Software Archive
Read-only legacy content
17060 Discussions
openmp vs. MIC speed issue
conor_p_
I am having issues with speed for a particular loop of my code. The openmp version with 8 threads is beating it every time on stampede. The way my example code below is organized is into three sections: one on the MIC with data transfer and memory allocation and no deallocation, one on the MIC with data transfer and no memory allocation, and one just using standard openMP. Although I am attaching four or so modules, PLEASE ONLY LOOK AT MC.F90. The other routines are just to set up the arrays for the loops in MC.f90. The code is compiled as follows
ifort -openmp -align array64byte global.f90 position.f90 modlist.f90 MC.f90 -O3 -o new.out
The times generated on the MIC were about 1.77 e-2 for the first case, 1.77 e-2 for the second case, and 1.4e-2 for the third case
The latency to use VTUNE on stampede is so bad that it renders it essentially useless. From what I could ascertain from tune is that I have some issue somewhere with threads having to wait around. Would someone who is good with VTUNE be willing to look at my loops in MC.f90 to see why my vectorized code runs slower on the MIC.
program lennard
  use ifport
  use position
  use global
  use modlist
  implicit none
  double precision :: potential, pressure
  integer :: criterium
  double precision :: energy,filter
  double precision :: minx,miny,minz
  double precision :: dx,dy,dz
  double precision :: dr,dr2,dri,dr2i,dr6i,dr12i
  double precision :: x1,y1,z1,x2,y2,z2
  integer :: l,i,j,k
  integer :: c1s,c1e,c2s,c2e
  integer :: T1,T2,T3,T4,clock_rate,clock_max
  integer :: count,cell_neigh
  integer :: num,tid,count1,count2,count3
  integer :: rep
  param%rcut = 2.50d0
  param%rcut2 = param%rcut**2
  param%dens = 1.0d0
  param%np   = 60000
  param%vol   = param%np/param%dens
  param%box   = param%vol**(1.0/3.0)
  param%hbox  = param%box/(2.0d0)
  allocate(x(param%np),y(param%np),z(param%np))
  call seed(10)
  !call srand(10)
  !--- initialize particles on a cubic grid
  call init_position('cubic grid', 'configuration.dat')
  !--- initialize list variables
  call init_list()
  call compute_cell_neighbors()
  call total_cell_sort_init(0)
  call build_r()
   do rep = 1,3
      print*,'beginning rep:',rep
      energy = 0.0d0
      count1 = 0
      ! case 1: MIC computation with data transfer                                  !
      call system_clock(T3,clock_rate,clock_max)
      !dir$ offload_transfer target(mic:0),&
      !dir$& in(x: alloc_if(.true.) free_if(.false.)),&
      !dir$& in(y: alloc_if(.true.) free_if(.false.)),&
      !dir$& in(z: alloc_if(.true.) free_if(.false.)),&
      !dir$& in(min_x: alloc_if(.true.) free_if(.false.)),&
      !dir$& in(min_y: alloc_if(.true.) free_if(.false.)),&
      !dir$& in(min_z: alloc_if(.true.) free_if(.false.)),&
      !dir$& in(start: alloc_if(.true.) free_if(.false.)),&
      !dir$& in(end: alloc_if(.true.) free_if(.false.)),&
      !dir$& in(cnum: alloc_if(.true.) free_if(.false.))
      !dir$ offload begin target(mic:0) nocopy(x,y,z,min_x,min_y,min_z,start,end,cnum) in(listvar) inout(energy)
      !$omp parallel do schedule(dynamic) reduction(+:energy),&
      !$omp& default(private) shared(min_x,min_y,min_z,start,end,cnum,x,y,z,listvar)
      do i = 0,listvar%ncellT-1
         c1s = start(i); c1e = end(i)
         do j = i*13,13*i+12
            cell_neigh = cnum(j)
            c2s = start(cell_neigh); c2e = end(cell_neigh)
            minx = min_x(j); miny = min_y(j) ; minz = min_z(j)
            do k= c1s,c1e
               x1 = x(k); y1 = y(k); z1 = z(k)
               do l = c2s,c2e
                  x2 = x(l); y2 = y(l); z2 = z(l)
                  dx = x2-x1-minx; dy = y2-y1-miny; dz = z2-z1-minz
                  dr2 = dx*dx + dy*dy + dz*dz
                  filter = 0.0d0
                  if(dr2.lt.2.50d0)then
                     filter = 1.0d0
                  endif
                  dr = sqrt(dr2)
                  dri = 1.0d0/dr
                  dr2i = 1.0d0*dri*dri
                  dr6i = dr2i*dr2i*dr2i
                  dr12i = dr6i*dr6i
                  energy = energy + 4.0d0*(dr12i-dr6i)*filter
               enddo
            enddo
         enddo
      enddo
      !$omp end parallel do
      !dir$ end offload
      call system_clock(T4,clock_rate,clock_max)
      print*,'timing for MIC computation case 2:',real(T4-T3)/real(clock_rate)
      print*,'energy case 2:',energy
      print*
      print*
   end do
   ! case three: arrays with data transfer and no memory alloc   !
