Software Archive
Read-only legacy content
17060 Discussions
mpss 3.3: unable to install libldap-dev k1om in mic
Ramon_B_
We are trying to install libldap in the mic's linux system, by using the overlay rpm feature. This is with MPSS 3.3
However, there seems to be a depedancy problem with the libldap-dev rpm supplied in the mpss-3.3-k1om.tar
[root@r14n9-mic0 RPMs-to-install]# rpm -i libldap-2.4-dev-2.4.23-r1.k1om.rpm
error: Failed dependencies:
	/usr/libexec/openldap/back_ldap-2.4.so.2.5.6 is needed by libldap-2.4-dev-2.4.23-r1.k1om
	/usr/libexec/openldap/back_meta-2.4.so.2.5.6 is needed by libldap-2.4-dev-2.4.23-r1.k1om
	/usr/libexec/openldap/back_monitor-2.4.so.2.5.6 is needed by libldap-2.4-dev-2.4.23-r1.k1om
	/usr/libexec/openldap/back_null-2.4.so.2.5.6 is needed by libldap-2.4-dev-2.4.23-r1.k1om
	/usr/libexec/openldap/back_passwd-2.4.so.2.5.6 is needed by libldap-2.4-dev-2.4.23-r1.k1om
	/usr/libexec/openldap/back_shell-2.4.so.2.5.6 is needed by libldap-2.4-dev-2.4.23-r1.k1om
These files are supplied by libldap-dbg, but in another path:
k1om# rpm -ql -p ./libldap-2.4-dbg-2.4.23-r1.k1om.rpm | grep back_
warning: ./libldap-2.4-dbg-2.4.23-r1.k1om.rpm: Header V4 DSA/SHA1 Signature, key ID 489957e7: NOKEY
/usr/libexec/openldap/.debug/back_ldap-2.4.so.2
/usr/libexec/openldap/.debug/back_ldap-2.4.so.2.5.6
/usr/libexec/openldap/.debug/back_ldap.so
/usr/libexec/openldap/.debug/back_meta-2.4.so.2
/usr/libexec/openldap/.debug/back_meta-2.4.so.2.5.6
/usr/libexec/openldap/.debug/back_meta.so
/usr/libexec/openldap/.debug/back_monitor-2.4.so.2
/usr/libexec/openldap/.debug/back_monitor-2.4.so.2.5.6
/usr/libexec/openldap/.debug/back_monitor.so
/usr/libexec/openldap/.debug/back_null-2.4.so.2
/usr/libexec/openldap/.debug/back_null-2.4.so.2.5.6
/usr/libexec/openldap/.debug/back_null.so
/usr/libexec/openldap/.debug/back_passwd-2.4.so.2
/usr/libexec/openldap/.debug/back_passwd-2.4.so.2.5.6
/usr/libexec/openldap/.debug/back_passwd.so
/usr/libexec/openldap/.debug/back_shell-2.4.so.2
/usr/libexec/openldap/.debug/back_shell-2.4.so.2.5.6
/usr/libexec/openldap/.debug/back_shell.so
This seems to be a bug in the RPM's, or am I missing something?
Any advice would be appreciated.
Loc_N_Intel
Hi Ramon,
I confirm that I cannot install libldap-dev, shipped with MPSS 3.3, in coprocessors due to the missing files in /usr/libexec/openldap.  I will generate a ticket to track this issue. Thank you very much.
Ramon_B_
ok thanks for confirming
Loc_N_Intel
Hi Ramon,
Just to follow up with you, this issue is resolved in the upcoming MPSS 3.5 . Thank you.
