Software Archive
Read-only legacy content
17060 Discussions
spotlight search icon not updated
Alon_I_
Hello
I followed your instructions  here on how to update spotlight search. this is for a construct game
ive added the following lines to my additions xml
<platform name="ios">
    <!-- iOS 7.0+ -->
        <!-- iPhone / iPod Touch  -->
            <icon src="icon-60.png" width="60" height="60" />
            <icon src="icon120.png" width="120" height="120" />
        <!-- iPad -->
            <icon src="icon76.png" width="76" height="76" />
            <icon src="icon152.png" width="152" height="152" />
</platform>
the icons are in the root directory of the construct export
What am i doing wrong ?
John_H_Intel2
The additions file needs to be named  intelxdk.config.additions.xml
Alon_I_
Hi John, thats the name i used for my file
the icons are at the root where the file is.
other then that i dont know why it stuill shows the default cordova icon.
Alon
Rakshith_K_Intel
Thanks for reporting, we are looking into this issue.
The correct way to spotlight and settings icons in additions xml are as follows, the main icons for iphone and ipad should be added from build settings UI:
<icon platform="ios" src="ios/Icon-40.png" width="40" height="40" />
<icon platform="ios" src="ios/Icon-40@2x.png" width="80" height="80" />
<icon platform="ios" src="ios/Icon-40@3x.png" width="120" height="120" />
<icon platform="ios" src="ios/Icon-Small.png" width="29" height="29" />
<icon platform="ios" src="ios/Icon-Small@2x.png" width="58" height="58" />
<icon platform="ios" src="ios/Icon-Small@3x.png" width="87" height="87" />
The spotlight icon are not updated currently, we are looking in to this now.
Alon_I_
HI Rakshith
I followed the instructions here : https://software.intel.com/en-us/xdk/docs/cordova-for-ios-build-option
there is another article with other instructions q19
https://software.intel.com/en-us/xdk/faqs/general
I guess that icon sizes in my file are not right
Rakshith_K_Intel
https://software.intel.com/en-us/xdk/docs/cordova-for-ios-build-options
The instruction in above doc is correct, the faq has to be updated.
However, we just found an issue, the icons for spotlight are not applied in the build, we are working on a fix.
Alon_I_
Hi Rakshith,
We have an app ready for market only with this issue unresolved and relied on xdk to publsih for us. I saw that there is a new build for the XDK without this being addressed.
We can't upload the app with the cordova icons , its just not professional on our end. Any time estimate for this?  Maybe a workaround ?
Rakshith_K_Intel
Can u check now again with these added to additions file:
delete the existing app on ios device and install the new build on device, spotlight icon should work now, I just tried, it works in spotlight
Alon_I_
Hello Rakshith,
Isnt it exactly the same file as you post in message # 4? What was changed ?
Do i need to locate the icons under ios folder and use the exact names ? i.e "Icon-Small@3x.png"
i used these files with diferent names and located on root but it didnt work
. i.e <icon platform="ios" src="icon87.png" width="87" height="87" />
Rakshith_K_Intel
nothing has changed, your declaration is correct, just delete the app on device and reinstall.
make sure that after you build, u are see the <icon ..> tags in the ios config xml file
Alon_I_
Thanks, so do i need to use the same icon names in the xml or i can renamed their location and names inside the xml ?
Alon_I_
unfortuntely that doest work
while i used exactly the same file name and location and got no build error. ipad still shows the cordova icon in the spotlight search
Alon_I_
log file shows some errors in regards to uploading the files which are not related to what i have in the additions file.
Copying icon from .../shapes1/icon-60.png to .../shapes1/platforms/ios/shapes1/Resources/icons/icon-60.png
cp: no such file or directory: .../shapes1/icon-60.png
Copying icon from .../shapes1/icon120.png to .../shapes1/platforms/ios/shapes1/Resources/icons/icon-60@2x.png
cp: no such file or directory: .../shapes1/icon120.png
Copying icon from .../shapes1/icon-180.png to .../shapes1/platforms/ios/shapes1/Resources/icons/icon-60@3x.png
cp: no such file or directory: .../shapes1/icon-180.png
Copying icon from .../shapes1/icon76.png to .../shapes1/platforms/ios/shapes1/Resources/icons/icon-76.png
cp: no such file or directory: .../shapes1/icon76.png
Copying icon from .../shapes1/icon152.png to .../shapes1/platforms/ios/shapes1/Resources/icons/icon-76@2x.png
cp: no such file or directory: .../shapes1/icon152.png
Copying icon from .../shapes1/ios/Icon-40.png to .../shapes1/platforms/ios/shapes1/Resources/icons/icon-40.png
cp: no such file or directory: .../shapes1/ios/Icon-40.png
Copying icon from .../shapes1/ios/Icon-40@2x.png to .../shapes1/platforms/ios/shapes1/Resources/icons/icon-40@2x.png
cp: no such file or directory: .../shapes1/ios/Icon-40@2x.png
Copying splash from .../shapes1/splash_iphone_r.png to .../shapes1/platforms/ios/shapes1/Resources/splash/Default-Landscape-736h.png
cp: no such file or directory: .../shapes1/splash_iphone_r.png
Rakshith_K_Intel
looks like the path for the icons are incorrectly defined in the xml file, you can have any name, the path for icon files should be relative to the folder where you have index.html.
if your project structure is like this:
- www/index.html
- www/ios/icon-40.png
then your icon should be defined like this
<icon platform="ios" src="ios/icon-40.png" width="40" height="40" />
Alon_I_
Hi thats exactly what i did The icon152 is in the root directory but fron reason it doesnt upload it. Btw this icon is called from the xdk icon selection and still it wasnt uploaded. The icons 40 20@2x etc were in root/ios/ and still are not uploaded. Will it help if i send you in pm my additions xml and file structure? There
Rakshith_K_Intel
just sent you a PM, send me link to download your project, I can try and let you know whats going on.
Alon_I_
I am going away for a few days without my computer. i will send it to you in a few days. Many thanks
Alon_I_
've sent you a PM :)
Rakshith_K_Intel
I got your code and opened in Intel XDK v1995, changed to my provision profile and built ios, installed on my iPhone6, app icon and spotlight icons are working, see attached images.
http://s16.postimg.org/k6jjzh3vp/Screen_Shot_2015_05_14_at_11_07_43_AM.png
http://s28.postimg.org/w5cjpfjr1/image2_1.png
http://s12.postimg.org/5uycnz9hp/image1_4.png
For older iphone and ipad and older ios versions, you have to add 5 more icons in additions xml file:
<!-- Spotlight Icon -->
	<icon platform="ios" src="res/ios/icon-40.png" width="40" height="40" />
	<icon platform="ios" src="res/ios/icon-40@2x.png" width="80" height="80" />
	<icon platform="ios" src="res/ios/icon-40@3x.png" width="120" height="120" />
<!-- iPhone Spotlight and Settings Icon -->
	<icon platform="ios" src="res/ios/icon-small.png" width="29" height="29" />
	<icon platform="ios" src="res/ios/icon-small@2x.png" width="58" height="58" />
	<icon platform="ios" src="res/ios/icon-small@3x.png" width="87" height="87" />
<!-- iPad Spotlight and Settings Icon -->
	<icon platform="ios" src="res/ios/icon-50.png" width="50" height="50" />
	<icon platform="ios" src="res/ios/icon-50@2x.png" width="100" height="100" />