   do rep = 1,3
      energy = 0.0d0
      !dir$& in(x: alloc_if(.false.) free_if(.false.)),&
      !dir$& in(y: alloc_if(.false.) free_if(.false.)),&
      !dir$& in(z: alloc_if(.false.) free_if(.false.)),&
      !dir$& in(min_x: alloc_if(.false.) free_if(.false.)),&
      !dir$& in(min_y: alloc_if(.false.) free_if(.false.)),&
      !dir$& in(min_z: alloc_if(.false.) free_if(.false.)),&
      !dir$& in(start: alloc_if(.false.) free_if(.false.)),&
      !dir$& in(end: alloc_if(.false.) free_if(.false.)),&
      !dir$& in(cnum: alloc_if(.false.) free_if(.false.))
         !do k = c1s,c1e
         !   x1 = x(k); y1 = y(k); z1 = z(k)
         do j = i*13,13*i+12
            do k= c1s,c1e
               do l = c2s,c2e
                  filter = 0.0d0
                     filter = 1.0d0
                  endif
                  dr = sqrt(dr2)
                  dri = 1.0d0/dr
                  dr12i = dr6i*dr6i
               enddo
            enddo
         enddo
      enddo
      !dir$ end offload
      print*,'time for MIC computation case 3 :',real(T4-T3)/real(clock_rate)
      print*,'energy case 3:',energy
      print*
      print*
   enddo
   ! case four: openmp                                         !
   energy = 0.0d0
   call system_clock(T1,clock_rate,clock_max)
   !$omp& default(private) shared(min_x,min_y,min_z,cnum,start,end,x,y,z,listvar)
     !do k = c1s,c1e
     do j = i*13,13*i+12
        do k= c1s,c1e
           do l = c2s,c2e
              filter = 0.0d0
              if(dr2.lt.2.0d0) filter =1.0d0
              dr = sqrt(dr2)
              dri = 1.0d0/dr
              dr12i = dr6i*dr6i
           enddo
        enddo
     enddo
  enddo
  call system_clock(T2,clock_rate,clock_max)
  print*,'time case 4 with filter:',real(T2-T1)/real(clock_rate)
  print*,'energy case 4:',energy
  print*
  print*
  stop
end program lennard
module modlist
  use global
  implicit none
contains
  !     constructor for class list         !
  subroutine init_list()
    implicit none
    integer :: i
    integer :: aver
    print*,param%box,param%rcut
    listvar%rn = (param%box/int(param%box/param%rcut))
    listvar%ncellT = nint(param%vol/(listvar%rn**3))
    listvar%ncellD = nint(listvar%ncellT**(1.0d0/3.0d0))
    listvar%alloc_size = int(ceiling(listvar%ncellT*1.2))
    print*,'--------------- INTIALIZING LISTS-----------------------------------'
    print*,'           rn                :',listvar%rn
    print*,'           ncellT            :',listvar%ncellT
    print*,'           ncellD            :',listvar%ncellD
    print*,'           MAKE SURE NCELLD CUBED IS NCELLT'
    print*,'--------------- END INTIALIZING LISTS-------------------------------'
    !--- try these arrays
    ! attributes align:64::min_x,min_y,min_z,cnum
    allocate(min_x(0:13*listvar%alloc_size),min_y(0:13*listvar%alloc_size),min_z(0:13*listvar%alloc_size))
    allocate(cnum(0:13*listvar%alloc_size))
    allocate(cl(0:listvar%alloc_size))
    allocate(cv_total(13,0:listvar%alloc_size))
    allocate(start(0:listvar%alloc_size),end(0:listvar%alloc_size))
    !--- allocate temp variables used for cell sort
    allocate(temp_num(0:listvar%alloc_size))
    aver = cell_max()
    aver = int(ceiling(1.4*aver))
    print*,'AVERAGRE',aver
    do i =0, listvar%alloc_size
       allocate(cl(i)%loc_r(aver))
       cl(i)%size = aver
    enddo
    !--- allocate atom cell construct
    allocate(atom(param%np))
  end subroutine init_list
  !     determines the neigh neighbors for total energy calculation      !
