Software Archive
Read-only legacy content
17060 Discussions
intel xdk designer with Ionic framework
Diego_Alejandro_R_
467324
Good day guys,
I'm developing an application and found a rare behaviour with the designer. The footer goes above of the screen when the virtual keyboard  appears (Ionic Keyboard plugin installed from this https://github.com/driftyco/ionic-plugin-keyboard). I did different tests to reproduce this issue and this are my results. I attach an image with the problem and the code
Note: when I create the project without designer , this worked very well with the solutions that I put in the links.
I hope that  you can  help me.
very thanks
Sincerely,
Diego Ramirez
Chris_P_Intel
What is the wrong in the screenshot?  It seems fine.
Diego_Alejandro_R_
Good day,
I solved this using this phonegap plugin developed by the ionic team
Elroy_A_Intel
Great. The keyboard plugin mentioned allows you to have the keyboard not push your entire content up but instead hover over it.
