Software Archive
Read-only legacy content
17061 Discussions
large APK size when building with Cordova CLI
Edo_F_
AFTER update 3900 , im trying to build APK using cordova-cli with package from intel xdk, and im shocked with size APK.
see the screenshot : http://prnt.sc/ekymic
PaulF_IntelCorp
Edo -- those two numbers do not make sense. It looks to me like one is a Crosswalk build and one is not. To check that theory, unzip each into separate folders (an APK file is a ZIP file) and see what's inside the "lib" folder in the unzipped output. If you see Crosswalk libraries in one, but not the other, my theory is correct. If not, something else is going on.
Did you want to build for Crosswalk?
p.s. I've also changed the title of this post to be more descriptive of the issue.
Edo_F_
i guess that , because im type 'cordova build' or 'cordova build android' thats same, i got big size apk.
another way build without crosswalk at CLI ?
Edo_F_
i wont build for crosswalk sir , thats why im uncheck 'crosswalk' at intel xdk when im build with cloud.
PaulF_IntelCorp
Could you share the config.xml in your Cordova CLI project?
PaulF_IntelCorp
Edo -- I've confirmed that there is a problem with the exported config.xml file that is adding in the Crosswalk plugin, regardless of the state of the Crosswalk optimization choice in your Build Settings. See this thread for more details > https://software.intel.com/en-us/forums/intel-xdk/topic/720917 < I'm closing this thread and in favor of that other thread.