  subroutine  neighcell_total()
    implicit none
    integer :: offsets(3,13)
    integer :: in,i,count
    integer :: ic,itel,icz,icy,icx
    integer :: ix,iy,iz
    integer :: iccx,iccy,iccz
    integer :: x,y,z
    !--- build offsets array
    offsets(1,1)=1; offsets(2,1)=0;  offsets(3,1) = 0
    offsets(1,2)=1; offsets(2,2)=1;  offsets(3,2) = 0
    offsets(1,3)=1; offsets(2,3)=-1; offsets(3,3) = 0
    offsets(1,4)=0; offsets(2,4)=-1; offsets(3,4) = 0
    offsets(1,5)=1; offsets(2,5)=0;  offsets(3,5) = 1
    offsets(1,6)=1; offsets(2,6)=1;  offsets(3,6) = 1
    offsets(1,7)=1; offsets(2,7)=-1; offsets(3,7) = 1
    offsets(1,8)=0; offsets(2,8)=-1; offsets(3,8) = 1
    offsets(1,9)=1;  offsets(2,9)=0;  offsets(3,9) = -1
    offsets(1,10)=1; offsets(2,10)=1; offsets(3,10) = -1
    offsets(1,11)=1; offsets(2,11)=-1;offsets(3,11) = -1
    offsets(1,12)=0; offsets(2,12)=-1;offsets(3,12) = -1
    offsets(1,13) = 0; offsets(2,13)=0; offsets(3,13) = 1
    count = 0
    do ic = 0,listvar%ncellT-1
       !--- obtain x,y,z coordinates of cell of interest: ic
       !--- this is doing using integer arithmetic
       icz = ic/(listvar%ncellD*listvar%ncellD)
       icy = (ic - icz*listvar%ncellD*listvar%ncellD)/(listvar%ncellD)
       icx = ic -icy*listvar%ncellD - icz*listvar%ncellD*listvar%ncellD
       do i = 1,13
          ix = offsets(1,i); iy = offsets(2,i); iz = offsets(3,i)
          iccz = icz+iz
          if(iccz.lt.0) then
             z = iccz + listvar%ncellD
          else if (iccz.ge.listvar%ncellD) then
             z = iccz - listvar%ncellD
          else
             z = iccz
          endif
          iccy = icy+iy
          if(iccy.lt.0) then
             y = iccy + listvar%ncellD
          else if (iccy.ge.listvar%ncellD) then
             y = iccy - listvar%ncellD
          else
             y = iccy
          endif
          iccx = icx+ix
          if(iccx.lt.0) then
             x = iccx + listvar%ncellD
          else if (iccx.ge.listvar%ncellD) then
             x = iccx - listvar%ncellD
          else
             x = iccx
          endif
          in = (x+y*listvar%ncellD + z*listvar%ncellD*listvar%ncellD)
          cnum(count) = in
          cv_total(i,ic)%cnum = in
          !--- store min im in cv array
          if(iccx.lt.0) then
             min_x(count) = param%box
             min_x(count) = -param%box
          else
             min_x(count) = 0.0d0
          endif
          if(iccy.lt.0) then
             min_y(count) = param%box
             min_y(count) = -param%box
          else
             min_y(count) = 0.0d0
          endif
          if(iccz.lt.0) then
             min_z(count) = param%box
             min_z(count) = -param%box
          else
             min_z(count) = 0.0d0
          endif
          count = count + 1
       enddo
    enddo
  end subroutine neighcell_total
  ! compute cell interaction indicies      !
  ! compute miniomage for each cell pair   !
