Software Archive
Read-only legacy content
standalone KNL + MKL
linewstar_l_
I've just got a KNL 7250, and I'm testing MKL perf on it.
MKL lib has 3 versions( IA32, intel64, mic),  I know to use MKL on Xeon Phi coprocessor, we should use mic, but my question is:
Which version of MKLshould I use on standalone KNL ?     mic or intel64?
I guess it's intel64 because mic is for PCIe XeonPhi?
Am i right?   thanks.
JJK
New Contributor III
for KNL you should (always) use intel64 - and on my KNL box I see the impact of using MKL in e.g. matlab.
Even for a PCIe version you would use intel64 - the "mic" version is for KNC only.
yu__frank
Hi Iinewstar.
  Where you found the MIC version of MKL ? I install Intel compiler 2007, I only found the intel64 version of MKL at the path: ./compilers_and_libraries/linux/mkl/intel64_lin
JJK
New Contributor III
that library comes with the Intel Composer XE package; the RPM name is intel-mkl-mic-XXX where "XXX" is a number that depends on the exact compiler suite. For the XE 2015 suite it was 090; for the XE 2013 suite it was 174, oddly enough
SergeyKostrov
Valued Contributor II
>>...I guess it's intel64 because mic is for PCIe XeonPhi? In my current environment I use the following command line to compile sources that use MKL API: icpc -O3 -xMIC-AVX512 -lmemkind -qopenmp -mkl -qopt-report=0 ... I could look for more technical details some time later ( paths, etc ) if you need.
