What's the easiest and clearest way to convert a logical in the following way:
.false. to 0
.true. to 1
I tried the following code with interesting results:
PROGRAM X
LOGICAL L
L = .TRUE.
WRITE(*,*) L,(-L),(-1*L)
! OUTPUT: T T 1
L = .FALSE.
! OUTPUT: F F 0
ENDPROGRAM
"L" and "-L" write out the same value!
.false. to 0
.true. to 1
PROGRAM X
LOGICAL L
L = .TRUE.
! OUTPUT: T T 1
L = .FALSE.
! OUTPUT: F F 0
ENDPROGRAM
Most simply:
or, more "scientifically":
The behaviour you get is consequence of the fact that in CVF literal .TRUE. TRANSFERs to -1 (#FFFFFFF) while .FALSE. TRANSFERs to 0. However, I
think that in expressions only least significant bit is tested, i.e.
displays FALSE, while for L = 25 displays TRUE. CVF non-standardly allows free mixing of LOGICALs and INTEGERs but one should be careful with that
(as the code above shows).
Jugoslav
I=0 IF (L) I=1
I = IAND( TRANSFER(L, I), 1)
L = 24 IF (L) THEN WRITE(*,*) "TRUE" ELSE WRITE(*,*) "FALSE" END IF
Jugoslav
...couldn't resist to add a funny example:
Jugoslav
PROGRAM X INTEGER:: I LOGICAL:: L = .TRUE. WRITE(*,*) L + L !Displays "F" END PROGRAM
Jugoslav
...to put an end to this relentless self-replying, try compiling any of the samples above with "Project/Settings/Fortran Language/Fortran Standards Checking/Fortran95" option.
I'll comment that compiling with the option /fpscomp:logicals changes the interpretation of LOGICAL to match that of PowerStation and C, where 0 is .FALSE. and 1 is .TRUE. When testing an integer as if it were a logical, anything not zero is considered TRUE.
Steve
Steve
