Software Archive
Read-only legacy content
17060 Discussions
iOS build - switching between ad_hoc and production
Marek_Š_
yesterday I built a project for iOS under production profile - it required to upload production Apple certificate on the build screen. Today, I wanted to build another project using ad_hoc profile as it's not finished yet (I did it many times before for this project). Unfortunately it looks like the production certificate, I uploaded for different project yesterday, is used for this one as well as my build crashes with the error message:
Signing Identity:     "iPhone Distribution: Foxtrot Technologies s.r.o. (TR9X822V33)"
Provisioning Profile: "Testy_adhoc"
                      (e272f795-f572-4bbd-a363-bc690e4d9c8e)
    /usr/bin/codesign --force --sign 3BF861F3161BE03354E667124B416CE4E46DF802 --resource-rules=.../Testy/platforms/ios/build/device/Testy.app/ResourceRules.plist --entitlements .../Testy/platforms/ios/build/Testy.build/Release-iphoneos/Testy.build/Testy.app.xcent .../Testy/platforms/ios/build/device/Testy.app
3BF861F3161BE03354E667124B416CE4E46DF802: no identity found
Command /usr/bin/codesign failed with exit code 1
** BUILD FAILED **
Does it mean I have to upload certificates each time I work on a project with different profile - ad-hoc / production?
Marek
John_H_Intel2
I see you have some successful builds and assume that you have got the issue fixed?
Expired cert?
Marek_Š_
I am not sure, it's an "issue" - the approach is very simple - in case I want to build ad-hoc, I have to upload ah-hod Apple certificate, in case I want to build production (AppStore) I have to upload production certificate. I was just surprised, that the certificates are not linked to build type from the build profile (adhoc / production) as provisioning files are and that they are shared between projects. So, that's why I asked ....
Marek
John_H_Intel2
You should be able to use the same iOS distribution cert for ad hoc and production builds, as long as each provisioning profile was created with the same cert.
Marek_Š_
Thanks John for the comment, I'll review my certificates / p. profiles and I'll test it.
Marek
Marek_Š_
I rebuilt the p. files and tested the build - it works great. Thanks a lot.
Marek
