Software Archive
Read-only legacy content
17061 ディスカッション
problems using stl in implicit model
ankit_m_
ビギナー
983件の閲覧回数
I am writing this very simple program using implicit offload model. wherein I make use of cilk_plus lib. I run into trouble when I do the following, my code doesn't run, can anyone please help me understand what I am doing incorrect here,
I am not including the definitions because when I do so somehow my message gets spammed. but if you look at the class body it is very straightforward.
#include <iostream>
#include <cilk/cilk.h>
#pragma offload_attribute(push,_Cilk_shared)
#include <vector>
#include "offload.h"
#pragma offload_attribute(pop)
#include "omp.h"
class _Cilk_shared Test
    public:
        Test();
        ~Test();
        unsigned long long GetNumElems();
        vector<int>& GetVec();
        unsigned long long PerformAdd();
        unsigned long long m_res;
        void SimulateData();
    protected:
        //void SimulateData();
        vector<int> m_vec;
Test* _Cilk_shared tt1;
int main()
    tt1 = new _Cilk_shared Test();
    _Cilk_offload_to(0) tt1->SimulateData();
    tt1->m_res = _Cilk_offload_to(0) tt1->PerformAdd();
    cout << tt1->m_res << endl;
    // auto clean up on MIC I presume !!
    return 0;
Following is what I get when I compile
 icc -openmp  -offload-option,mic,compiler,"-z defs" cpSimple.cpp -o cpOO
/tmp/iccgh0xCb.o: In function `Test::Test()':
cpSimple.cpp:(.text+0x82): undefined reference to `std::vector<int, std::allocator<int> >::vector()'
/tmp/iccgh0xCb.o: In function `Test::SimulateData()':
cpSimple.cpp:(.text+0xf5): undefined reference to `std::vector<int, std::allocator<int> >::push_back(int const&)'
/tmp/iccgh0xCb.o: In function `Test::PerformAdd()':
cpSimple.cpp:(.text+0x37b): undefined reference to `std::vector<int, std::allocator<int> >::operator[](unsigned long)'
/tmp/iccgh0xCb.o: In function `Test::~Test()':
cpSimple.cpp:(.text+0x532): undefined reference to `std::vector<int, std::allocator<int> >::~vector()'
/tmp/iccgh0xCb.o: In function `Test::GetNumElems()':
cpSimple.cpp:(.text+0x587): undefined reference to `std::vector<int, std::allocator<int> >::size() const'
Thank you
Sincerely,
AM
0 件の賞賛
4 返答(返信)
TimP
名誉コントリビューター III
983件の閲覧回数
Why not use icpc to link? This isn't MIcrosoft Windows; icc is a real C compiler driver, not C++.
Kevin_D_Intel
従業員
983件の閲覧回数
I cannot reproduce the same errors despite trying to fill in for the missing definitions so it would be difficult to understand the errors without have the complete code.
Could you try attaching a file containing the complete source that includes the definitions for the missing functions and that produces the errors you showed?
ankit_m_
ビギナー
983件の閲覧回数
Hello Kevin,
Thank you for all your help in troubleshooting this. Attached is the src file.
I am running into troubles with stl and generally unsure of what headers need to go in my scr file at the time of offload.
e.g. should I use offload.h or <new>
#include <vector>
Also, following is what I do to compile my program
 icpc -openmp  -offload-option,mic,compiler,"-z defs" cpSimple2.cpp -o ss2++
I have included -offload-option to understand what is happening at the MIC side but when I use this trigger I see a lot more error messages than mentioned in my earlier post.
I really appreciate all your help here.
Sincerely,
AM
Kevin_D_Intel
従業員
983件の閲覧回数
Thank you AM. The attached test case does not compile "as is" but we understand your interest and with some small changes can reproduce the link errors mentioned. Developers are looking into this case now and a run-time failure that has surfaced with it so I'll update again when I know more.
返信
