Software Archive
Read-only legacy content
17060 Discussions
debuggable property reverting to false when I build
Matthew_E_
Hi all,
Trying to debug a built app on Android 5.0. In XDK, I've set the debuggable property to "true," save, and then go to build tab as per normal. After the build is done, if I return to the Develop tab and check on the xml file, the debuggable property has been reverted to "false."
Any idea why this would happen? Anyone else had this issue?
Mepler
Swati_S_Intel1
You have to set debuggable=true in the intelxdk.config.additions.xml file. <preference name="debuggable" value="true" />
If you set it in intelxdk.config.xml it will get overridden by the default settings. Also, remember to set it back to false before publishing your app to the store.
Matthew_E_
Ah, thanks. I did not see there were two files. A little confusing but now that you've pointed it out I'll give it a try!
