Software Archive
Read-only legacy content
17060 Discussions
mux1 vs mux2 on IA-64
Adam
Why is it that mux1 only has five possible permutations, whereas mux2 has any possible permutation?
I was searching "the entire Internet" for the answer, and I couldn't find it. Maybe an Intel Itanium engineer can brief me on this one?
Adam
Terence_S_Intel
Quoting - Adam Kachwalla
Adam
mux2 operates on 4 elements. Therefore, you need 8-bitsin the instruction decode field (4 elems x4 possible destinations = 4 x 2 bits) to have all possible permutations.
mux1 operates on 8 elements. To have all possible permutations, you would need 24-bits in the instruction decode field (8 elems x8 possible destinations = 8 x 3 bits). Because only 8-bits are available in the instruction coding, a set of 5 common permutations are provided.
Adam
Adam
Couldn't you use an imm24 field?
Terence_S_Intel
There isn't enough space in a 41-bit instruction for a 24-bit field.
For mux1/mux2, you need 6-bits for QP, 14-bits for r1 and r2, 13-bits for opcode and extensions. That leaves the 8-bits for the permutations.
Adam
So then how do some instructions (such as movl) take imm64 fields?
Terence_S_Intel
Those instructions are special cases where you need to encode an address in the instruction. For the sake of simplicity, you'd like to severely limit those uses.
Adam
What about:
(qp)movl r3=imm64
(qp)mux1 r1=r2, r3
Or is mux1 like how it is so that only one instruction is needed?
Terence_S_Intel
What about:
(qp)movl r3=imm64
(qp)mux1 r1=r2, r3
movl needs to have an imm64 field. mux1 doesn't really need to. If mux1 did, it would make instruction decode much more difficult.
