Good day guys,
I'm developing an application and found a rare behaviour with the designer. The footer goes above of the screen when the virtual keyboard appears (Ionic Keyboard plugin installed from this https://github.com/driftyco/ionic-plugin-keyboard). I did different tests to reproduce this issue and this are my results. I attach an image with the problem and the code
Note: when I create the project without designer , this worked very well with the solutions that I put in the links.
I hope that you can help me.
very thanks
Sincerely,
Diego Ramirez
- Tags:
- HTML5
- Intel® XDK
What is the wrong in the screenshot? It seems fine.
Good day,
I solved this using this phonegap plugin developed by the ionic team
Great. The keyboard plugin mentioned allows you to have the keyboard not push your entire content up but instead hover over it.
Topic Options
