Software Archive
Read-only legacy content
error #10310: Failed to enable trusted storage check for licensing
Darren_R_
It looks like this is a known problem with the evaluation version on x64 systems (see https://software.intel.com/en-us/forums/topic/531047).
I am experiencing the same error message when I type the command
ifort -v
Cheers,
Darren
Hubert_H_Intel
Darren,
Thanks for letting me know. As explained in the mentioned forum thread you can alternatively activate/install Intel® Parallel Studio XE 2015 products with using the license file. I'll send it to you offline. Please restart the installer and use the license file then (Activation Option: 'Alternative optiones > Use license file').
Please let me know if this helps.
Regards, Hubert.
Darren_R_
Thanks for the quick reply Hubert.
When I run parallel_studio_xe_2015_setup again, it reports
Error while extracting file C:\Program Files (x86)\Intel\Downloads\parallel_studio_xe_2015_setup\installs\composer_xe\108\w_cprovsshell_2010\VSIntShell.exe
Crc is mismatched.
Is there an uninstaller I can run first before trying setup again?
Cheers
Darren
Hubert_H_Intel
Which file is CRC mismatched? The main full offline installer package? Could you please provide the full output of the chksum of the package you downloaded?
If you kept the temporary directory when you ran the package the first time you can start the
   c:\Program Files (x86)\Intel\Download\<packagid>\setup.exe
again and choose 'Remove'.
Hubert.
Darren_R_
The temporary directory was deleted after the installer completed the first time.
The hash values of the setup file are
MD5: bcd1c27e61ec7a496a32e47ef41af4fe
SHA-1: 60dea952c1ff9d4fa19e37dc687165c2e9c6457b
Cheers,
Darren
Darren_R_
I used Windows 'Remove Program' to uninstall parallel studio. The installer then ran without error and I could use the supplied licence file.
However, I did have to make the change as described here https://software.intel.com/en-us/forums/topic/365799#comment-1757443 to get the debugger working with VS Shell 2010.
Thanks for the help Hubert,
Darren
