Software Archive
Read-only legacy content
17060 Discussions
requirement to log in and restart forum every time
TimP
The new "feature" where we are logged out automatically and must enter the forum, log in, then reenter the forum, is irksome.  If this is intended as a way to slow down the spam temporarily, I suppose it won't be long before it fails.
I have this same problem on various browsers and various OS (I access the forum from Windows, Android, and linux).
Harold_G_Intel
Hi Tim,
I am not aware of this "feature.".  I'll check into it.
Regards, Hal G
Intel(R) Developer Zone Support
http://software.intel.com
*Other names and brands may be claimed as the property of others.
Harold_G_Intel
Hi Tim,
I will be sending you a separate email on this.
Regards, Hal G
TimP
It still happens more often than not on Windows Firefox that it's necessary to re-enter the forum from the top after logging in.  The efforts made by the support team have improved things and fixed the problem of the forum being difficult to use on Android.
Bernard
Valued Contributor I
Although I do not have the problem described by Tim. I would raise the question related to long loading and web refresh times. I am not sure if IDZ web server is constantly overloaded or has to cope with small available bandwidth, but this kind of problems is quite annoying.
TimP
It still happens frequently that it's necessary to reenter the forum after logging in.  More annoying lately is the survey pop up while replying to a post, which usually on android requires replying to the post and losing several minutes.
