we need to do some image processing in both depth stream and color stream.for it has optical parallax between two kinds of stream, I'd like to know how to get the offset value and how to match depth and color stream.
All of that is nicely covered in the documentation.
I want to convert the 16-bit depth data to millimeter.what is the formula? Is that " *0.0001"?
i have been looking in the documentation at https://software.intel.com/sites/landingpage/realsense/camera-sdk/v1.1/documentation/html/index.html?doc_devguide_whats_new_in_sdk.html quite a lot and have not found anything about this offset.
i measured it manually to be between 30 - 60 px in horizontal positive way.
have you found anything about the offset? if so, can you give me a link or a hint where to find it in the documentation?
i think i get direct mm values from my R200 in 16 bit depth. i convert it into opencv format to show it and there a value of 1000 roughly makes 1 m
You don't (can't?) get offset values, you use methods in the PXCMProjection interface to map between the images.
That is exactly what I was looking for!
It seems like I was looking at the wrong place in the documentation or didnt see the link of it to my issue.
Anyway : Thank you very much James!
Edit:
some code snippet for fellow visitors of this post
PXCSenseManager *sm = PXCSenseManager::CreateInstance();
sm->Init();
PXCCaptureManager *cmanager = sm->QueryCaptureManager();
PXCCapture::Device *device = cmanager->QueryDevice();
PXCProjection *projection = device->CreateProjection();
PXCCapture::Sample *sample;
while (sm->AcquireFrame(true) >= PXC_STATUS_NO_ERROR) {
sample = sm->QuerySample();
if (sample->depth) {
PXCImage *depthPXCImage = projection->CreateDepthImageMappedToColor(sample->depth,sample->color);
//image is now aligned
