Software Archive
Read-only legacy content
ifort: error #10310: Failed to enable trusted storage check for licensing: intel parallel studio xe 2015 evaluation version
Christian_W_
I have the same problem using the evaluation version (w_fcompxe_2015.0.108.exe)  downloaded today as explained in: https://software.intel.com/en-us/forums/topic/531047 and https://software.intel.com/en-us/forums/topic/531589.
I'm getting the error message "ifort: error #10310: Failed to enable trusted storage check for licensing".
Thank you very much for your help.
Christian
QIAOMIN_Q_
   I will send you the license file for product instalaltion/activation. Please restart the installer and use the license file then (Activation Option: 'Alternative optiones > Use license file')..
Thank you.
QIAOMIN.Q
Intel Developer Support
Please participate in our redesigned community support web site:
User forums:                   http://software.intel.com/en-us/forums/
Christian_W_
Hello Qiaomin, thank you for your help. Now I need your advise how to update the flexlm server. Could you provide a link where it to download? And does the evaluation version really need a licenses server? And I'm worrying if updating the flexlm would probably cause problems with other programs using it? Thank you very much Christian
QIAOMIN_Q_
Hello Chris,
  I have sent you the license file for product instalaltion/activation. Please restart the installer and use the license file then (Activation Option: 'Alternative optiones > Use license file')..
Thank you.
QIAOMIN.Q
Christian_W_
Hello Qiaomin,
thank you very much for your support. It works perfectly. I tested it today.
Best regards
Christian
Guohong_Y_
hello:
my email is yiguohong@live.com
today,I was downloaded the intel c/c++ compiler the lasted version 2015 update 2.
icl: error #10310: Failed to enable trusted storage check for licensing:
thank you !
Feilong_H_Intel
Hi Guohong,
I sent the license file to you a minute ago.
charles_h_
Please send me the license file.
Feilong_H_Intel
Hi Charles,
Please send serial number to me via private message.
