Software Archive
Read-only legacy content
17060 Discussions
placeholder
FiXo
Hi, it seems to be a bug with "placeholder" attributes in textarea (see picture).
The placeholder value don't disapear :)
Thanks for all !
Chris_P_Intel
what UI framework are you using?
FiXo
Android (Nexus 5).
Swati_S_Intel1
Did you create the app from scratch or did you use App Designer?  If you used App Designer, when you create the project it asks you which UI framework you want to use? What option did you select (jQuery Mobile/App Framework/Twitter Bootstrap/Topcoat)?
Swati
Anusha_M_Intel1
Hi FiXo,
I tried this on a Nexus 5. The issue exists when debugging on device. But its fine once you build the app. The placeholder text disappears.
Hope this helps.