  ! compute cell coordinates for each cell
  subroutine compute_cell_neighbors()
    implicit none
    call neighcell_total()
  end subroutine compute_cell_neighbors
  !     determines cell number             !
  integer function cell(x,y,z)
    implicit none
    double precision :: x,y,z
    integer :: ix,iy,iz
    if(x.lt.param%box)then
       ix = int(x/listvar%rn)
    else
       ix = listvar%ncellD-1
    endif
    if(y.lt.param%box)then
       iy = int(y/listvar%rn)
    else
       iy = listvar%ncellD-1
    endif
    if(z.lt.param%box)then
       iz = int(z/listvar%rn)
    else
       iz = listvar%ncellD-1
    endif
    cell = ix+iy*listvar%ncellD+iz*listvar%ncellD*listvar%ncellD
  end function cell
  ! finds cell with largest number of atoms for initial array allocation
  integer function cell_max()
    implicit none
    integer :: temp_cell(param%np)
    integer :: i,icell
    temp_num(:) = 0
    cell_max = 0
    do i = 1 ,param%np
       icell = cell( x(i),y(i),z(i))
       temp_cell(i) = icell
       temp_num(icell) = temp_num(icell) + 1
       if(temp_num(icell).gt.cell_max)then
          cell_max = temp_num(icell)
       endif
    enddo
  end function cell_max
  ! want to assign each atom to appropriate cell
  ! generate list of atoms in each cell for GONET algorithm
  ! do not want to deallocate and reallocate her
  subroutine total_cell_sort_init(step)
    implicit none
    integer :: step
    integer :: i,icell
    integer :: new_size
    temp_num(:) = 0
    do i = 1 ,param%np
       icell = cell(x(i),y(i),z(i))
       !--- keep particles current cell
       atom(i)%cell = icell
       atom(i)%loc  = temp_num(icell)
    enddo
    do i=0, listvar%ncellT - 1
       !--- number of molecules in cell
       cl(i)%num = temp_num(i)
       !--- while sorting here, check to see if reallocation is needed
       if(cl(i)%num.gt.cl(i)%size) then
          new_size = int(ceiling(1.4*cl(i)%num))
          deallocate(cl(i)%loc_r)
          allocate(cl(i)%loc_r(new_size))
          cl(i)%size = new_size
       endif
    enddo
    do i= 1,param%np
       !--- get cell for particle
       icell = atom(i)%cell
       !--- place particles in cell
       cl(icell)%loc_r(atom(i)%loc)%x = x(i)
       cl(icell)%loc_r(atom(i)%loc)%y = y(i)
       cl(icell)%loc_r(atom(i)%loc)%z = z(i)
    enddo
  end subroutine total_cell_sort_init
  subroutine build_r()
    integer :: i,j,counter
    counter = 0
       start(i) = counter + 1
       do j = 1 ,cl(i)%num
          counter = counter + 1
          x(counter)    = cl(i)%loc_r(j)%x
          y(counter)    = cl(i)%loc_r(j)%y
          z(counter)    = cl(i)%loc_r(j)%z
       enddo
       end(i) = counter
    enddo
  end subroutine build_r
end module modlist
module global
  implicit none
  !                      INPUT VARIABLES                                              !
  type input
     double precision :: rcut,rcut2,rv,rv2,rcrv2,rcrv
     double precision :: maxd,vmax
     double precision :: kboltz
     double precision :: vol,box,hbox,ibox
     double precision :: dens
     double precision :: temp,P,beta
     double precision :: alpha
     integer :: np
     integer :: istart
     integer :: mceq,mcsteps
     integer :: nsample, nadjust
  end type input
  type nuc
     double precision :: kn
     integer :: numSweep,numStep
  end type nuc
  type(nuc) :: nucVar
  type ainfo
     integer :: type
  end type ainfo
  !--- declare param variable
  !dir$ attributes offload:mic::param
  type(input) :: param
  !                        POSITION ARRAYS                                             !
