Software Archive
Read-only legacy content
17060 Discussions
logical to integer
wstephens
What's the easiest and clearest way to convert a logical in the following way:
.false. to 0
.true. to 1
I tried the following code with interesting results:
PROGRAM X
LOGICAL L
L = .TRUE.
WRITE(*,*) L,(-L),(-1*L)
! OUTPUT: T T 1
L = .FALSE.
! OUTPUT: F F 0
ENDPROGRAM
"L" and "-L" write out the same value!
Jugoslav_Dujic
Valued Contributor II
Most simply:
I=0
IF (L) I=1
or, more "scientifically":
I = IAND( TRANSFER(L, I), 1)
The behaviour you get is consequence of the fact that in CVF literal .TRUE. TRANSFERs to -1 (#FFFFFFF) while .FALSE. TRANSFERs to 0. However, I
think that in expressions only least significant bit is tested, i.e.
L = 24
IF (L) THEN
     WRITE(*,*) "TRUE"
ELSE
     WRITE(*,*) "FALSE"
END IF
displays FALSE, while for L = 25 displays TRUE. CVF non-standardly allows free mixing of LOGICALs and INTEGERs but one should be careful with that
(as the code above shows).
Jugoslav
Jugoslav_Dujic
...couldn't resist to add a funny example:
PROGRAM X
INTEGER:: I
LOGICAL:: L = .TRUE.
WRITE(*,*) L + L      !Displays "F"
END PROGRAM
Jugoslav
Jugoslav_Dujic
...to put an end to this relentless self-replying, try compiling any of the samples above with "Project/Settings/Fortran Language/Fortran Standards Checking/Fortran95" option.
Steven_L_Intel1
I'll comment that compiling with the option /fpscomp:logicals changes the interpretation of LOGICAL to match that of PowerStation and C, where 0 is .FALSE. and 1 is .TRUE. When testing an integer as if it were a logical, anything not zero is considered TRUE.
Steve
