilk_for_recursive+0x100)
called by 0x7f7d61108739: (__$U0+0x99)
called by 0x7f7d61108089: (__cilkrts_cilk_for_32+0xf9)
called by 0x400fa1: (~/aamirshafi/tmp/cilk_tests/reducer_test.c:16, main+0x65)
total =10
2 errors found by Cilkscreen
Cilkscreen suppressed 16 duplicate error messages
Cant tell the version of the cilkscreen since using -v option gives an error. But the cilkview version info is below:
user@velour:~/tmp/cilk_tests$ cilkscreen -v
E:Unable to load ~/aamirshafi/work/install/cilkutil/bin/../lib32/cilkscreen-tool.so: libimf.so: wrong ELF class: ELFCLASS64
user@velour:~/tmp/cilk_tests$ cilkview -v
cilkview v2.0.1049.0
Copyright (c) 2010 Intel Corp. All rights reserved
user@velour:~/tmp/cilk_tests$ uname -a
Linux velour 2.6.29-tps+perfctr+fpufix #1 SMP Sat Sep 4 22:20:28 EDT 2010 x86_64 GNU/Linux
--Aamir
0 件の賞賛
2 返答(返信)
Brandon_H_Intel
従業員
422件の閲覧回数
Hi Aamir,
I can reproduce the problem with Cilkscreen, and I've submitted a problem report to the Cilk Plus team. I'll update the thread when they have any updates.
Brandon_H_Intel
従業員
422件の閲覧回数
If you compile now with the C++ Composer XE 2011 update 8 and get the latest version of the Cilk Plus SDK, this problem should now be resolved.
返信