  !dir$ attributes offload:mic::start
  integer,allocatable :: start(:)
  !dir$ attributes offload:mic::end
  integer,allocatable :: end(:)
  !dir$ attributes offload:mic::min_x
  double precision, allocatable :: min_x(:)
  !dir$ attributes offload:mic::min_y
  double precision, allocatable :: min_y(:)
  !dir$ attributes offload:mic::min_z
  double precision, allocatable :: min_z(:)
  !dir$ attributes offload:mic::x
  double precision, allocatable :: x(:)
  !dir$ attributes offload:mic::y
  double precision, allocatable :: y(:)
  !dir$ attributes offload:mic::Z
  double precision, allocatable :: z(:)
  !---------------------  LIST ARRAYS  --------------------------------------------!
  type atom_cell
     !--- cell of atom
     integer :: cell
     !--- position in cell list
     integer :: loc
  end type atom_cell
  type cell_data
     !--- x,y,z coordinates of particles
     type(ainfo),allocatable :: loc_r(:)
     !--- total number of atoms in cell
     integer :: num
     !---size of array
     integer :: size
  end type cell_data
  type vlist
    !--- minimum image displacement convention
     double precision :: min_z,min_y,min_x
     !--- cnum is going to be the cell index being held
     integer :: cnum
  end type vlist
  type vlist_SOA
     double precision, allocatable :: min_x(:),min_y(:),min_z(:)
     integer, allocatable :: cnum(:)
  end type vlist_SOA
  type list
     !.....declare doubles and ints
     double precision :: rn
     integer :: ncellT
     integer :: ncellD
     !--- typically 1.4 * ncellT
     integer :: alloc_size
     integer :: cv_size
  end type list
  !--- try just arrays
  !dir$ attributes offload:mic::cnum
  !--- declare variable for above types
  !dir$ attributes offload:mic:: listvar
  type(list) :: listvar
  type(atom_cell),allocatable  :: atom(:)
  !--- cell lists
  !--- for each cell, contains the atoms present
  !--- cell_list(i)%cell_members(j) is ith cell's jth member
  type(cell_data), allocatable :: cl(:)
  !--- cell verlet lists
  !--- This is going to be interaction matrix for cell pairs
  !--- Each index in matrix will contain verlet list
  !--- index (i,j)%(a,:) will contain atoms in cell j within cuttoff from atom a in cell i
  type(vlist), allocatable :: cv_total(:,:)
  !---temp variables used for cell sorts
  integer, allocatable :: temp_num(:)
end module global
module position
  use ifport
  use global
  implicit none
  integer:: numpd
  double precision ::gsize
  integer :: flag
contains
  subroutine init_position(situation,file_name)
    implicit none
    integer:: counter,i,j,k
    character(len=*) :: situation,file_name
    double precision :: half,deltax,remainder,spot
    print*,'from init position:',param%box,param%np
    numpd = ceiling(param%np**(1.0d0/3.0d0))
    gsize = param%box/(1.0d0*numpd)
    print*,'----------------initializing positions ----------------------'
       print*,'              INITIALIZING PARTICLES ON CUBIC GRID'
       print*,'              GRID SPACING:',gsize
       print*,'              NUMBER PER DIMENSION',numpd
       counter =1
       do i=1,numpd
          do j=1,numpd
             do k=1,numpd
                if(counter.le.param%np)then
                   x(counter) = (k-1)*gsize
                   y(counter) = (j-1)*gsize
                   z(counter) = (i-1)*gsize
                endif
                counter = counter+1
             enddo
          enddo
       enddo
  end subroutine init_position
end module position
conor_p_
Ugh. Sorry I don't know why the code came out like that, and I don't see an edit post anywhere so I will repost the code
program lennard
  use ifport
  use position
  use global
  use modlist
  implicit none
  integer :: l,i,j,k
  integer :: rep
  param%rcut = 2.50d0
  param%dens = 1.0d0
  param%np   = 60000
  call seed(10)
  !call srand(10)
  call init_list()
  call build_r()
   do rep = 1,3
      energy = 0.0d0
      count1 = 0
         do j = i*13,13*i+12
            do k= c1s,c1e
               do l = c2s,c2e
                  filter = 0.0d0
                     filter = 1.0d0
                  endif
                  dr = sqrt(dr2)
                  dri = 1.0d0/dr
                  dr12i = dr6i*dr6i
               enddo
            enddo
         enddo
      enddo
      !dir$ end offload
      print*
      print*
   end do
   do rep = 1,3
      energy = 0.0d0
         !do k = c1s,c1e
         do j = i*13,13*i+12
            do k= c1s,c1e
               do l = c2s,c2e
                  filter = 0.0d0
                     filter = 1.0d0
                  endif
                  dr = sqrt(dr2)
                  dri = 1.0d0/dr
                  dr12i = dr6i*dr6i
               enddo
            enddo
         enddo
      enddo
      !dir$ end offload
      print*
      print*
   enddo
   energy = 0.0d0
     !do k = c1s,c1e
     do j = i*13,13*i+12
        do k= c1s,c1e
           do l = c2s,c2e
              filter = 0.0d0
              dr = sqrt(dr2)
              dri = 1.0d0/dr
              dr12i = dr6i*dr6i
           enddo
        enddo
     enddo
  enddo
  print*
  print*
  stop
end program lennard
module global
  implicit none
  !                      INPUT VARIABLES                                              !
