Software Archive
Read-only legacy content
17060 Discussions
iOS issue
Marcondes__Marcos
Hello
I got issue on iOS itunes ... .same code on Android with sucess !
Error message and app code attached
Thanks in advance for support and help me
Marcos
PaulF_IntelCorp
/*jslint browser:true, devel:true, white:true, vars:true */
function onAppReady() {
    if( navigator.splashscreen && navigator.splashscreen.hide ) {   // Cordova API detected
        navigator.splashscreen.hide() ;
    var el ;
    el = document.getElementById("idColaboradores") ;
    el.addEventListener("click", eventColaboradores, false) ;
    el = document.getElementById("idCaes") ;
    el.addEventListener("click", eventCaes, false) ;
    el = document.getElementById("idGatos") ;
    el.addEventListener("click", eventGatos, false) ;
...etc...
document.addEventListener("deviceready", onAppReady, false) ;
// see https://github.com/apache/cordova-plugin-inappbrowser#cordovainappbrowseropen
var eventColaboradores = function() {
    // add code here to check to see if the network is available and usable
    // before doing the following...
    var url = "http://www.carolzerbini.com.br/colaboradores/colaboradores.asp" ;
    var target = "_self" ;              // or "_blank" or "_system", see docs for more
    var options = "location=off" ;      // see docs for more
    var ref = cordova.InAppBrowser.open(url, target, options) ;
    // add code here to clean up, do other appropriate things, etc.
var eventCaes = function() {
    var url = "http://url/to/caes" ;
var eventGatos = function() {
    var url = "http://url/to/gatos" ;
...etc...
Marcondes__Marcos
Works perfect for 1 option BUT not for more than !
My problem now is when there more than 1 option
If user press Cães go to Caes page
If user press Gatos. go to Gatos page
If user press .... and so on
thanks in advance
Marcos
PaulF_IntelCorp
    var el ;
...etc...
...etc...
Marcondes__Marcos
Thanks for all support on this issue
I could send to itunes
Waiting for review
I update asap I get Apple approval or rejection
Marcos
Marcondes__Marcos
YESSSSSSSSSSS
Problem resolved and all set on itunes.com .... approved Thanks God and Paul :-)
Stefano_C_
Hi everybody,
I have the same issue, but I need to post a form to my webpage for processing.
How can I apply this method to a <form method="post" action="http://mysite.ext"> ?
Many thanks for sure help
Stefano
PaulF_IntelCorp
Stefano -- I recommend you search the web and Stack Overflow for something like "using <form> to post data in cordova phonegap app" to find a solution that works for your situation. There are many ways to accomplish what you want to do, all very dependent on the nature of your data, your app and your server. The XDK builds a standard Cordova (aka PhoneGap) app, so solutions you find for Cordova and PhoneGap will also apply to the XDK.
Stefano_C_
Thanks Paul,
I try again to find a solution for the reject message from Apple when I try to publish:
"Thank you for your resubmission. We noticed that your app is still not in compliance with our guideline.
Performance - 2.1
We discovered one or more bugs in your app when reviewed on iPhone and iPad running iOS 10.2.1 on Wi-Fi connected to an IPv6 network."
Since now I've find a lot of suggestions, but no one is accepted by Apple
