Software Archive
Read-only legacy content
17060 Discussions
iOS production legacy not including any icons
sebastian_r_
Hi.
I have a project i just finished but when i build the project into a distributable zip for the app-store, the zip will not
include any of the icons. It will give you only black png`s for the icons, even if you upload them all again.
Please any help.
John_H_Intel2
A couple things:
How are you coming to this conclusion? Unzipping and looking at the files? You can not unzip the package before uploading via application loader. It is a signed zip. Google for the black icon issue, that is how the builds are submitted. Dont has me how or why, but when you upload to the store they look fine.
Second, did you see all the notifications about legacy builds being deprecated? They will be removed from the build system altoghether soon. You should be building with the Cordova builds.
sebastian_r_
Thanks for the info.
Is there any manual or tutorial for old users having to switch to the new Cordova environment ?
PaulF_IntelCorp
There is no doc for upgrading from legacy to Cordova. By and large, the method of programming is the same. In general, you'll find lots of information out there for Cordova. The main differences are the fact that you can use third-party plugins and how you configure the build system is different.
sebastian_r_
Thanks Paul. Hey Intel team, the bug is still there. I changed the icons carefully, then sent the build to apple, they approved and sadly, the
icon for the app is the INTEL icon, not the one i provided. I´m using an ipad 2. Thanks.
PaulF_IntelCorp
The current version of the XDK should insert your icons into the project. Are you using the icon and splash screen tools on the Projects tab? We have many people that have successfully built iOS apps and submitted them to the Apple store, so I'm not clear on what bug you are referring to.
sebastian_r_
Hi Paul. You`re right, many people and even myself, have sent apps succesfullly to the appstore. So the first time this happened, i thought that it was
that i just forgot to include one of the icons, so i made it again, and carefully selected the icons on the projects tab. But again, after the apple approval process, i downloaded the app and sadly, the icon is not correct.
sebastian_r_
Also, there are two dialogs that ask for the icons. One on the project tab, and one on the build menu, under assets. Which one is the most important, or we have to put the icons on both ?
thanks.
PaulF_IntelCorp
Sebastian, please see this thread (which I believe you are also one) for an answer regarding some missing iOS icons: https://software.intel.com/en-us/forums/topic/559079
Regarding icons on the build tab, that implies you are using the Legacy build tile, not the Cordova build tile (my instructions above apply to the Cordova build tile). Please do not use the Legacy build tile unless you have a significant reason to keep using it. That build system is not being maintained and will disappear. We ask that all users migrate their apps to the Cordova build system. There is no way to upload icons using the Cordova build tile, only by setting them up on the Projects tab and using the additions.xml file (per the other forum thread reference).
