Software Archive
Read-only legacy content
17060 Discussions
simple questions
Jen_B_
1) I have only one coprocessor, then "offload target(mic)" is same as "offload target(mic:0)"?
2) I specify only fortran arrays inside "in/out/inout" for the offloaded openmp parallel region, do variables used inside that region also need to be explicitly specified inside the "in/out/inout"? Or are they implicitly put inside the "in"? thanks.
Jen_B_
forgot to tell that in 2) I won't need those variables back. thanks.
Kevin_D_Intel
1) Yes
2) Variables the compiler sees within the lexical scope of the offload code are implicitly transferred by default with INOUT so add them to an explicit IN to avoid transferring their values back to the host at the conclusion of the offload code block.
Jen_B_
Thanks!
