Software Archive
Read-only legacy content
17060 Discussions
ios indexeddb problem
Jörg_G_
i develop a Little app with an indexedDb Database. I am Import the plugin: "cordova-plugin-indexedDB" (0.1.2) and the IDE automatic Import the plugin "cordova-plugin-websql" (0.0.10).
On emulate Devices the app works fine. On Chrome too. The build end wiht no Errors and i can install the app on my iPhone 6 IOS 9.3.2. The App starts but no data stored in the database.
Build Log
  • Building a Cordova 5.4.1 application.
  • Using platform cordova-ios 4.0.1.
  • The application name is "dumbo"
  • The package name is "de.schumannsolutions.u18"
  • Plugin "cordova-plugin-statusbar" (2.1.0) installed.
  • Plugin "cordova-plugin-device" (1.1.1) installed.
  • Plugin "cordova-plugin-splashscreen" (3.2.0) installed.
  • Plugin "cordova-plugin-indexedDB" (0.1.2) installed.
  • Plugin "cordova-plugin-websql" (0.0.10) installed.
  • Targeting iOS version 8.0.
any idea ? Thanks
PaulF_IntelCorp
Many people prefer to use the SQLite plugin (see the featured plugins list -- cordova-sqlite-storage).
Valerio_P_1
This is the code to work with Android and IOS. The "Cordova VKWebView Engine" is incompatible with IndexedDB then you do not use it.
document.addEventListener(
    "app.Ready",
    function(){
         if(window.device.platform !== 'Android'){
            window.shimIndexedDB.__useShim();
        createLocalDB();
    false
var db=null;
function createLocalDB(){
    db=null;
    var indexedDB = window.indexedDB || window.mozIndexedDB || window.webkitIndexedDB || window.msIndexedDB || window.shimIndexedDB;
    var request = indexedDB.open(LOCAL_DB_NAME, LOCAL_DB_VERSION);
    request.onupgradeneeded = function(){
        db = request.result;
        // from heare, create your objectStore
    request.onsuccess = function(){
        console.log("Success");
    request.onerror = function(){
        console.log("Error in indexedDB");
Daniele_A_
up ^ i have the same problem in iphone with ios 9 ... when i try to create database he can't i use various plug in no way....There is news about ios and indexdb?? Wich plug in it's best to use? Regards
