$ icc --version
icc (ICC) 12.0.0 20101006
Copyright (C) 1985-2010 Intel Corporation. All rights reserved.
I wrote a simple program (fib.c), which is attached.
I compiled as
$ icc fib.c -o fib
Then I tried to run and got:
$ ./fib
./fib: error while loading shared libraries: /home/bradley/intel/composerxe-2011.0.084/compiler/lib/intel64/li\\
bcilkrts.so.5: cannot restore segment prot after reloc: Permission denied
It works OK with an older runtime:
$ LD_LIBRARY_PATH=/opt/intel/compilerpro-12.0.0.025/compiler/lib/intel64 ./fib 5
fib 5=5
and it even gets speedup.
Any ideas what I've done wrong?
链接已复制
I tried to reproduce your case here, but I didn't find error like what you said above. See below output:
[wchen18@dpd26 ~]$ LD_LIBRARY_PATH=/opt/spdtools/compiler/cpro/Compiler/12.0/084/composerxe-2011.0.084/compiler/lib/intel64 ./fib 5
fib 5=5
[wchen18@dpd26 ~]$
Could you check your environment again?
Wise
Based on the error message, I suspect that SELinux* has a problem with the runtime shared object. Is it possible to try setting SELinux to permissive and see if that allows the library to load? I'm working on try to reproduce here.
OK, I have a system set with SELinux on "targeted" settings, and it works.
[cilk]$ icc -V fib.c -o fib
Intel C Intel 64 Compiler XE for applications running on Intel 64, Version 12.0.0.084 Build 20101006
Edison Design Group C/C++ Front End, version 4.1 (Oct 6 2010 18:42:54)
Copyright 1988-2009 Edison Design Group, Inc.
GNU ld version 2.17.50.0.6-5.el5 20061020
[cilk]$ ./fib 5
fib 5=5
I can't do "strict" on the lab machines because it does weird things with the network. If changing the SELinux setting on your system works, maybe I can work with you to get the specific system settings to try to reproduce.
What's up with selinux and icc anyway?
