Software Archive
Read-only legacy content
17060 Discussions
how to uninstall Intel Parallel studio
meliann
I tried to uninstall Intel parallel studio using the "uninstall.sh" inside the "parallel_studio_xe_2011" directory. It said
ERROR: can't detect uninstall script
Product uninstalled. Press to exit...
The directories are still there. I want to reinstall the Parallel Studio, shall I remove the directories or start installation without removing them?
I use Scienific Linux 5.5, x86_64 system.
Vladimir_T_Intel
If you were installing the product in the root mode, you should remove the product directory and clean-up the rpm data base:
rpm q | grep intel
identify the appropriate packages and uninstall them:
rpm e
