Software Archive
Read-only legacy content
17060 Discussions
how get my SHA-1 in xdk with xdk signing cert - android...
Victor_I_2
how get my SHA-1 in xdk with xdk signing cert - android... I want it for Cordova App Google Signin...well ???
Certain Google Play services (such as Google Sign-in and App Invites) require you to provide the SHA-1 of your signing certificate so we can create an OAuth2 client and API key for your app. To get your SHA-1, follow these instructions:
keytool -exportcert -list -v \
-alias androiddebugkey -keystore %USERPROFILE%\.android\debug.keystore
https://developers.google.com/android/guides/client-auth
Anthony_H_Intel
You can download your keystore from the Intel XDK, then use keytool to obtain the SHA-1:
See here for more information about managing certificates using Intel XDK.
Leonidas_S_1
Where keytool located, from where run it and where put keystore file?
Is it in jdk or jre?
Leonidas_S_1
https://github.com/EddyVerbruggen/cordova-plugin-googleplus/issues/341
Why getting keystore no exist??  ^^^^ here
Same getting using forward slash... as separator... is it alias wrong?? Or...? From git bash win 10 pro prompt. ..
Keystore file name can have dashes using it in cmd line ? Eg andoid-key12.keystore
Victor_I_2
WELL where is the problem in #4...
Victor_I_2
I think problem solved at last ...
success test and in device
Giselle_G_Intel
Victor,
Could you explain or select what helped you solve your problem, so that other users with a similar problem can use your solution?
