Software Archive
Read-only legacy content
17060 Discussions
iOS Build failed version 3088
Honda20
Hi, Im getting build failed, im currenly using version 3088, when I opened the log i see (Build Log below).
I'm using Cordova CLI 5.4.1. I tried Target version 7, 8,.0, 9.0, 9.2 all not working.
Can you please assist. Thanks
Build Log
Building a Cordova 5.4.1 application.
Using platform cordova-ios 4.0.1.
The application name is "testapp"
The package name is "xdk.intel.blank.testapp"
Plugin "cordova-plugin-device" (1.1.1) installed.
Plugin "cordova-plugin-inappbrowser" (1.3.0) installed.
Plugin "cordova-plugin-splashscreen" (3.2.1) installed.
Plugin "cordova-plugin-device-orientation" (1.0.2) installed.
Plugin "cordova-plugin-network-information" (1.2.0) installed.
Honda20
Hi Paul F. Please can you look into this issue. I got a iOS build failed but it doesn't says any error on the logs.
Anusha_M_Intel1
Is that the extent of your build log? Do you get an external build log which is like 5 pages long? If so, could you attach it to your next post? The minimum target version for cordova-ios if 8.0.
Honda20
Hi Anusha, I dont see any external build log. Where do I navigate to open external build log please.
PaulF_IntelCorp
Honda -- see screen capture below:
Honda20
Thanks Paul. I found the issue. The certificate/provision expired, I re-created my certificate/provision and it build successfully. The link to logs doesn't show when the certificate/provision expired.
