- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
I use compaq v 2000 and I bought 20.1 inch of monitor.
but the problem is that my graphic option has no 1680 x 1050
how can I do that please let me know
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Go to
http://softwarecommunity.intel.com/Wiki/Graphics/239.htm
Come back here with questions. I can probably help.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Raw EDID base
00: 00 FF FF FF FF FF FF 00 4E 14 11 20 85 07 00 00
10: 0D 11 01 03 6C 2B 1B 78 EA C5 C6 A3 57 4A 9C 23
20: 12 4F 54 BF EF 80 71 40 81 40 95 00 B3 00 81 CF
30: 81 0F 81 4F B3 0F 7C 2E 90 A0 60 1A 1E 40 30 20
40: 36 00 B1 0E 11 00 00 00 00 00 00 FD 00 38 4C 1E
50: 55 0E 00 0A 20 20 20 20 20 20 00 00 00 FC 00 53
60: 63 65 70 74 72 65 20 20 0A 20 20 20 00 00 00 FC
70: 00 58 32 30 57 47 2D 31 30 38 30 50 0A 20 00 00
this is mine but I cant make sence the DTD
which is going to my DTD?
furthermore
how can I replace to igxp32.inf
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I'd go with
7C 2E 90 A0 60 1A 1E 40 30 20 36 00 B1 0E 11 00 00 1A
I replaced the last 00 (which was clearly bogus) with 1A. If you get flicker, vary that last hex number from 18, 1A, 1C, 1E.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
thank you
buy Im still complicate about
HKR,, DTD_5,%REG_BINARY%, 00, 00, 00 ,00, 00, 00,00, 00, 00,00, 00, 00,00, 00, 00,00, 00, 00,00, 00;Fifth DTD
this things.
what should I do?
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
hey I did it thank you so much
I can see some kinda flickering but thats not big deal thank
you again
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
thanks a lot !!!!
Im trying to figure the quality out now
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I have a Starlogic 20.1" LCD. It supports upto 1680x1050 resolution.
Thevideo card on my Dell Latitude D410 is 915GM/GMS, 910GML Family.
Here is my MonInfo results
Raw EDID base
00: 00 FF FF FF FF FF FF 00 4C A3 58 4A 00 00 00 00
10: 00 0F 01 03 80 19 12 78 0A 87 F5 94 57 4F 8C 27
20: 27 50 54 00 08 00 01 01 01 01 01 01 01 01 01 01
30: 01 01 01 01 01 01 64 19 00 40 41 00 26 30 18 88
40: 36 00 F6 B8 00 00 00 19 00 00 00 0F 00 00 00 00
50: 00 00 00 00 00 18 EE 02 74 00 00 00 00 FE 00 54
60: 44 34 31 39 00 31 32 31 58 4A 0A 20 00 00 00 FE
70: 00 EC D3 C5 B7 91 68 42 00 01 01 0A 20 20 00 19
I believe my DTD is
64 19 00 40 41 00 26 30 18 88 36 00 F6 B8 00 00 00 19
And since I want 1680x1050. So I changed the DTD a little bit.
64 19 90 40 61 1A 26 40 18 88 36 00 F6 B8 00 00 00 19
But unfortunately, I got out of sync/blank screen problem.
I couldn't find modeline info on this monitor on google. But I do have a linux box that works flawless with this monitor (i.e.I can do 1680x1050). Is there anything else I can try??
FYI, the Intel driver didn't work for me. I am using the latest video driver from Dell. Ver. 6.14.10.4693. (9/15/2006). and the file I had to modify is ialmnt5.inf. But everything looks exactly the same as the other link described.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
archibael, thanks for your reply.
From another thread "945GM not working with my 1680x1050 monitor" I found a DTD string that works with the 20.1" starlogic (1680x1050@60Hz)
21 3990 30 62 1A 27 40 68 B0 36 00 DA 28 11 00 00 1C37 01
(You were the one provided the DTD. thanks again)
Acutally after reading that thread, I realized that the EDTD data that I reported was my laptop's monitor's. And the starlogic doesn't have the EDTD. Luckily there is something that could work!!
In case someone may be inerested. This is my xorg.conf. I actually entered them myself according to the spec listed in the user manual.
Section "Monitor"
Identifier "Monitor0"
ModelName "StarLogic 1680x1050"
HorizSync 31.5 - 80.0
VertRefresh 50.0 - 75.0
Option "dpms"
EndSection
But it seems I need more information in order to generate the DTD.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
(**) NV(0): *Default mode "1680x1050": 146.2 MHz, 65.3 kHz, 60.0 Hz
(II) NV(0): Modeline "1680x1050" 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync
I guess this is what you are talking about. I will try to see if I can come up with a better DTD for my monitor. This is really cool
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