  type input
     integer :: np
     integer :: istart
  end type input
  type nuc
  end type nuc
  type(nuc) :: nucVar
  type ainfo
     integer :: type
  end type ainfo
  !                        POSITION ARRAYS                                             !
  type atom_cell
     !--- cell of atom
     integer :: cell
     integer :: loc
  end type atom_cell
  type cell_data
     integer :: num
     !---size of array
     integer :: size
  end type cell_data
  type vlist
     integer :: cnum
  end type vlist
  type vlist_SOA
  end type vlist_SOA
  type list
     integer :: ncellT
     integer :: ncellD
     integer :: cv_size
  end type list
  !--- cell lists
end module global
module modlist
  use global
  implicit none
contains
    implicit none
    integer :: i
    integer :: aver
    aver = cell_max()
       cl(i)%size = aver
    enddo
    implicit none
    integer :: ix,iy,iz
    integer :: x,y,z
    count = 0
       do i = 1,13
          iccz = icz+iz
          if(iccz.lt.0) then
          else
             z = iccz
          endif
          iccy = icy+iy
          if(iccy.lt.0) then
          else
             y = iccy
          endif
          iccx = icx+ix
          if(iccx.lt.0) then
          else
             x = iccx
          endif
          cnum(count) = in
          if(iccx.lt.0) then
          else
          endif
          if(iccy.lt.0) then
          else
          endif
          if(iccz.lt.0) then
          else
          endif
          count = count + 1
       enddo
    enddo
    implicit none
    implicit none
    integer :: ix,iy,iz
    else
    endif
    else
    endif
    else
    endif
  end function cell
    implicit none
    integer :: i,icell
    temp_num(:) = 0
    cell_max = 0
    do i = 1 ,param%np
       endif
    enddo
    implicit none
    integer :: step
    integer :: i,icell
    integer :: new_size
    temp_num(:) = 0
    do i = 1 ,param%np
    enddo
       endif
    enddo
    do i= 1,param%np
    enddo
    counter = 0
       do j = 1 ,cl(i)%num
       enddo
       end(i) = counter
    enddo
end module modlist
module position
  use ifport
  use global
  implicit none
  integer:: numpd
  integer :: flag
contains
    implicit none
       counter =1
       do i=1,numpd
          do j=1,numpd
             do k=1,numpd
                endif
                counter = counter+1
             enddo
          enddo
       enddo
end module position
Sunny_G_Intel
Hi Conor,
Before investigating further I would like to verify if I have the source code compiled and running correctly. I have the following output :
 from init position:   39.1486806904843            60000
 ----------------initializing positions----------------------
               GRID SPACING:  0.978717017262106
               NUMBER PER DIMENSION          40
   39.1486806904843        2.50000000000000
            rn                :   2.60991204603228
            ncellT            :        3375
            ncellD            :          15
 AVERAGRE          38
 beginning rep:           1
 timing for MIC computation case 2:  0.8054000
 energy case 2:  0.000000000000000E+000
 beginning rep:           2
 timing for MIC computation case 2:  2.0999999E-03
 beginning rep:           3
 timing for MIC computation case 2:  1.8000000E-03
 beginning rep:           1
 time for MIC computation case 3 :  2.0999999E-03
 energy case 3:  0.000000000000000E+000
 beginning rep:           2
 time for MIC computation case 3 :  1.8000000E-03
 beginning rep:           3
 time for MIC computation case 3 :  2.0000001E-03
 time case 4 with filter:  6.9100000E-02
 energy case 4:  0.000000000000000E+000
I am not sure if the values for energy should be zero for all cases. Am I doing something wrong.
