Software Archive
Read-only legacy content
[solved] "Package signature verification failed" warning on installation
Mike_K_2
I try to install Intel XDK 2727 on Windows 7 x64 SP1 but failed due to "Package signature verification failed" error.
I've downloaded the package 3x and try to install it but still no joy.
I think the issue come from the invalid digital signature/certificate but how to fix it?
Thanks!
Elroy_A_Intel
I have escalated your issue to the Intel XDK engineering team to investigate.
Mike_K_2
Thanks Elroy!
I've found the solution!
For those who has a problem like me, you need to start a "Certificate Propagation" services from Control Panel.
Start->search for "services.msc"->find service called "Certificate Propagation"->start the service.
cheers!
Daniel_Q_Intel
Hi Mike,
Yes, this error come from the invalid digital signature/certificate. It's caused if the system doesn't have root certificate.  Mike's solution is right. Additionaly, certificates can be installed automatically with Windows update
Other link related to Manage Trust Certificates: https://technet.microsoft.com/en-us/library/cc754841.aspx
Cheers Regards
Daniel Quiroga
David_J_4
I've tried to download this application on various machines, Windows 10, Windows 7, Windows Server 2016, Windows Server 2012R2 always get the same error.
David_J_4
Please note that I did try importing the certificate
joao_g_
boa noite,
infelizmente minha maquina ainda utiliza o windows vista,
como posso instalar o software com sucesso?
grato desde ja
Pamela_H_Intel
Joao,
We do not support Windows Vista. Intel XDK can be used on Windows 7+, Ubuntu Linux, or Mac OS X.
