Software Archive
Read-only legacy content
17060 Discussions
intel.xdk.device do not compile on server!
Thomas_V_1
Hi, I can not get the intel.xdk.device plugin to compile on server with DEBUG, TEST(mobile) or BUILD. This is for Android, ver 2548, cli 5.1.1. I tried two different projects and I get the same fault (From DEBUG see below). Can anyone verify if the problem so I know its not my fault?
-compile:
    [javac] Compiling 16 source files to .../appanalyzer/platforms/android/bin/classes
    [javac] .../appanalyzer/platforms/android/src/com/intel/xdk/device/Device.java:277: error: cannot find symbol
    [javac]         final ViewGroup parent = (ViewGroup)webView.getView().getParent();
    [javac]                                                    ^
    [javac]   symbol:   method getView()
    [javac]   location: variable webView of type CordovaWebView
    [javac] .../appanalyzer/platforms/android/src/com/intel/xdk/device/Device.java:378: error: cannot find symbol
    [javac]         webView.getView().setOnKeyListener(webViewListener);
    [javac]                ^
    [javac] Note: Some input files use or override a deprecated API.
    [javac] Note: Recompile with -Xlint:deprecation for details.
    [javac] Note: .../appanalyzer/platforms/android/src/com/intel/xdk/device/Device.java uses unchecked or unsafe operations.
    [javac] Note: Recompile with -Xlint:unchecked for details.
    [javac] 2 errors
BUILD FAILED
.../android-sdk-linux/tools/ant/build.xml:720: The following error occurred while executing this line:
.../android-sdk-linux/tools/ant/build.xml:734: Compile failed; see the compiler error output for details.
Total time: 6 seconds
.../appanalyzer/platforms/android/cordova/node_modules/q/q.js:126
                    throw e;
Error code 1 for command: ant with args: release,-f,.../appanalyzer/platforms/android/build.xml
John_H_Intel2
Do you have other plugins included that could be conflicting with the intel.xdk.device plugin?
Try creating a new blank app, add the device plugin, and try building that. It worked for me.
Thomas_V_1
Thanks John.
I made a new test project with only inte.xdk.device and I have the same fault.
hmmm
Thomas_V_1
Downgraded to cli 4.1.2 and the test project compiles.
Thomas_V_1
also downgraded intel.xdk.device 1.2.5 to 1.2.4.
for my project i downgraded
cli to 4.1.2
and
device to 1.2.4
and
cordova-plugin-statusbar1.0.0  to   org.apache.cordova.statusbar0.1.9
and it works.
Thomas_V_1
The app is a lot more stable and the bugs I see are my bad programming(for now).
Thanks for the help.
